Question about Sharp Aquos LC-46D62U 46 in. LCD HDTV
Aquos 46" getting multiple lines when using AV cables
I just purchased a 46" Aquos. When I connect to any of the AV jacks I get multiple fuzzy lines in the picture no matter what device I connect to the tv(PS2, GameCube and DVD) I have tried new AV cables same result. It appears that the only connection working is my HDMI.
    Problem Solver:
  • 3 Answers
Criminy! This is amongst it's several fatal flaws. I strongly suggest that you RUN, DO NOT WALK-- back to where you purchased it, and get your money back. Then, coffee in hand, sift through a few "Consumer Report" type ezines & find a better model to own!
Posted on Jan 01, 2009
How do i get sound to external speakers sharp aquos?
You have to connect the TVs line out to any external Amps' line in input terminals, using an AV cable. The external amp: will then act as an outside audio amplifier to TV. Electro help
Jul 20, 2014 | Sharp Televison & Video
How do I hook up a HD satallite dvr to a av reciever dvd player and HDTV using HDMI cables
Things You’ll Need:
  • HD television
  • HD satellite or cable receiver
  • DVD player
  • Stereo receiver
  • AV cables
  • Cable connector
  • HDMI cables
Step1Examine the back of your HDTV. You will see a series of input jacks for AV cables, (typically color-coded white and red for audio and yellow for video), as well as an antenna input and one or more HDMI input jacks. There will likely be a number of them, but each one should be distinguished with a label ("video," "cable" or something similar). Step2Attach the cable connector from the cable or satellite receiver to the antenna input on the back of the TV. Step3Connect the AV cables to the DVD player, VCR, stereo receiver or whichever other component you wish to connect to the television. The cables should line up by color: place the white cable in the white input jack, the red cable in the red input jack and the yellow cable in the yellow input jack. All three cables from each component need to go into the same label input jacks. Usually, they will all line up in a vertical row. Step4Find the HDMI output jack on your receiver or DVD player (some receivers will not have them--they are necessary to receive a high definition signal--but can still play on the TV through the cable connector or AV cables). Attach one end of an HDMI cable to the output jack of the receiver and the other end into the input jack on the HDTV. Step5Turn on the TV. Access the menu with your remote, and follow any instructions it gives you. Your HDTV may require a few additional steps to complete the hookup of the receiver (though not all of them will). Step6Access the "input" button on your TV remote. This will allow you to switch the TV signal to one of the cable connections you have just made. For example, if you attached the HDMI cable to the first of two HDMI input jacks, the TV will flash "HDMI 1" on the screen to tell you that is where it is receiving its signal. Hope that helps..........
Jul 15, 2008 | Televison & Video
I have just purchased a sharp HT-SB250 sound bar to go with my sharp 32" Aquos LED tv. The item came supplied with the RCA cable and having connected it to the sound bar and the audio connections in...
You have obviously connected the sound bar's RCA (red, and white) cables to the TV's IN jacks rather than the OUT jacks, OR you might have them connected to the RCA VIDEO jacks. Check it. Connect them to the TV's audio OUT jacks. Presumably, the inputs on the back of the TV are marked "audio out", and the IN connections from your sound bar must go into the OUT inputs on your TV. I can't imagine what else it could be causing the problem.
Jul 26, 2017 | Audio Players & Recorders
We've just purchased the Aquos LE820 and set up foxtel IQ box using red/yellow/white cable. We can see the channels but the image in is black and white and fuzzy, like not in tune. Did we do something...
Hi, try setting the FORMAT to NTSC, or AUTO, in settings this is what happens when the wrong one is chosen, if you have it wired up correctly also you must choose COMPOSITE Video INPUT, this is the Yellow wire, this goes color to color in the jacks, same with the other two, the other two, the Red & White are the Audio stereo left & right.
http://www.scribd.com/doc/19365521/Sharp-AQUOS-LC404652LE700UN-Operation-Manual
above is an operations manual so you can check exactly how to do this.
Apr 16, 2011 | Sharp AQUOS 52in. LE820 LED LCD HDTV
I cant get my tv to get the regular cable channels. i just hooked it up to a new connection, it has no digital box, it runs straight through the cable. ive done the channel search and i dont know what else...
If your TV has a menu button, go into the menu and try setting the input of the TV to the jack that you connected your cable to. Sometimes the TV will not check all the inputs and just does the default one when you do the auto-tune search function to find the active channels. Also, check to see that your wall receptacle is actually hooked into your active cable TV line. You should have a splitter somewhere in the same line that your other TV is using. If not, that jack that you are hooking up your new TV to is probably not active.
Jan 01, 2018 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Tried to hook up hd cables and seems good but no audio tried to hook up but can't get to work
You cannot get AUDIO from Component Video, as it is only VIDEO, you must get another set of Cables RED & WHITE, and connect them from the AV, AUDIO Jacks, OUT on the "Sender" The DVD, Receiver etc, to the AV AUDIO IN on the TV. So you will have 5 Cables connecting BOTH Video & Audio. The Component Video, uses Blue, Green, & Red, these go color to color on the RCA Jacks at BOTH ends PLUS the Red & White Audio, color to color at BOTH ends. .Hope that clears things up.
Feb 14, 2010 | Hitachi 46W500 46 in. TV/DVD Combo
Fuzzy picture
Tryi going threw video jacks instead of coax cable see if that works better
Jul 18, 2009 | Mitsubishi VS-5047 50" Rear Projection...
Picture not HD quality while watching HD channels
Make sure you are using an HDMI video cable for optimal picture quality. Also, you must be using an HD reciever.
Jun 12, 2007 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Sharp Aquos LC-46D62U 46 in. LCD HDTV Logo
145 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
