Question about Sony BRAVIA XBR KDL-V26XBR1 26 in. LCD HDTV
Sony bravia won''t play PS3
USING HDMI CABLE TO HOOK UP PS3, BUT TV JUST SAYS INVALID FORMAT. WHAT AM I MISSING? I have the same. The strange thing is that i bought the sony 2 weeks ago it worked perfectly for 1,5 week, than somebody else started it and now its only says 'invalid format'. I reset the video settings of the ps3 by holding the power button, resetted my tv, tried the ps3 at a friend with an LG tv with my cables where it worked perfectly If i try the AV cables they only give sound, no view. I have no idea what to do now, help!!!
3 Suggested Answers
SOURCE: sony bravia won''t play PS3
Try setting the resolution to a higher grade or a lower grade.. That solved the problem for me.. good luck!
Posted on Jan 06, 2009
  • 30 Answers
SOURCE: did this thing, not working. I have a 40" sony
the ps3 has a setting to run on hd tvs. if this is not selected you will have this problem. go into ps3 settings and select automatic output settings and when you turn it on you should be asked if you would like to keep these hd settings.
Posted on Nov 28, 2010
When I hook my ps3 up to my Sony Bravia tv it comes up invalid format. Any suggestions? But doesn't do that when I hook it up to other sony
Disconnect any SCART leads.
  1. Connect your HDMI lead to your TV HDMI 1 port and PS3.
  2. Now turn OFF your TV, then turn OFF your PS3
  3. Now wait 15 seconds.
  4. Now turn on your TV and follow this carefully......
  5. Now press and hold the "ON" button on your PS3 until it cycles at least once.
  6. Wait 2 seconds and it should handshake properly and make the connection.
I had the same issue, was a pain until I saw the solution on another site.
Jul 02, 2010 | Sony Playstation 3 (PS3) Console
Invalid format??
change the display settings to 1080i or 720p- his tv likely does not support 1080p.
Mar 30, 2009 | Sony Playstation 3 (PS3) Console
No video display,
UUUHH HHHH DUH!!ITS NOT MENT 4 PS2!!!
Jan 26, 2009 | Sony Playstation 3 (PS3) Console
Ps3 times out "invalid format" using hdmi cable
its the game in the game there is a trade mark thing and it thinks u are copying so it does any thing to stop u by doing a error382
or
its your cords and your useing a really cheap brand the does not sut your tv and it is does not sut your ps3 so it will cut out and make errors
Jan 12, 2009 | Sony Playstation 3 (PS3) Console
I'm getting an invalid format on my hdmi inputs when i hook up my ps3. It's wierd because it works on my viszo, but not on my new westinghouse or my samsung.
If you accidentally set your PS 3 for 1080p resolution, when the TV can only support 720p, you get a black screen. The Westinghouse TV I used displayed a message that said "invalid format." To reset the PS 3 to the standard AV format, you shut the PS 3 off. Then you hold the PS 3’s power button down for about 10 seconds. It will reset to standard video
Dec 27, 2008 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Nov 24, 2008 | Sony BRAVIA XBR KDL-V26XBR1 26 in. LCD...
PS3 to sony bravia
If you have an HDMI cable hooked up to the PS3 and the TV, you have to set the TV to the HDMI channel.
Oct 26, 2008 | Philips 19PFL5622D/37 19 in. LCD...
I cant hook my PS3 to the surround system for Sony DAV-HDX275W
what exactly is the problem? no connections? or connected and cannot get it to work?
Aug 31, 2008 | Sony BRAVIA DAV-HDX267W Theater System...
Toshiba HDTV + SONY PLAYSTATION 3 + SONY Home Theatre DAVHDX265
I have looked up the infomation on your TV I noticed that your TV has two HDMI input plugs. Since your SONY BRAVIA is hooked up to one port, you need to buy another HDMI cable for your PS3. On your tv remote you should have an option to switch from video 1 to video 2 so then you can switch from the SONY BRAVIA to the PS3 the problem is you will only hear your PS3 Sound from you TV. If you want to hear your PS3 sound from your SONY BRAVIA you need to buy an optical cable (also called TOSLINK) to connect from your PS3 to the SONY BRAVIA.
Hope that helps!
May 01, 2008 | Televison & Video
HDMI into sony bravia
plug in hdmi cable turn ps3 off then on wait and a message will apera click yes then another message appers then click yes then it should work if not connect with the red white yellow plug and then change the settings to hdmi and plug the hdmi cable in
Sep 06, 2007 | Sony Playstation 3 (PS3) Console
Sony BRAVIA XBR KDL-V26XBR1 26 in. LCD HDTV Logo
254 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
