Question about Hotpoint Aquarius WF000 Front Load Washer
Pump filter blocked
Wf320 hotpoint washing machine pump filter blocked but cant get it to come out
  • mike3234 Dec 27, 2008
    its ok prob solved took apart housing and emptied it that way only took an hour you will require torx bit to remove though
Actually it was quite easy, unplug from mains lie it down on its back and unscrew the 4 screws around the filter/pump it will then come out enough for you access it easier, unplug the connection which has 2 black wires from the pump and unscrew the 3 torx screws which will then separate the pump from the filter and anything stuck inside will fall out before reassembly make sure the impeller is not damaged on the pump if it is you may have to replace the pump I'm told is quite cheap to replace, reassemble and away you go. Whole job only took me a couple of hours and saved me a fortune.
Posted on Dec 28, 2008
Fault 05 is showing on my hotpoint washing machine,what does this mean
Hotpoint makes a massive range of washing machines and i noticed you didn't include a model number, but nevertheless Google says it's a blocked pump/filter.... i guess you tried Google too?
Jan 01, 2018 | Hotpoint Washing Machines
Wf250 will only allow a very small amount of water in and then shuts off.
Check the lint screen and water outflow from inside the tub cylinder... socks are often lodged inside the tube. Check the filter screen on the inlet hose at the faucet (tap).
May 29, 2015 | Hotpoint Repair Pcb / Module Wf240 Wf250...
I need to get to filter on my wf320 hotpoint washing machine
Disconnect power from circuit breaker or unplug power cord before starting. The filter in the hotpoint aquarius 1200 is in the front bottom side, hidden by a trim panel. Remove the trim panel at the bottom of the front side and find the access at the right hand side. Keep a large flat container ready to collect water from drain filter.
Pl say so if helped
Mar 16, 2013 | Hotpoint Washing Machines
I have fault 5 on my hotpoint ultima washing machine
A-5: Circulation pump blocked or faulty
  • Check filters
  • Check circulation pump motor for blockages
  • Check main circulation pump
Apr 11, 2012 | Hotpoint Washing Machines
Water won't drain away from the drum. I think I may have a blocked filter. How do I access to clean the filter on a Hotpoint WT960G washing machine please. Many thanks.
Most Hotpoint washers do not have a customer accessable drain cleanout. Also, it may be a full or partial pump failure. Replacing the pump assembly will improve washer performance.
Replacement pump is about 20 Pounds delivered, and can be self installed quite easily.
Link to video
May 03, 2011 | Hotpoint Washing Machines
Please help the washer fills up and turns the
Seems like a blockage or maybe pump worn out. Fill machine and take grey outlet pipe on rear of machine. Place this pipe as low as possible into a bowl. If water flows free from this pipe then your pipes are not blocked and most likely you will need to change your pump. Before you try this just put machine onto spin and ensure this will work when machine is almost empty
Mar 12, 2010 | Hotpoint Aquarius WF220 Front Load Washer
Hotpoint WF320 wont spin or empty
sounds like something is jamming the pump, strip pump down and clean
May 26, 2009 | Hotpoint Aquarius WF220 Front Load Washer
REMOVAL OF BLOCKED PUMP ON WASHING MACHINE
Remove the lower portion of the front panel. 3 screws.
Twist the pump filter and pull to remove it.
Mar 17, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Why do the lights just keep flashing?
Try unplugging it and rubbing the plug on a soft dry cloth, static electricity can cause problems.
Try opening and closing door acouple of times, if still no luck , suggest you call engineer
Dec 09, 2008 | Hotpoint Aquarius WD63 Front Load...
Hotpoint Aquarius WF000 Front Load Washer Logo
531 people viewed this question
Top Hotpoint Washing Machines Experts
vince
gbob59
Eric Taylor
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
