Question about Plumbing
Stopper not working
Where can I find a repair manual to fix this?
    Problem Solver:
  • 14 Answers
Most good book stores such as Borders have handyman type books that explain the basic of most faucets repairs including the waste assemblies for lav faucets.
sanray
Posted on Dec 27, 2008
Tip
Simple Removal of Stuck Sink Stopper
I found an easy solution to removing a stuck stopper recently when I was fixing my kitchen sink and the stopper became vacuum-stuck. Instead of trying to pull on it (which will not work since the pressure is too great), or trying to release the vacuum by prying up an edge with a knife or other instrument (which would damage the stopper or sink), I used a (clean) toilet plunger to plunge the stopper out. Simply place the plunger squarely over the opening where the stopper is stuck and give it two good plunges. I got the stopper stuck several times while fixing the sink and this trick worked every time for getting the stopper unstuck. Make sure you are using a plunger that's cup-shaped (stands upright on its own), and not the kind that has a bulb at the end.
on Jun 28, 2014 | Home
Grohe drain stopper installation
Try cleaning drain with a length of wire. Strip insulation back about an inch. Turn exposed wire back to form a hook and put down drain and spin, then remove from drain, repeat until hook comes out fairly
clean. Then put drain cleaner down drain, follow instructions with drain cleaner. This should remove gunk that is preventing stopper from working correctly.
If you need further help, reach me via phone at https://www.6ya.com/expert/frankie_091f536560a54e12
Jan 20, 2014 | Plumbing
Trac off is flashing
mine was flashing and my engine lite was on. had it checked and the cam shaft was broken and broke the cam shaft sensor. had both of them replaced and now the trac off lite is not flashing.
Jan 29, 2010 | 1998 Ford Windstar
My crime stopper remoye start will not work the
try programing the remote again by going to www.crimestopper.com and to the support tab choosing manuals and manuals again with the model number from the unit under your dash find the manual for that model for any other question you can contact their tech support at 800.998.6880 ext 210
Oct 03, 2009 | 2-Way Remote Starter
Brake lights do not extinguish when engine is stopped
Removing the dash was way overkill for that problem. its a 5 minute or less job to fix that. Ck the stopper for the brake switch or adjustment.
Sep 16, 2009 | 1992 Honda Accord
My Ex-Z60's battery stopper
Battery stopper can be fixed in repairs. 800-706-2534 and keep choosing option 2 and they will tell you where to send it.
Mar 18, 2008 | Casio EXILIM ZOOM EX-Z60 Digital Camera
Janome JD1818 Automatic Buttonhole Not Working
If everything appears to be working correctly for the first side and stops and bunches up when it should reverse - Make sure you have pulled down the stopper arm (this is not clear in the manual) when the button hole foot contacts the stopper arm gently push the foot against the stopper arm and the direction will reverse and finish the button hole. **Stopper arm pulls down from above - Check the pictures in you manual carefully.**
Mar 16, 2008 | Sewing Machines
Battery Stopper broke off
you need to send it into Casio's repair center to have that fixed. I don't believe they will just send you that part. Call the repairs center at 800-706-2534 and then keep choosing option 1. Tell them what's going on and that you would like to send it in for repairs. If they ask just lie and tell them you already talked to tech support. LOL
Aug 06, 2006 | Casio EXILIM ZOOM EX-Z60 Digital Camera
Plumbing Logo
99 people viewed this question
Top Plumbing Experts
Andrew Bugbee
Tom Chichester
Gil Shultz
Are you a Plumbing Expert? Answer questions, earn points and help others
