Question about Nokia 3230 Cellular Phone
Refrigerator cooling fan freez so not cooling.
Hai dear my refrigerator brand is {NATIONAL}.NR-422TE-X my problem it is my refrigerator has work 15 years.now my fredge work only 15 days excellent but after 15 days his up side cooling fan freez defrost water is not drain so drain line have totaly freez so refrigerator is not work.and i remove all items in fredge and warm water drop freezer side .so drain line open and after cleaning i was started fredge. pls solve my problem .thanks
  • 43,501 Answers
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
gf
Posted on Sep 29, 2010
Cools unevenly, bottom is freezing and top is just cool
what do you have?brand name and full model number off of machine,i've seen if the fan isn't working this can happen,no fan to blow air heat rises so the top is warmer than the bottom but i don't know what you have?
Feb 05, 2018 | Refrigerators
I have national Refrigerator NR 422-TE-G 2 doors which I bought from Saudi Arabia. This worked very efficiently for may years but now it is has defrost problem. Ice goest filled in freezer due to which fan...
Remove power and defrost. Check heater element behind panels in back of freezer. With ohm meter should read 20 ohms or less. You could remove it and bring it to a local repair shop and have them test it and if required order you a new one. If this does not work it may be the control board
Oct 21, 2013 | Refrigerators
The refrigerator is national "nr-302
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
First I would check cold control. Thats where you turn it off, if your temp is not warm. it can
be defective and not shutting off. If your temp is warm proceed with the following.
I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if FREEZER CONTROL is turned WARMER WHICH MAKES THE REF COLDER AND VICE-VERSA. SEE?
The ref. temp should be about 33-35
The Freezer temp should be 0 to 10 Any thing below these temps is overkill and a waste of elect
The higher the number you turn it up to is the coldest
But is probably a common defrost problem The ice build up
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
Make sure back cover is on the fridge. Some take them off and throw them away.
make one out of cardboard if its gone, using the holes of the old one.
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
If you need more help go here:
http://www.applianceaid.com/procedures.html
MORE
TIPS AND TRICKS:
STOP PAYING FOR EXPENSIVE WATER FILTERS FOR YOUR REF. DO THIS====
http://www.fixya.com/support/r9962087-stop_paying_high_price_refrigerator
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME AND GIVE ME YOUR TESTIMONIAL IF POSSIBLE, IF THIS WAS HELPFUL
ITWILL BE MUCH APPRECIATED.
Sep 16, 2011 | Refrigerators
I have a national NR-302TE-X fridge for the past 4 months the fan in the freezer gets frozen and stops due to this the fridge does not cool and a lot of water is defrosed and there is water inside the...
dear
there is a temp, sensor in side the fridge that turn on a heater rod and stops compressor that melts the ice at back of freezer and fan.
or toy can open rear panel in side freezer and pure hot water (not boiling ) on frozen ice on condenser coils, this will help you for on week and then you have to repeat it again
you need a good tech person to solve that problem
hope toy under stand
?Adnan : eng-adnanpaul@hotmail.com
Nov 13, 2010 | Refrigerators
I have frost free hotpoint future,the fridge seems to be working but the freezer isnt at the minute, the food is not freezing and the fan does not seem to be working! it has no suction on doors either, my...
Defrost timer/control is sticking...
heatman101.
Oct 15, 2010 | Refrigerators
@15 yr old GE top freezer fridge. Top freezer
check to see if an internal fan is fitted. This may have stopped/ burnt out. if fan is running try 24 hr defrost.
May 15, 2010 | GE GTS22KBP Top Freezer Refrigerator
Refrigerator not cooling / fan not turning
Yes , replace the fan motor . Part number 833697 . Also make sure the coils are clean of dust , lint etc. Be sure to reinstall the back panel , after replaceing the motor , as this motor cools the coils and the compressor . ( only 3 screws hold the fan motor on , easily repaired .)
Sep 15, 2009 | KitchenAid Refrigerators
Refrig cooling
Sounds like the evaporator fan is not working. Check to see if you can hear the fan running in the freezer. If not running, try removing the panel in the back of the inside freezer and manually spin the fan blade . This sometimes works.
Jul 03, 2009 | Refrigerators
DEFROST TIMER FOR NATIONAL REFRIGERATOR NR-302 TE-G
the defrost timer have a motor inside it......it act as a watch, in every 8 hrs it defrost if the problem lies in it than you need to replace it as because it is not repareable
Jun 16, 2009 | Refrigerators
Nokia 3230 Cellular Phone Logo
273 people viewed this question
Top Nokia Cell Phones Experts
270rexton
270rexton
