Question about Lenovo ThinkPad R60 with Wireless Wide Area Network (ThinkPad R60_WWAN_Standard_123N)
Can't connect to internet with lenovo thinkpad X61
I don't know where to put in the wireless code under the lenovo wireless settings to log on
  • mandshall1 Mar 13, 2009
    Borrowed this for overnight and can't see how to turn on the wireless connection?
    Sergeant:
  • 366 Answers
Use FN + F5 to start Think pad Wlan Manager
Use it to manager your Wlan settings
Posted on Dec 27, 2008
Make wireless printer discoverable
check the printer directions..some printers have to be set discover able inorder for your Lenovo device to see it. Some printers and devices time out after 3 min and therefore have to be set in discoverable mode again
Feb 14, 2018 | Lenovo Computers & Internet
Key on IMB Lenovo ThinkPad X61 came off.
If the small plastic hinges are still attached to the keyboard, then place the key over these hinges, align it with the others keys and press down on the key until it click onto these hinges.
Aug 23, 2012 | IBM Lenovo ThinkPad X61 Notebook
Thinkpad Lenovo - suddenly no internet
How do you connect to the internet? Are you going through a wireless router or using a usb device provided by a cellphone provider?
Maybe you need to check your settings on the broadband service since you mentioned it. You could also reinstalled the broadband application if it is not solved.
May 14, 2012 | Computers & Internet
I just replaced the screen on Thinkpad X61 and now my wireless is not working. Did I damage the wireless antenna?
This is Lenovo Support, and the manuals download page for the ThinkPad X61 Notebook PC,
http://www-307.ibm.com/pc/support/site.wss/product.do?subcategoryind=0&familyind=374625&brandind=10&doccategoryind=0&modelind=0&doctypeind=8&validate=true&partnumberind=0&sitestyle=lenovo&template=%2Fproductpage%2Flandingpages%2FproductPageLandingPage.vm&operatingsystemind=49979&machineind=0
If you do not have the HMM, (Hardware Maintenance Manual. Or also stated as a Service Manual),
click on -
Hardware Maintenance Manual - ThinkPad X60, X60s, X61, X61s
On the next page under the heading File link, click on the blue -
42x3550_04.pdf
It may take up to 30 seconds before you will see the first page, and additional time may be needed to fully download the file. (Suggest you download the file all the way before looking through it)
(Took 35 seconds to download the file just now. No additional time needed. Using Adobe Reader 10, {X}, and a medium speed DSL connection)
Page 84 through 86.
(The page number in the page number box at the top of the PDF file. {Right of Down Arrow}
Not the actual page number itself)
1) Did you make sure the two antenna leads are connected to the Wireless LAN PCI Express Mini card?
2) Are the leads connected properly to the card?
Card in position, and front of laptop facing you the Gray lead goes on the Left side (Connector), and the Black lead to the Right side (Connector)
Page 112 through 114.
Did you reroute the antenna cables (Leads) properly, on each side of the LCD screen's metal frame?
The cables can be damaged by stretching, or becoming pinched. You may not see the damage readily.
The outside sheath of the cable can hide internal damage to the wire within the cable.
Test each antenna cable with a multimeter set to OHM's. (Continuity check)
Replay back in a Comment.
Regards,
joecoolvette
May 31, 2011 | Computers & Internet
Why wireless and Lan are not working in my lenovo r60.it shows connected but it willnot access internet
DNS service is not working.
Reinstall network card by removing the hardware from device manager and reboot. Reinstall network connection set up
Aug 24, 2010 | Lenovo ThinkPad R60 with Wireless Wide...
My lenovo thinkpad x61 tablet does not turn on now. Replaced the battery 2 days ago, was working fine until today.
confirm that the Power adapter is ok if the A/C indicator comes ON on the LCD on the laptop. If the A/c indicator is off replace the the power pack. Else the board may be bad, replace the board.
Aug 12, 2010 | Lenovo ThinkPad X61 Tablet PC
Problem in connecting wireless internet
Some general guidelines to connecting to a wireless network..
Make sure you have at least 3 bars of signal
Make sure you know the password ( if there is one)
Try to connect to the network via ethernet cable to verify the wireless router is actually working..
Oct 28, 2009 | IBM Lenovo ThinkPad X61 Notebook
What's needed to get set up for Skype if I have a ThinkPad X61?
no you don,t need external speakers and any usb web cam will do some cheap ones out there if you look around
May 21, 2009 | IBM Lenovo ThinkPad X61 Notebook
Spacebar on IBM Lenovo ThinkPad X61 came off.
I took mine off to clean under it and had a similar problem. After a bit of struggling I figured it out. I will try to explain it as best as I can, but forgive the non-technical language:
There are two gray plastic pieces on the space bar that must be that must be latched to the two white plastic pieces on the computer. The gray pieces pop off the space bar easily. Take them and put them on the white pieces on the computer so that the white arms lay across (and snap into) the top and bottom of the gray piece. The middle of the gray piece will sit in between the two arms that are not "holding" the gray piece. Then take the space bar and put the metal part into the hole on one side (outside of the plastic pieces) and then push it over so you can put the opposite metal part into the other side. Then push the space bar straight down and it will snap into place.
Apr 12, 2009 | IBM Lenovo ThinkPad T61 Notebook
Lenovo ThinkPad R60 with Wireless Wide Area Network (ThinkPad R60_WWAN_Standard_123N) Logo
813 people viewed this question
Top Lenovo Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
