Question about Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator
Freezer coils keep freezing up
I think my defrost system is broke, I used to hear it defrost every few days, now I dont hear it at all and I always notice my coils are frozen. How do I start fixing it?
  • 1 more comment
  • leonardmp92 Dec 27, 2008
    Thanks Ken. Where do you think the defrost timer and thermostat is located?
    Should I assume that I have a manual defrost timer? I have Kenmore refrig, model 106-5666*502...I dont even know if that model number is correct, cant find anything w/ that model number online.
    How do I get to it?
    I have heard that some timers are not manual, but on the "motherboard", could mine be one? Frig is about 3 yrs old.
    OK, will take a look at that and get back w/ you. I looked for parts on a website and didnt see any defrost timers on the parts list...thinking it's something on the motherboard.
  • 306 Answers
Start by opening the freezer door and listen for a fan blowing. As long as the compressor is running the inside fan should be running. If it is running go to next item. If it isn't running that is the problem. Need to replace the inside fan.
Next step locate the defrost timer usually in the same housing that the thermostat is. Now look for a screw driver recessed area that would allow a flat screw driver to turn or advance the timer. It only turns one way so be carefull. Advance the timer till you hear a click that should be defrost. Now wait approx. 30 minutes and see if the timer has advanced on it's own. Should be out of defrost and back in cooling cycle. let me know what you find out on these two solutions. ken
Posted on Dec 27, 2008
  • Ken Bledsoe Dec 27, 2008
    It is usually located in the center top right next to the t-stat looks like
    a plastic housing. There is a flat blade screw driver recessed area
    that advances the timer. It only turns one way so if it don't go one
    way it will go the other real easy. No the timer is automatic and they do go bad. It's like a clock and goes into defrost every 12 hours for about 30 min.
    Do you see a plastic housing where you adjust the temperature setting. And with a unit only 3 years old more then likely you are right everything is controlled by circuit board (mother board)
Coils freeze up and fridge runs all the time till I melt coils.
There might be a few causes
Door Seal might be defective causing the door not to shut tightly this causes air from the room to get into the freezer through the opening and as the air comes in contact with the evaporator coils, it freezes. Normally the defrost system removes the ice but if the seal is defective the coils freeze too quickly and the defrost system cant keep up
If the freezer evaporator coils ice over, the defrost thermostat might be defective. Several times a day the defrost heater turns on for a few minutes to melt away any frost that may have accumulated on the freezer evaporator coils. In order for this to work, the defrost thermostat has to sense that the coils are cold enough. If the coils are cold enough the defrost heater will turn on. If the thermostat is defective it may not be able to sense the temperature of the coils and then won't turn on the defrost heater. If the defrost heater doesn't turn on, the evaporator coils ice over and eventually no air will be able to travel through the coils to provide cooling to the freezer. The defrost thermostat can be checked for continuity. It should have continuity when it reaches the low temperature of its operating range.
Jun 03, 2015 | Refrigerators
Freezer keeps building up ice on the condenser i think, and after a few day sitting the bottom part of the freezer freezes and the rest dont
I'm not sure what system you have but typically there is a defrost timer on the back of the fridge. Often you can barely detect where it is, as only the stem sticks out.
What worries me is the amount of moisture in your fridge. You did not indicate how long to make the build up, check your seals carefully with a dollar bill.
Sep 02, 2013 | Refrigerators
MSD2656GEQ The coils on the freezer side ices up, then does not cool the refridgerator side
Hi, It's a common problem with no-frost refrigerators, you have a defrost problems, two scenarios. (1) hot air entering freezer/refrigerator, examples. hot summer days, regular openings, high room temperatures, hot foods and broken door gasket, leaving freezer/refrigerator doors slightly open overnight, could cause your evaporator (coils) to freeze/ice up. cases like this, unplug/disconnect your refrigerator, remove produce, clean and let it defrost, for an hour, make sure all ice melted. plug or reconnect your refrigerator let it work/ run empty for another hour, then put back your produce. sure it will work perfect for the next 3-4 days. (2) next type of defrost problem could be faulty defrost heater, defrost thermostat, you will have to open back panel on freezer side to check. check your defrost heaters, defrost thermostat and defrost timer, it's better to change defrost timer and defrost thermostat together, or change faulty ones independently. but before you change any parts, clean and defrost refrigerator first, could just be regular openings, hot days, etc. if after 3-4 days it started to ice up, then check following parts. defrost heater. defrost thermostat and defrost timer, let me know if icing occurs after 3-4 days then we can check those parts i suggested. remember to always disconnect/unplug your refrigerator, before attempting any repairs. good luck
Aug 21, 2009 | Maytag MSD2656G Side by Side Refrigerator
Our freezer keeps freezing up and it causes it to
If you tell me the model number found in locations in photo below I can help you.
Jul 13, 2009 | Refrigerators
My U-line runs too long ... it never shuts off......
What model do you have? If you have a combo then the thermastat is in the freezer compartment. Normally when I hear about the bottom freezing is that the freezer door isnt closing(sealing) all the way. If your cold air drops into the refrigerator then the thermostat doesnt recognize this. U-line refrigerators does run the compressor, This makes the compressor run more effiecient. If your defrost is giving problems and you say that you replace the switch you must mean the timer. Maybe it wasnt the timer. It could be the hotgas coil thats giving the problem. Alotof techs dont understand how U-line works. I hear about this all the time. So check the freezer door to make sure its closed and sealing. Then you need to advance it to defrost and you should hear a snap of the coil opening up the valve. Then the hotgas should go thru and you hear the crackle of frost.
Jun 27, 2009 | U-Line Icemaker
Coils In Freezer Keep Freezing
check continuity thro defrost heater and check thermal cutout in series with the defrost heater
Aug 03, 2008 | Admiral 26 cu. ft. Side-By-Side...
Magtag french door with water and ice despenser door with auto defrost keeps freezing up.
You have a defrost system problem related to the timing device, heaters, or defrost thermostat. Coils for the freezer are inside the back wall and defrosting the surface does not get ice out of coils.
it will not get any better until you have it serviced. This is not normally a project for a do-it your selfer.
May 28, 2008 | Refrigerators
Freezer/refrigerator compressor running constantly
th ebi-metal is a thermostat which shuts the defrost heater on/off, but doesnt actually put the unit into defrost. if it were bad the defrost heater would never go on resulting in massive build up of ice on back wall of freezer, and noticable refrigeration sect. cooling.. dont know how you know the compressor never shuts down, but if that the case perhaps you have a sealed system/ freon issue. try removing the back panel of freezer section and check the evaporator coil. you shuld have an even frost pattern over the entire evap coil. if theres just frost over the top 1or 2 coils, and the rest of coil is shiny aluminum , thats an indication of a sealed system issue.( 5 year part warr by manufacture) def not a do it yourself issue...but that would,, depending on extent of restriction/loss of freon,, cause freezer to freeze and defrost eratically,and the compressor would be running constantly trying to achieve a good stable temp
Apr 02, 2008 | Refrigerators
Side by Side Refridge that Is Not Freezing
chances are you have a defrost problem check the back of the freezer for ice build up if so here is your problem defrost system if not push in freezer door switch and see if you hear a fan running do this any ways if fan dont run the coils will freeze up also to defrost the easy way unplug unit until ice melts this wont cure the problem but will let it run 2-3 more day until you fix it
Dec 03, 2007 | Refrigerators
Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator Logo
420 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
