Question about HP Officejet 5610 All-In-One InkJet Printer
Carriage cradle stuck on right side!
Hi I am trying to use my printer but I keep getting the message " Carriage Jam". I have checked all slots to make sure there are no paper jams, I've taken out the print cartridges and reinstalled a few times, I've plugged unit into wall instead of plug strip but, nothing seems to help!
Most online help gives solutions for carriage stuck on left but, my carriage is stuck on the right side. I turn it off and on but, the carriage does not move......help!
  • heurriche Jan 20, 2009
    My ac adapter is broken how do release the cradle with no power
    New Friend:
    Genius:
  • 2,120 Answers
Carriage system is broken. Uneconomical to repair. Sorry
Posted on Dec 30, 2008
Whenever i try to print it does 1/2 page then the cartridge keeps getting stalled on one side. Error message on screen says print cartridge stalled, error message on printer says clear carraige jam. Cannot...
If there's a carriage jam. While the printer is turned on, Open the access door of you printer.
If the carriage is stuck at the left side, try moving it manually by hand to the right most part of the window. If it's stuck on the right, try moving it by hand to the left.
If you've already done that. While the printer is turned on, unplug the power cord from the back. Close the access door. And then plug it back in.
Make sure you restart the computer first just to avoid documents getting stuck in the print queue. Try printing again. Usually it does the trick.
Feb 03, 2011 | Office Equipment & Supplies
KODAK ESP 7 AIO Carriage stuck on left handside Paper jam message but no paper or bits stuck inside Have tried reset procedures of internet tried when -feed rollers turn but carriage cradle appears...
optical encoder is known as the timing Strip film that guide the carriage of the cartridge, you have to clean softly with a cotton and alcohol.
Oct 30, 2010 | Kodak 5500 ALL-IN-ONE PRINTER
"carriage jam. Open door. Clear carriage jam, then press okay" error keeps repeating... tried everything still no change...
If you are getting a 'carriage jam' error as soon as you turn on your printer with no tasks in progress, then check for any piece of paper stuck in the carriage. Remove the paper carefully. If the paper tears, part of it might remain inside the paper path and damage the product.
Follow the steps for fix HP Printer Carriage Jam
  • Turn off the printer and open it to see where the paper is stuck.
  • Manually move the carriage toward the opposite side.
  • Check the paper path and remove any piece of paper or any other object that is stuck in the path.
  • Reconnect the power cord and turn on the printer.
Sep 01, 2010 | HP OfficeJet 6210 All-In-One InkJet...
HP PSC 1610 printer gives error message: Carriage Jam, clear carriage. I open the door and there isn't a Jam. I tried the solution (clean cartridge, turn off/on couldn't reset) posted by nanotech 9 Aug...
Aug 21, 2010 | HP PSC 1610 All-In-One InkJet Printer
Carriage Jam
http://www.fixya.com/support/t6088190-hp_7400_displays
May 08, 2010 | HP Officejet Pro 850 InkJet Printer
Carriage jam
Step 1: Move the carriage to the center manually if necessary If the carriage is stuck on the right or left side of the product, follow these steps to move the carriage to the center of the product.
Step 2: Check for a broken carriage chute
The carriage chute is the side wall of the carriage that holds a curved metal piece (the x-bias spring). A broken carriage chute might cause the carriage jam condition.
Step 3: Turn the product off and on again
Step 4: Clear any paper jam.
Step 5: Make sure that the control panel faceplate is correctly installed
Step 6: Plug the All-in-One directly into a wall outlet
Step 7: Perform a partial reset
Step 8: Print a self-test page
Step 9: Service the product. Now this model is outdated as per HP website.
Aug 23, 2009 | HP Officejet 7210 All-In-One InkJet...
Epson R320 carriage jammed
The ink cartridge is probably not inserted correctly.  Unplug the printer and manually move the carriage to a location where you can take the ink cartridge out.
Remove it and reinsert it, making sure that it is fully located, before applying the power.
Make sure that there is nothing blocking the carriage movement, such as some remnant of paper.
Oct 21, 2008 | Epson Stylus Photo R220 InkJet Printer
Carriage jam message
I had this same problem and spend hours working on it. Took the side panels apart to get a better look. Nothing anyone said fixed the issue. Not even the link everyone keeps posting to HP's carriage jam fix. Was out of solutions and about to give up and order a new printer. There was one last thing I had to try that I didn't think was going to work, but I had a theory. Right after I tested this solution it started working again. This worked for me, but anyone who has tried every and have not got their printer to work can try it.
My Solution: Open the front covers and look inside. Just above the metal rail that the carriage travels on there is a thin plastic strip about 1/4 in. width and should have a glossy shine to it. I believe this is some kind of positioner. It runs through the carriage and gives it some kind of position. After years of use, it'll become dirty with ink. I used some tissue and alcohol and wiped the strip clean. It worked perfectly fine right after. Below is a picture of the strip I underlined with a yellow line.
Aug 27, 2008 | HP Photosmart C4180 All-In-One InkJet...
Epson 1280 Solid red mainteance light
Hi-
Is iot on the position where you can install the ink cartridge? try turning it off and unplug it from power supply then after 10mins replug and turn it back on. keep me posted, but if it will do the same thing chances are there is something wrong with the belts on it, better have it fix or have it check. Thanks for using fixya!!
Jun 26, 2008 | Epson Stylus Photo 1280 InkJet Printer
Print cartridge cradle stuck there was a paper jam. That was cleared, but now it says the cradle is stuck and the paper does not feed please help print cartridge cradle will not move
Hi, I have a HP Photosmart 8050. Runs good till Now. 1, ONE Sheet of paper Jamed. THe RED Light Keeps Blinking Like crazzzy. I unhooked it to re-boot. It says Print Cartridge Cradle is stuck. Clear Jam & press OK. Iv'e L@@KED 4 anything. Nothing in way. I took the ONE sheet out. Still Nothing. It's Like my X-wife. 1 item wrong and a Bunch of ****. New Ink. Got Milk. Oh wrong Commercial. Got Fix. Retired Handi-capped sanior, Ron
Mar 17, 2008 | HP Photosmart 2575 All-In-One Printer,...
HP Officejet 5610 All-In-One InkJet Printer Logo
706 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
