Question about HP (F2013A) Plug-In Module (Laptop) Floppy Drive
Whitch driver do I need to make the HP F2013A floppy drive run on a parallell port on Win XP ??
  • Anonymous May 11, 2009
    Did you solve it?
SOURCE: Canon Printer LBP-800 with Win XP
where can i download Canon LBP800 driver?
Posted on Apr 30, 2008
komguy
  • 2306 Answers
SOURCE: HP Laser 4L driver for USB port
Not all USB adapters are the same, you need the one that is made for your printer, I would try a different adapter before going too deep, because when you plug it in your computer should see it even without drivers.
Posted on Jul 21, 2009
  • 218 Answers
SOURCE: ms 7142 Msi board, cant install xp with sata hdd
I think this is your board, K8MM-V. The following is the link to all drivers and info regarding said mobo:
http://www.msi.com/index.php?func=downloaddetail&type=driver&maincat_no=1&prod_no=173
Posted on Dec 30, 2009
  • 226 Answers
SOURCE: Compaq External Floppy Drive
External, parallel port based FDD's are just too darn old and uncommon, and there's no auto-detecting on these things. These things also come with their own power supplies - so make sure the power supply is plugged in or else it ain't gonna get no power - and then you'll need the drivers (which I doubt will be XP compatible).
A USB based external FDD would be a much easier solution!
Posted on Mar 12, 2010
  • 121 Answers
SOURCE: I have a TSP700 parallel port label printer and
you might need to fiddle around with the usb virtual printer port configuration , when you add printer. when adding a printer, uncheck the install automatically tick box, then on the NEXT page click on the drop down list of "use the following port" and try virtual port. it might work.
Posted on Mar 21, 2010
Testimonial: "Didn't work, but thanks. No option to config Virtual USB port"
Instal xp on panasoc cf 71
had same problem with loading win xp proff on cf 74 toughbook mk1.
soution for me was downloading sata hdd controller from panasonic toughbook support site, loading the driver onto floppy drive, using usb floppy with driver ready to use, loading win xp profesional and on first loading win screen pressing f6 when prompted at beginning of win intallation, when on screen instructions to load sata driver appeared, i followed on screen instructions and loaded 3rd option from floppy sata drive mobile driver, left usb installed untill xp loaded and running, do not remove usb floppy untill win loaded, i really hope this helps you
Mar 25, 2013 | Panasonic Toughbook CF-27 Notebook
Need win xp driver for mf355h-332mr 3.5" floppy
Take a look at :
http://www.driverguide.com/
joining is free and they probably have what you are looking for.
Sep 10, 2011 | Mitsubishi 1.44M 3.5 34Pin Floppy Drive...
Will a superdiak model work on win xp
I believe it's a usb connection? It should work on xp. The only problem i can think of is the driver, which should be available on their website. Is it an Imation brand?
Try plugging into windows xp and if it will ask for a driver then head over to manufacturer's site and download the appropriate driver.
for imation external floppy drivers, click here.
hope this helps.
May 03, 2011 | Imation (01946) External Floppy Drive
Unable to get parallel port floppy drive working on a compaq presario 2108us -- parallel port drive is mf335h-333mc
After you have hooked the drive to your computer you need to go to the manufacturers website and download a driver to make it recognizable to your computer.
Mar 25, 2011 | Mitsubishi 1.44M 3.5 34Pin Floppy Drive...
What hardware and or software would be required to transfer data from a Commodore 64 5 1/25 floppy disk to a Pc or Mac?
find a cheap floppy disc reader....most of this old data will not be readable by windows xp and higher (you will need probably win 95 or 98)
Mar 21, 2010 | HHP ImageTeam 4710 Barcode Scanner
HP2100 PRINTER NEEDS USB PORT ON WIN XP LAPTOP.
You have to purchase a Parallel to USB printer cable.
Jan 03, 2009 | HP LaserJet 2100 Printer
UMAX Astra 1220P Scanner worcks not with ( or in) Windows XP Home Edition pecnikfranc@yahoo.com . I need a driver for umax astra 1220p ( work under xp o/s). Thanks for all help.
I believe that the HP 3200C is a very similar scanner, and the
HP parallel driver will work, try the following links:
http://www.softwarepatch.com/utilities/hp-3200c.html
http://h10025.www1.hp.com/ewfrf/wc/genericSoftwareDownloadIndex?cc=us&dlc=en&lc=en&softwareitem=sj-1436-3&jumpid=reg_R1002_USEN
I think you will find that the old UMAX scanner is extremely
slow over the parallel port, and the image quality is nowhere
nearly as good as modern USB-2 scanners.
USB-2 is orders of magnitude faster than the parallel port,
and a really good scanner costs around $60 these days.
You may want to try the Canon LiDE 80: It scans pictures
and film, it's good, it's fast, it's dirt cheap and I love it.
Martin
Jun 14, 2008 | Umax Astra 1220P Flatbed Scanner
Feb 12, 2008 | Compaq (190563-001) External Floppy Drive
HP DRIVERLESS USB FLOPPY DRIVE F5101B
Update your laptop chipset driver and check for broken usb ports.
Dec 11, 2007 | HP (F5101B) External Floppy Drive
Windows xp with not recongise HP Laserjet 6p when plugged into a usb port
To my knowledge, the 6P isn't a USB printer, it's parallel port only. Are you using a USB / parallel port adapter? If so, I believe that's the root of your problems - the adapter.
Try hooking it directly to the parallel port (shut the PC and printer down before doing so).
Upon restart, Windows will detect it, and may or may not "know" the model, so you may have to choose it from the dropdown boxes.
If it works when directly connected, you will need to either locate drivers for the adapter (if any), or manually configure it under the printer port properties.
If you need more help, let me know. These are great little printers - once you get them to work!
Dec 03, 2007 | HP LaserJet 6p Printer
HP (F2013A) Plug-In Module (Laptop) Floppy Drive Logo
112 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
