Question about Nikon D40 Digital Camera with G-II 18-55mm Lens
Nikon D40 displays: FILE DOES NOT CONTAIN IMAGE DATA
Camera displays this message sometimes after trying to take a picture, and fails to capture an image.
Also camera will only take picture if focussing is switched to manual.
Is this a common problem that can be solved, or is this a terminal malfunction?
Thanks for any ideas on this!
  • Anonymous Jan 12, 2009
    also lcd screen switches between color and negitave type picture
  • Anonymous May 21, 2009
    hi, my friend was taking photos then battery ran out and half of the photos ' do not contain image data', both when i viewed them in the camera or on my computer.
    thanks
  • 95 Answers
Check the compatibility of your lens and camera.
i think your lens is something wrong. there is a slide chips under it that might slept . go to expert technician to fix it.
Posted on Jan 22, 2009
Hi, I have the Nikon Coolpix 3000 and I've recently had some problems. I have only had this camera since December; Several times I have tried to upload pictures and "this file contains no image...
You can try to reformat the sd card. Sometimes cards will contain data that disrupts the reading process.
Also, sometimes if you edit images on the pc, such as rotating them in Window's image viewer, it will rewrite the image as a jpeg that is unrecognized in the camera.
Lastly, check to see if the photos are being saved to the sd card or the camera.
Mar 10, 2011 | Nikon Coolpix S3000 Digital Camera
DISK SAYS "FILE DOES NOT CONTAIN IMAGE DATA" BUT
hi there,
this case will happen if you still have pictures on memory card and it hasn`t been formatted using the Nikon system
the solution is backup your files on memory card to PC/laptop, then reformat the memory card using Nikon menu
hope this will help you
Dec 13, 2010 | Nikon D60 Digital Camera
FOLDER CONTAINS NO IMAGES.
Please follow the instruction below and let me know what is happening.
1. format the new card.( Can't format is from any virus
infected PC ).
2. Insert the card then reset your camera setting.
3. select your mamory card default for save the
photographs.
4. Before start photography confirm that your battery
is fully charged.
Thnaks & please give me feedback about your camera.
Feb 03, 2010 | Nikon D40 Digital Camera with G-II 18-55mm...
Nikon d40 motnior blank while taking picture.
That's entirely correct. Live view cannot work on SLR's whilst the photo is being taken due to the requirement for the mirror and live view sensor to flip out of the way during image capture.
Live view on SLR cameras is a misleading description, it's really a live preview instead.
Dec 11, 2009 | Nikon D40 Digital Camera
Nikon Coolpix S550 memory card problems
Your camera uses a different filing system than the other camera...they are not interchangeable.
Sep 28, 2009 | Nikon Coolpix S550 10 Megapixel Digital...
"FILE CONTAINS NO IMAGE DATA"
It may be of your new SD card. Try with another SD card. It may not show you File contains No Image Data. -Lalith
Oct 23, 2008 | Nikon Coolpix 4200 Digital Camera
NEF Image will not open - Macintosh
RAW NEF images from Nikon cameras are proprietary formatted raw data directly from the cameras's sensor. If the images are improperly transferred to the computer they will not be able to be opened and will give an "Unsupported File Format" warning. Macintosh OS X has an "Image Capture" application (found in: Hard Drive/Applications/)that can be used to transfer images. If "Image Capture" is used NEF files will be corrupted and will not be able to be read. Only Nikon View, or manually dragging images from the mounted card, should be used to transfer NEF's. To disable "Image Capture": Double-click to open the hard drive and then the "Applications" folder Double-click "Image Capture" From the "Image Capture" menu choose "Preferences..." In the "When a camera is connected" pop-up choose "No Application" Close the Preferences window and Quit Image Capture After disabling Image Capture, it will not launch when the camera is connected and you can use Nikon View to properly transfer NEF images.
Aug 30, 2005 | Nikon Coolpix 5000 Digital Camera
Aug 30, 2005 | Nikon D70 Digital Camera with 18-50mm Lens
Can't place camera image file into another document
Nikon digital cameras record images in the "EXIF" (Exchangeable Image File Format) file type. Even though the file name (when shooting compressed files) ends in ".jpg" it is not a regular JPEG image. This format includes not only the JPEG picture data but also the shooting information (f/stop, shutter speed, lens, etc.) and other text-based data. Writing this type of information is part of the global "DCF" standard for images from digital cameras. Some applications do not properly read this data and will display various errors and warning when opening these files. The only way to use an image in one of these programs is to open it in an image-editing program and save the file to a new file name. This changes the file from an EXIF image and saves it into whatever format is chosen, stripping out all of the extra data. Contact the developer of the program which does not properly open EXIF files for possible updates.
Aug 29, 2005 | Nikon Coolpix 5700 Digital Camera
Nikon D40 Digital Camera with G-II 18-55mm Lens Logo
696 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
