Washing isnt getting power think i've shorted it
  • 15,935 Answers
First check the breaker hasn't tripped in your main breaker panel.
If you suspect you have a defective timer it can easily be replaced by performing the following steps:
1. Unplug washing machine... and pull out the timer knob. Some knobs have a removeable center cap and hidden screw. Some are simply slip-fit. Remove the knob.
2. Remove console. This can be accomplished in one of two ways depending on which type of console you have.
a. If the console has removable end caps, the caps lift off by prying on the top from the back of the washer.
The cap will pull off towards you as you are facing the unit from the front of the washer.
There will be a screw under each end cap that you will need to remove.
b. If the console does not have removable end caps, you will need to slide a putty knife under the front corner of each side and push in while lifting up.
There is a retaining clip under each side that has to be released.
3. Once the console has been released it will lift up and fold back over the back of the washer in its resting position. Use care not to stress the small plastic hinges that hold it on. They can break easily.
4. Disconnect all power plugs and remove the timer's mounting screws.
5. Reinstall reverse of removal.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 12, 2010
DE error message
the door isnt closed
the machine thinks
so check the door
or replace the doors interlock
it may close right stay closed etc
but the machine thinks the door isnt locked
Feb 07, 2015 | Washing Machines
Why isnt my starter getting power
fusible link burned out on single( small wire terminal) replace that wire/fusible link wire
Sep 08, 2012 | 1988 Chevrolet Camaro
Xerox Phaser 8550 tripping RCD on warm up
IF the warranty is still in effect, call for service.
IF no warranty, then check the heaters for the solid inks.
Probably a bad element, or a shorted element.
Unless you are skilled with electrical meters, V-O-M type,
this could be dangerous.
DO NOT ATTEMPT to troubleshoot this with power on.
IF you can use a meter, with the power OFF,
check for continuity and resistance with multi-meter set to Ohms.
BE CAREFUL!
Electricity can KILL!
Jul 27, 2012 | Xerox Phaser® 8500, 8550, 8560, 8560MFP...
My washing machine kkeps tripping my fuse box
This is related to a fault in the main control panel, it is possible there is a short if the fuse keeps tripping off. You need to remove plug and pull out the panel to check for short in the power supply to the main control panel usually a SMPS unit. Use a multimeter to check for short, if so this must be replaced.
check for tips from the link below:
http://www.espares.co.uk/advice/washing-machines/a/7/1298/how-to-replace-washing-machine-controls-hotpo.html
Apr 30, 2012 | Hoover Nextra HNF 3157 Front Load Washer
I think i shorted out my motherboard with another inverter to powerful now pc isnt coming on compaq 442875-001
Connect a known good inverter and Screen with the laptop's battery removed and power cord disconnected. The motherboard will power up without a screen or inverter connected if it's working. If not check F1 or FS1 on the main board power supply section. Also check the diodes in that area for shorts. Sometimes what happens is the screen or inverter gets plugged in while the battery or power cord is connected. Even thou the laptop is powered off it still has the standby voltage live.
Jul 18, 2011 | HP Compaq Presario F500 F700 and G6000...
My dell D820 laptop is shorting out the power adapter. Whenever I plug in the adapter, it shuts down via short circuit protection. I verified that the adapter is good. I have stripped down the laptop and...
It is most likely the DC connector. Take it off the system board and clean the solder joints, then replace it.
http://www.laptoprepair101.com/laptop/2007/12/06/dc-power-jack-repair-guide/
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy Holidays!
Thanks, Joe
Dec 13, 2010 | Dell Latitude D820 Notebook
I have a WD-65737 Mitsubishi DLP TV . Last night it was working great and then this morning it didnt come on . I mean its like it isnt getting any power . The green light isnt even coming on . Please help
iI just had the sMe isuue. your tv needs a system upgrade. Contact Mitaubishi and they will email the upgrade link. You will need Aa thumb dri.ve upto 4gigs to downlaod...ensure its empty. They directions will guide u. thru.
Sep 30, 2010 | Mitsubishi WD65737 65" DLP TV
2002 GMC wiring problem
get one from junk yard sounds like a dead short somewhere check around starter wires!!! :)
Jul 06, 2009 | 2002 GMC Yukon XL
Honda acord gear
it could be a short or the trans isnt gettin power and is in limp home mode you will have to have someone investigate further
Sep 15, 2008 | 2001 Honda Accord
Help please
u may want 2 just call verizon and tell them that it isnt working unless u boutgh it over 30 days i think u cant do anything bout it unless u have insurance.......wish i could help more........sry
Jan 06, 2008 | LG enV VX9900 Cellular Phone
Washing Machines Logo
Top Washing Machines Experts
