Question about GE GSS25JFPCC / GSS25JFPWW Side by Side Refrigerator
Ice/Water dispenser is dispensing crushed ice only.
Ice/Water dispenser is not dispensing water or cubed ice.
  • 979 Answers
You could have a problem with the lever that changes from one to another. If you can access the panel behind that door you may be able to see if it is mechanical or not.
Posted on Jan 14, 2009
Ice maker crushes ice but wont dispense Crushed ice
Good Afternoon Friend,
I understand that the ice maker in your Frigidaire refrigerator, model# FRS23H7CS, is crushing your ice, but will not dispense the crushed ice. It sounds like the dispenser is possibly jammed. Follow the following steps for a possible resolution:
    1)The ice has melted and frozen around the auger due to infrequent use, temperature fluctuations, and/or power outages. Remove the ice container, thaw, and empty the contents. Clean the container, wipe dry, and replace it in the proper position. When new ice is made, dispenser should operate.
    2)Ice cubes are jammed between the ice maker and the back of ice container. Remove the ice cubes that are jamming the dispenser.
    3)Ice cubes could be frozen together. Use the dispenser often so that cubes do not freeze together.
    4)The ice cubes are hollow or smaller than normal. The ice & water filter cartridge could be clogged. Replace the filter cartridge. Dispensing system operates best at 20 - 100 psi water pressure. Well water pressures should fall within this range.
    If the above does not work, I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Turn the power back on and try dispensing crushed ice. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully.
    -Best Regards-
    WP
Jun 20, 2014 | Frigidaire FRS23H7CS Side by Side...
Dispenses crushed ice only, not cubed
remove the dispenser bucket where the ice drops into inside the freezer and get a Tupper ware bowl,remove the bucket and dump this ice into the bowl,then rinse with the dispenser bucket with warm tap water to melt any ice on each end of this ice maker,then wipe dry and replace into freezer where you removed it to get cold again and leave empty till the next harvest of ice,this can be normal on some units after so many weeks,as it will not let the blades retract so as just to dispense only cubes,once bucket is cleaned of ice jams the solenoid and blades will again retract for cubes only
Feb 10, 2013 | Refrigerators
Ice cube stuck on crush
remove the ice bin,there must be a chunk of ice blocking the cubed dispenser chute of the dispenser and channeling all ice thru the chopper chute,run hot water thru it to melt any chunks blocking the cube chute,then dry it and let it get cold before filling with new ice or you will have the same issue again
Aug 12, 2012 | Frigidaire Refrigerators
Hi i have a double door samsung fridge and when i place dispensable ice on cube i still get crushed ice in addition is there any way to increase the speed at which water comes out the dispenser
There is likely a faulty solenoid which switches the ice dispenser between "crush" and "cube" mode.
The water pressure at the water dispenser is proportional to the supply line water pressure. Unless there is a restriction in the supply line or the dispenser line, the only way to increase the water flow is to increase the supply line water pressure -- not an easy proposition.
More info, let me know.
Charlie
Feb 12, 2011 | Samsung RS2630SH Side by Side Refrigerator
GC3SHEx300 ice dispencer does not dispense cube or crush ice. Water comes out, lights work. it is not deactivated.
Sep 06, 2010 | Whirlpool 21.8 cu. ft. Side-By-Side...
Ice maker only dispenses crushed ice, won't dispense cubed ice anymore.
I have a GE TFX25ppbaaa refrigerator. The ice maker corkscrew motor would run and provide crushed ice only. The corkscrew motor would not run when the switch was moved to the cubed ice ( half moon) setting.
I replaced the large Light/ water/ crushed ice/cubed ice switch , ( product service number GEH WR55X129 ) ( part number GE 162D6372 PO17 )and it fixed the problem. Cost was about $43.00.
Apr 17, 2009 | Refrigerators
Frigidaire Gallery Series Side by Side doesn't crush ice
hi there,
could be that the ice maker arm is getting stuck or may have some frost on it. can you supply the complete model # please?
Sep 25, 2008 | Frigidaire Gallery Series GLHS269ZDB 36"...
Ice dispenser only dispenses crushed ice
You may not need to replace the solenoid.  If you hear the hum, and not a loud click and don't see then rod move, it may be frozen with ice.  Test it manually with your hand, it should be free  to move up and down.  If not, then it is frozen with ice.  Remove the ice dispenser and let it thaw and dry out.  You should then be able to move to rod and it will work fine, at least until it freezes again.  Anyone know how to prevent it from freezing up? Its a continual problem for me
Apr 06, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Pull out your ice bin. In the back of the bin you will see a rod protruding from one side. That rod goes into an opening in the rear of the freezer. There is a solenoid behind that opening that raises and lowers the arm on the ice bin giving you crushed or cubed ice. Check to see if that solenoid is froze up or if your rod got stuck under it. If all check ok then replace that solenoid.
Nov 05, 2007 | Frigidaire FRS26KF5C Side by Side...
Check and make sure your switch is okay. Some have a switch that controls whether you want crushed or cubes. If it is defective replace it.
Oct 23, 2007 | Hotpoint HSS25GFP Side by Side...
GE GSS25JFPCC / GSS25JFPWW Side by Side Refrigerator Logo
108 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
