Question about Logitech Z-2200 Computer Speakers
Speaker problem I've had these Logitech z-2200 speakers for 3 years now and the sub is starting to pulse and it seems to be getting worse every time I turn it on. Is there any way I can fix this?
  • liberties02 Dec 22, 2008
    I have the same problem, it's driving me nuts. The bass is constantly irritated, like a thunderstorm is playing in the background. It continues if you pull the line in plug from the back of the computer.
    Brigadier General:
  • 6,966 Answers
Hi, can you please elaborate on "sub is starting to pulse". Assuming initially that by pulse you mean that the sub produces a thumping sound when turned on, then: in some cases, this would be even considered normal; if you have not experienced this before except lately, then it is possible that the amplifier powering the sub is in question. Chances are that you have a leaky/defective capacitor in that section. The basic repair would involve remove/check/replace (if needed) but if you are not comfortable working with a soldering iron and a VOM, it would probably be best to have an electronics tech work on it. Hope this works out for you. Good luck.
Posted on Apr 22, 2007
I have a logitech Z-640 speaker system connected to a Panasonic Plasma TV and the sub woffer has no volume coming from the large speaker.All the other speakers are OK It seems there is no power going
Hi Ray,
if there is no power going thru than,might probably be your fuse in the subwoofer that's blown.What you have to do is remove the wire mesh from the front using a terminal flat screw driver. You will notice that there are screws around the speakers,remove them inorder to take the speakers out.Once you've done that take out the speakers gently so that you dont disconnect any wires inside.Turn the peakers over and you will see a fuse attached to the speaker.Try replacing the fuse with the asme ratings.
Please refer to the image below on what the back of the peaker looks like.
All the best and Good Luck.
G..
Nov 10, 2011 | Logitech Z-640 Computer Speakers
Logitech Z5500 5.1 speaker system Hi, Any suggestions on how to troubleshoot this problem? there is no sound coming from the subwoofer or the speakers, but when I connect my mp3 player to the pod...
Try pulling the power from the unit for a few minutes, the reconnect. Make sure you've got the surround settings correct. If that doesn't do it, you've likely popped the amp or the amp's power supply in the sub box.
Jun 16, 2011 | Logitech Z-5500 Computer Speakers
My Logitech Z523 Speakers make a loud humming noise when plugged into my PC. When i plug it into my phone or laptop there is no humming noise. Sometimes there is a fuzzy crackling sound when it is not...
Mine did the same thing then I found the solution by accident. After reading a post about moving the sub to different positions and making sure connections were tight to the sub , I loosened the right speaker connection screws to the sub and noticed the humming stopped completely . I know it sounds crazy but it worked for me.
Nov 30, 2010 | Logitech Z523 2 Speakers
I have problems with my logitech z 2200 i have static on the speaker i unluged and even switched the plugs which ever speaker is pluged into the slot will have static i got this system as a gift plz help...
Read this here -
http://forums.logitech.com/t5/2-1-2-0-Speaker-Systems/Z-2200-Touching-the-remote-volume-knob-results-in-a-very-loud/m-p/369699;jsessionid=4ED1A1BC248CB27152E9281D845FAF4A
Hi, the crackling is mostly a result from dust and debris building up on the contacts of the volume knob over the years.
You could try taking some compressed air to the space between the knob and the pod.
and
Sometimes with the power off rotating the knobs from end to end will also help.
m/E
Sep 14, 2009 | Logitech Z-2200 Computer Speakers
Z-2200, Left Channel Stopped Working
The exact same thing has happened to me,, the left channel just stopped working. I am in process of changing the audio amplifier chip for the left channel a TDA 7296. Its a fairly inexpensive gamble at less then 5 bucks for the chip. It is fairly complicated amplifier chip with a built in mute, standby and thermal shutdown protection features in the chip so it is possible any of that has gone haywire the chip would not output properly if so. Also found on the same channel a small choke a three turn coil that was dislodged when they added silicon to the board and it pulled the choke lead right off the board. I would presume this alone would not be the problem but could have lead to the amplifier going bad if it truly is.
Evertyhing else on the main board seems to test well and nothing is standing out as a problem. Rollin the dice. Waiting for a chip in the mail,,, time will tell.
Jan 20, 2009 | Logitech Z-2200 Computer Speakers
Logitech x-530 rear speakers and Center speaker not working
you have to go to your audio output setup (try to look for an audio-related icon on your taskbar - next to time display)
setup your audio output for 6 channel or 5.1channel output (depending on software)
follow on-screen description of where to plug in your speaker jacks - green, peach and black.
enjoy...
Dec 02, 2008 | Logitech X-530 Computer Speakers
Logitech z-5500
Try to click the EFFECT BUTTON a few times to change the effect settings (see also in display) from e.g. Stereo (which uses only two front speakers) to other settings (for which some will use the other (rear/center/sub)speakers as well). Success,
Jun 20, 2008 | Logitech Z-5500 Computer Speakers
Sub Woofer Not Working
Make sure it is plugged in and the volume is up. Also make sure you don't have your sound muted. Do any sounds come out of your computer? Go to the control panel and click sounds and do a test.
Dec 25, 2007 | Logitech Z-2300 Computer Speakers
Speakers not working correctly
pls swap the spk pin in to your sound card jack socket . bye
Sep 22, 2007 | Logitech X-530 Computer Speakers
R Front Speaker Doesn't Work
Dude Here is a link that gives you a step by step testing procedure. Sounds like a defect in that particular speaker, you will know with this test from logitech. http://logitech-en-amr.custhelp.com/cgi-bin/logitech_en_amr.cfg/php/enduser/std_adp.php?p_faqid=2913&p_created=1125714076
Sep 15, 2007 | Logitech X-530 Computer Speakers
Logitech Z-2200 Computer Speakers Logo
241 people viewed this question
Top Logitech Audio Players & Recorders Experts
Michial Gueffroy
Jerry Umali
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
