Question about Kenmore 62602 Electric Dryer
Dryer will not spin, belt is not lose
We cannot figure out how to get to the motor. I put a large blanket in and heard a bump, then dryer quit spining
  • laura_dillon Dec 27, 2008
    dryer will not spin but belt is not lose. How do we get to the motor.
  • 979 Answers
Take off the back and you should see the motor. You can also lean it over on the frontside and get to the motor. If your drum is not turning and the belt is not loose, then the problem lies in the axle or sprocket the drum turns on. It may have seized up and needs to be lubricated. Check your motor and see that it runs.
Posted on Feb 07, 2009
Heat is blowing out but the drum is not spining
You broughtke the belt of drum wont turn you might take the dryer apart to make sure the idler pulley is spinning free also. They sometimes get tight and burn the belt up.
Apr 10, 2015 | Avanti D110 Electric Portable Dryer
My daughter put a large wet blanket in the dryer and it has completely stopped rotating. I can here it turning on, but not sending the message to heat and rotate the drum
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 01, 2011 | Kenmore 97561 Gas Dryer
Zanussi dryer not spining
heatman101
Jul 25, 2011 | Dryers
Dryer power is on, cycle starts but dryer drum doesn't spin, we may have broke it by turning the drum by hand to retrieve a particular garment, heard a lot pop or snap sound.. now dryer doesn't spin.. any...
heatman101
Nov 10, 2010 | Samsung DV218AEW Electric Dryer
My brand new GE profile frontloader dryer quit spinning. Still blows and I can hear the motor. Other than that no odd sounds and the drum spins manually without resistance. Model DPVH890EJMG How do I fix...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
heatman101
Aug 16, 2010 | GE Dryers
My gas dryer stopped turning.
There are two options on why your dryer would stop turning.
1. Your dryer motor quite
2. the dryer belt either came off or broke.
you will need to take the dryer apart to see if the belt is broken. if not than it is your motor.
Please let me know if you need further assistance in this matter.
Thank you for choosing fixya. please do not forget to rate and comment about your experiance.
Jan 06, 2009 | Dryers
Can't get replacement parts back on Kenmore 60 series dryer.
The belt has groves, right? Make sure the groves go over the motor pulley from the right. The idler pulley is spring loaded. Place the belt around the idling pulley with the smooth side of the belt on the pulley. This should work.
Dec 24, 2008 | Kenmore 62602 Electric Dryer
Put a belt on a dryer
Hello vanessastar3. Your dryer may have a motor mount with cushion or spring mounts and they may have grown weak with age. If the dryer performes substantially this maybe the lose point. Check your belt route most units have a flate spring supported roller and this maybe your weak spot. I will need Mgfr. & model# to be more pin point to the problem area if these suggestions don't correct the problem. Have fun.
Oct 01, 2008 | Dryers
Dryer not spinning
ok this sounds simple
if the dryer stopped spining there are 4 things to look at
1 the belt for dryer if this snapped the drum will stop spining
2 the dryer wheels these ware down and break off this is what helps keep dryer in a spin straight
3 this is the crucial one the motor siezed up from lack of appliance oil not being added to a regular maintenance
4 the guages has stopped working but i doubt this if it still keeps a timer going round this would not be it you dont have to run dryer to test guages just set guage to a time and see if it rotates with the time on it
the belt you can check your self by pulling down the dryer pan that will show bottom of dryer with belt if its a belt simple maytag can come out and do a replacement and maintenance on the spot
i hope this helped seeing im not there to actually see in person whats actually wrong
May 17, 2008 | Maytag LSE7806A Top Load Stacked...
Kenmore 62602 Electric Dryer Logo
Top Kenmore Dryers Experts
Sal De
Marvin
Marvin
Justin Duby
Justin Duby
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
