Question about GE Profile 3.5 Cu. Ft. King-Size Capacity Washer with Stainless Steel Basket
Constant drain won't fill
Hello, Well I fixed my washer it was leaking from where the bleach goes the tube was ground down... Anyway now that I plugged it back in and tried to fill it, it won't fill!! Just pours out the back, please help.. is there a way to reset it? Thank you, Christy
  • Christy Beauvais Apr 21, 2007
    Sorry I forgot to tell the model#, I could not find it it is WPSF4170V1WW
  • Christy Beauvais Apr 22, 2007
    Thank you very much!! Duh! common sense is usually my strong point but I assumed that is wasn't based on a gravity flow... But, again thank you now works perfect :}
  • 247 Answers
Look at how the drain hose is run. The highest part of the hose needs to be comfortably higher than the maximum water level in the machine. The manual will tell you what minimum height you need, but if you can't find that, use 36" as a starting point. A.
Posted on Apr 22, 2007
How do I get the bleach dispenser to drain?
Hello Denise C - There are several things that could cause the bleach to not dispense into the washer. Are you sure the liquid in the dispenser after the wash is bleach? If it is pure bleach, the solenoid that lets the water into the dispenser is not working. This solenoid is located on the back of the dispenser. It only gets voltage during the dispense time and fills the bleach dispenser with water. The bleach dispenser fills while the washer is filling for the rinse cycle.
When the washer begins to fill for the rinse cycle, the bleach solenoid is energized and water flows into the bleach dispenser cup. When the cup is full the water siphons out and bleach and water flow into the tub.
If the liquid in the bleach dispenser is pure bleach you may need a technician to diagnose and repair the problem. The voltage will have to be tested to the bleach solenoid and a volt meter is required.
If the liquid in the bleach dispenser is water you probably need to clean the dispenser cup. Scum will build up in the siphon tube and stop the liquid from going into the washer tub. The incoming water will dilute the bleach and overflow the dispenser cup and run into the tub.
Remove the insert from the bleach and fabric softener compartments. Clean the bottom of the insert and the bleach and fabric softener compartments. Reinstall the insert and put the drawer back inside the washer.
To test the siphon action slowly pour water into the bleach compartment. When the water level goes above the maximum line stop pouring. The water should all drain out. You may also test the fabric softener compartment the same way.
I do hope this information proves to be helpful.
Jan 01, 2013 | Frigidaire Affinity ATF7000E Front Load...
Maytag bravos washer- bleach compartment wont drain during wash cycle
The solenoid that turns on to dispense the bleach is bad, or you have a clogged tube that goes from bleach dispenser to tub.
Apr 29, 2012 | Maytag Bravos MTW6600T Top Load Washer
After each load the "fill bleach cup" is filled with water. I have to take the whole tray out and flip it up-side-down to empty the water. I cannot find where the thing can be clogged. I can't use bleach...
Bleach & fabric conditioners "syphon away" into machine... try adding 1/2 lt water to the bleach compartment, if it then syphons away your syphon is not blocked. If it does not drain you will need to find the syphon cap - genarally just a tube, most manufacturers will make the tube a different colour to the rest of the draw.
If it did drain when water added you may have issues with bleach not being a part of that particular cycle, delicates for example...
Apr 22, 2010 | Whirlpool Duet GHW9150P Front Load Washer
When the washer goes to the rinse cycle it does not fill it just keeps running water in the tube.............Maytage Atlantis
check washer drain hose if it is all the way in your drain line take out put it back only 6 to 8 inch in your drain line. i think i will solve your problem.
May 21, 2009 | Maytag Atlantis MAV8551 Top Load Washer
Washer fills up than starts draining while in wash cycle
Hello , here is the fix-your drain hose is placed to low in the drain line in the wall, it can not be placed in water or it will siphon the water out of your washer into the drain pipe and it wont stop until it hits air. try pulling your drain hose up and out of the drain and get a zip tie or cable and tie it to one of the water valves by the drain pipe placing the end of the drain hose about 5-6 inches inside the drain pipe. Let me know if you have any other questions and good luck it will work.
Phil
Jan 28, 2009 | Frigidaire FLEB8200DS Top Load Stacked...
Bleach leaking on floor
hiya was a bit puzzled at this one ? but will try to help not certain re your machine about bleach in dispensor but consulted the wife about bleach in our machine and no where in the manual does it mention use of bleach only softeners ? however you mention dispensor does not dispense ? try this? remove/pull out drawer and clean out the machine where drawer fits of any residue powder alsi the softener dispensor remove from drawer and ensure the cap is good fit on the dispensor tube ? if loose? then the dispensor will not work as it is emptied of softener//bleach by syphon effect ie as like toilet flush? as water enters rises to tor of tube then the fluid in compartment is syphoned along with water that is entering on rinse? cycle so if no syphon? water will o/flow/fill the drawer on l/h side and may o/flow leak from drawer ?? hope this helps? and you understand the syphon effect for using softeners ? ps i may be mistaken about use of bleach but prior apologies if iam wrong
Oct 20, 2008 | LG WM-2277HW Front Load Washer
Please help me with my washer
Hello browneyez070
Welcome,
You said, your Hotpoint top loader washing machine won't spin water out. Model VBXR1O6OVOWW?
Common causes before considering repairs.
Water won’t drain
Drain hose is kinked or
Improperly connected on it.
Solutions
• Top of drain outlet should be less than 8 ft. above floor.
• Straighten drain hose and make sure washer is not sitting
Let me know if these measures help.
Huuum
Oct 15, 2008 | Hotpoint VBXR1090B Top Load Washer
Water leak
it sounds like the bleach fill line. at the top of the washer is a bleach fill cup, it might attach to it. this black bleach fill line attaches to the bleach fill cup to the bottom of the tub.
Jun 15, 2008 | GE WHRE5260E Top Load Washer
GE tFX26KR side by side leaks water onto floor
remove the back of the unit at the bottom where the compressor is, it is held in place with 5/16ths screws. locaate the drain tube going to the drain pan, it is held in place with a spring type clamp, remove the drain tube and run water through it till it is clean and not obstructed, reinstall all parts
Apr 11, 2008 | GE GSL25JFPBS Side by Side Refrigerator
Washer fills and drains repeatedly
Have a look at the routing of your drain hose. It sounds a bit as if: a. The highest point of the hose isn't high enough (you normally want to aim for about 3 feet off the ground) - so that water starts draining from the machine before it is finished filling. and b. There isn't an effective air break or anti-siphon valve where the drain hose goes into the domestic drainage system - so that once the machine starts to drain by itself, it continues until empty. A.
Jun 07, 2007 | GE WJSR2070B Top Load Washer
Washing Machines Logo
73 people viewed this question
Top GE Washing Machines Experts
Marvin
Marvin
jimorris77
Sal De
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
