Question about Zio Corporation CameraMate RealTime (cm-50000) Video Capture
Video output from VHS recorder
I cannot get an output from my PAL VHS recorder via a scart to composite cable plugged in to the cameramate unit. I have checked with scart from VCR to scart in to TV and this is fine. But output from scart from VCR to composite video (yellow lead) cannot be seen on TV. I have tried another VCR but still no joy. Both were Panasonic VCRs. The cables were all new and top quality. Any ideas? Should I try a scart to S-video lead connection between VCR and Cameramate instead? Thanks Frustrated.
    Problem Solver:
  • 4 Answers
Does your television have multiple scart connectors? Sometimes some models have only 1 connector that will accept RGB signals... Another thing you can check are VCR settings - scart component video output is not "official" and hence you might need to look at some of the setting if you need to enable it. Another possibility is that your scart cable may not have your rgb signals connected (based on wikipedia reference: "not all SCART cables make use of all the pins, often leaving out RGB signals. In many cases there is also no way to see which type of signal that is currently displayed on the TV set."
Posted on May 12, 2007
How to connect Sky digibox & DVD recorder to Samsung UE46ES6300 TV
Buy 2 hdmi leads and use one to connect sky TV decoder to the hdmi 1 socket on the back of the TV and if your DVd recorder has an hdmi socket attach it to hdmi 2 or leave it on the scart socket
as you don't name your dvd recorder the connections available are unknown
hdmi is the best followed by component which requires a 3 cable lead 3 video (video is red green blue plugs ) audio is red and white which is a 2 wire lead which all are needed to get video and audio to your TV
scart is the lowest quality along with composite video
Jul 04, 2017 | Televison & Video
Problems with Philips vhs recorder/dvd player
You only need coaxial cable to pick up TV stations broadcast via an aerial. If your TV has sockets to connect via HDMI or SCART, then any players can be connected via them. So if the adapter box picks up TV signals, you connect the main aerial cable to that and it should have a coaxial out socket, that should be connected to the aerial in of your TV. If you are recording to an analogue video from the adapter box, then that will need to be connected via a scart socket or other connection.
Nov 24, 2017 | Philips Dvd Player Vhs Video Tape Player...
Having trouble hooking up vcr
I've never seen a VCR use anything other than Composite, S-video or RF analog outputs. That's because VHS uses the NTSC or PAL analog video standards. (In the US, it is NTSC; in Europe PAL is the old standard.)
To use the Composite output, get a triple RCA cable (red, white and yellow connectors). Connect one end of the cable to Video Out (yellow), Audio Out right (red) and Audio Out (white) on the VCR. The other end of the cable goes to the corresponding Composite Video In jack and the adjacent Audio In jacks on the TV. If you are using S-video, (both units must have S-video jacks), the S-video cable replaces the Composite section of the triple cable, so you only need an audio patch cable (two RCA plugs on each end). Be sure to use the audio input corresponding to the S-video input. Note: S-video is generally better quality than composite, although HD digital is still superior.
If you wish to record from the TV, the TV must have a composite video or S-video output. This is not very common. If you wish to record programs from an RF source (cable or antenna), see the next paragraph.
In the days before digital, a typical connection scheme was to run the cable or antenna RF source to the ANT IN coax connector on the VCR, then run a short coax cable from ANT OUT to ANT IN on the back of the TV. This may not work with a digital source. Pre-HD VCR tuners would not be HD compatible, and may even filter out the digital signal in bypass mode (VCR off). You would need an HD to analog converter box at the VCR input to retain this setup. I have no information on your TV's support for NTSC video through the tuner (especially since you did not mention the model : /).
Jun 21, 2011 | LG Televison & Video
Im trying to connect my unit to my tv to record shows and i having trouble doing so please help i am hooking it up wrong
For OTA or CATV signals, you need to daisy chain the coax from the source (antenna for OTA) to the coax input on DVD recorder and then the coax out to the coax input of the TV. If you have a set-top cable box with an incoming CATV signal, it should be connected between the DVD recorder and the TV.
The unit can tune in and record 480i (SD) ATSC (OTA digital), NTSC (OTA analog), analog CATV and digital CATV channels.
A satellite receiver or a non-CATV cable box should get the incoming signal first and then have their composite video output (A/V) connected to the DVD recorder composite video input and then their coax (RF) output (if present) gets connected to the TV. For these, you would record from the IN1 or IN2 (press Select Input) instead of selecting a channel. Then connect the composite video out on the recorder to the TV's composite video in.
Digital signals are either enough to tune in or give no signal. So check that your antenna is correctly oriented for OTA.
Separately, you can connect the video signal when playing DVDs via composite (good signal) out and component out (better signal) out to the TV's matching input. For the component video, the sound is carried on a separate cable. Then set the TV to the input source.
In the case of wanting to watch a VHS tape while taping to a DVD, do not use the Component video source, set the TV to Input 1 (composite).
I hope this helps.
(you can get a copy of the manual here: http://tv.manualsonline.com/manuals/mfg/panasonic/dmrez47v_dmrez475v.html )
Nov 25, 2010 | Panasonic DMR-EZ47V DVD Recorder/VCR
Can I go from VGA to SVGA?
If the question is can I convert my composite video output to a super video input then the answer is NO,
The composite is coaxial (2 wires) the S-Video uses 4pins and there is no S-Video output on a Presario 1200 laptop.
You can however use a Multi-AV SCART adaptors with Input/Output signal switch where you plug in the composite video output into the top video and 3.5 mm jack stereo audio into the mono audio connections on top.( via a stereo to mono cable)
http://upload.wikimedia.org/wikipedia/en/thumb/a/a7/Multiconnector-scart-chti.jpg/200px-Multiconnector-scart-chti.jpg
Hope this is the answer you are looking for !
Sep 27, 2009 | Compaq Presario 1200XL103 (155726-163) PC...
DV220MW9 DVD/VCR: won't record video on VHS
your cable tv connect into dvd/vcr,video/audio out connect to av in your tv,solved
Jul 06, 2009 | Philips Magnavox DVD/VCR Dual Player
Has philips VR765 composite video out on scart connector?
you will need to get this to make the scart a composite connection http://www.svideo.com/scart.html
Jan 05, 2009 | Philips VR750 VHS VCR
No color from VHS on DVD/VHS player
There may be an input selection between Composite and S-Video that needs to be toggled in your Hauppauge software.
Your Hauppauge card may also be in the wrong signal format mode (NTSC or PAL). Your source device and your Hauppauge card need to be in the same mode (both NTSC or both PAL) for the capture to work properly.
If your NV-VP33 is a SCART output, then you may need to check your SCART adapter and your device as not all devices output both S-Video (Y/C - two signals) and Composite (CVBS - one signal) type signals.
If your SCART adapter has both Composite and S-Video outputs, try the other one.
And finally... if you're playing an NTSC tape/DVD in a PAL player, it doesn't mean the output is true NTSC 3.58. Most times it's NTSC 4.43 which is OK for TVs, but NOT okay for video capture devices. Video capture devices need true NTSC 3.58 to sync the color carrier properly.
Apr 29, 2008 | Hauppauge WinTV HVR-1600 - ATSC HDTV...
PAL to NTSC conversion
This is not a converting unit, it will play the format of the tape inside. To convert the signal you need one of the following:
1) A converting VHS player; they are fairly expensive.
2) A separate video converter (hardware); they run for about $200-$500; just put this between your VCR and the TV.
3) Capture the PAL on your computer using a software like Movie Maker via a Firewire cable. Than convert it to NTSC on your machine using software like Nero... do a search on Google for converting software. Or just watch it on our computer in PAL format, most computers do that... For this step I use a separate camcoder that has a passthrough feature. The VCR connects to it and the camcorder connects to the computer via Firewire.
4) send the PAL tape to a specialized shop for conversion. They normally charge $30-$40 for a regular 2h VHS tape.
Jan 20, 2008 | Philips DVDR3435V/37 DVD Recorder/VCR
Trying to import analogue video from VHS
I _assume_ you're feeding PAL video into the MV500i... one of the simplest ways to lose color information is to feed an NTSC (or PAL60) source to a standard PAL display.
Another possibility is that you're losing the chroma signal. I believe this camcorder has a composite (CVBS) analog input. If you're tapping off a SCART connector, make sure you use a SCART to composite cable, not SCART to Y/C (luminance/chroma). Are you using the same cabling with the camcorder as with the TV?
Jan 19, 2008 | Canon MV500i Mini DV Digital Camcorder
Zio Corporation CameraMate RealTime (cm-50000) Video Capture Logo
234 people viewed this question
Top Zio Televison & Video Experts
Jason
Richard Schurman
Richard Schurman
Level 1 Expert
Damen Wong
Damen Wong
Are you a Zio Televison and Video Expert? Answer questions, earn points and help others
