Why I need to press F7 after I turn on the computer otherwise the screen is blank? windows XP
  • 127 Answers
Reinstall your windows and check it again otherwise go to service center
Posted on Dec 27, 2008
I have a Coby Netbook Model NPBC1023XPPUR. When it starts up, the Coby introduction screen comes up and then goes to a blank black screen. What can I do to fix this?
First, Cold-Start the machine, unplug, remove battery, hold down on.off button for 30 sec., leave battery out, plug in try to boot normally, is the HDD led blinking? OR, System restore/recovery. At the Coby logo screen appears, press and hold the F7 key to start system recovery, follow instructions. OR remove HDD test, replace if necessary.
Nov 18, 2012 | Coby Computers & Internet
I have a Compac computer that has Windows XP installed (SP2), when I start up the computer, the Windows XP will not run correctly. Once it seems to be opening Windows, my computer screen just looks blank...
When you are on the blank screen try to press CTRL+ALT+DEL on your keyboard at the same time. it should bring up the task manager window. now, click on FILE > New Task Run > Type in EXPLORER.EXE and press Ok. it should show you your Taskbar, desktop wallpaper, desktop icons
Oct 01, 2010 | Computers & Internet
Ireless-B 2.4GHz Broadband ROUTER Linksys i need key
the key maybe written on the bottom of the unit otherwise you will need to loginto the router and goto the wireless section to find the key and security type
Connect with a cable to your computer, and enter the Router's default IP address, 192.168.1.1, in the Address field. Then, press Enter. A login screen will appear. (Non-Windows XP users will see a similar screen.) Leave the User name field blank. use the default password admin. Click OK to continue.
Sep 28, 2010 | Linksys WRT160N Wireless Router
Lcd screen stuck in external screen mode
How to use the function (Fn) keys on the keyboard - ThinkPad T40, T40p, T41, T41p, T42, T42p, T43, T43p
Switching the display output location.
Switch between the computer display and an external monitor. If an external monitor is attached, the computer output is displayed in the following three patterns by turns:
  • External monitor (CRT display)
  • Computer display and external monitor (LCD + CRT display)
  • Computer display (LCD)
Notes:
  • For any operating system other than Windows 2000 or Windows XP, no additional procedure is needed. Just press Fn+F7.
  • This function is not supported if different desktop images are displayed on the computer display and the external monitor (the Extend desktop function).
  • This function does not work while a DVD movie or a video clip is playing.
To enable this function in Windows 2000 and Windows XP, the following procedure is needed:
  1. When you log on to Windows 2000 and Windows XP for the first time, press Fn + F7 and select a display-switching function in the Initial setup window. Since in Windows 2000 and Windows XP multiple users can log on to a single operating system by using different user IDs, each user needs to select the function in the initial setup window when logging on for the first time.
  2. If the Fn + F7 key combination have been assigned to a presentation scheme function, start Presentation Director, and change the settings.
Feb 28, 2010 | IBM ThinkPad T41 Notebook
IBM T61 remains with dark blank screen but is on.
Connect it to another monitor,and see if it comes on. Your screen may be damaged.
Feb 22, 2010 | Lenovo ThinkPad T61 Notebook
Broken screen, external monitor via VGA won't
Press "Fn+F7" once, wait a few seconds, and press it again, to "cycle" through all the possibilities (LCD-only, VGA-only, both).
Try the monitor with some other computer (desktop or laptop) to see if the monitor works at all.
Restart your computer -- does the initial "splash" screen (showing CPU speed and RAM-test) show? Does the "Windows" screen (with the crawling worm) show on the external monitor?
Nov 16, 2009 | Lenovo 3000 N500 Notebook
I connected my laptop to my LCD TV using VGA cable. I changed the mode to VGA external monitor. Image/video appear perfectly fine during start up. but right after windows logged in for like 5 second the...
Easy way:
Press and hold Fn key, and then look at the F1-F10 keys.. Most likely it is F7, and has a picture like a computer screen.
So, press and hold Fn key, and then press F7 (or whatever key it is for your laptop). This will change your "presentation" settings, and thus switch back and forth from laptop screen, laptop screen + external screen (TV), just external screen (TV).
If this doesn't work as you expect, just try:
Instructions for Windows XP:
Open the Display Properties window by:
Start -> Run -> %windir%\system32\control.exe desk.cpl,@0,3
(this is the same window where you can change screen resolution).
There you will see two or more "screens", labeled: 1, 2, 3.
Click on "1", and you'll see:
[X] Use this device as the primary monitor
[X[ Extent Windows desktop onto this monitor
Click on "2", this is your TV.. Mark
[X] Extent Windows desktop onto this monitor
Then change the resolution to 800x600.
Click Apply
=> now your TV should start showing you a picture.
You can move your mouse between the laptop screen and the TV screen.
If you want just the TV, you can make "2" to be your primary monitor, by clicking on [X] Use this device as the primary monitor.
Nov 04, 2009 | Haier 42EP24S 42 in. EDTV-Ready Plasma...
Turning on but remains blank screen
it may happen that your extetnal (VGA Display) is enabled, this will disable your LCD Display.
just press Fn key and look function keys where monitor symbol is drawn ( that is F7 or F8 key. (turn on laptop then press Fn + F8/F7)
Aug 20, 2009 | HP Pavilion tx1000z Notebook
Unable to reinstall windows xp
try it again with the bootable floppy disk... if you have the option use fdisk /mbr and then format the computer and reinstall using the cd you have. the fdisk /mbr command will get rid of any virus residing in your master boot record.
May 24, 2009 | Microsoft Windows XP Home Edition
After booting process done. Screen goes blank and Keyboard not working only Mouse cursor is dispaly and working on the blank screen in My acer Laptop.
Try booting the system to Safe mode.
To boot to safe mode:
Restart the computer. As soon as the BIOS has finished loading, F8 key on your keyboard. When Windows Options menu appears, scroll to select the Safe mode menu item, and then press Enter.
Select "Last known good configuration" then press Enter.
If that doesn't work reboot again and keep tapping on F8 to Safe Mode and instead of selecting "last known good configuration" select "Repair Your Computer"
Or you can try this:
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
  1. Place your Windows XP set up disk in your CD drive.
  2. Turn off your computer and change your BOOT order to boot from CDs first.
  3. Turn your computer back on.
  4. Press any key on your keyboard when it asks you to.
  5. Press enter when you see a blue screen, one of the options should say, "To setup Windows XP now, press ENTER.".
  6. Press enter to start the windows set up.
  7. Accept the Licence and Agreement and confirm that the setup is searching for current versions on XP.
  8. Press "R" when the set up has found your current version of XP.
  9. Notice that the Set up is deleting all your windows xp files and replacing them. (This will not cause loss of data)
Jan 11, 2009 | Acer Aspire 5610 Notebook
Computers & Internet Logo
Alun Cox
David Payne
David Payne
