Question about Kenmore 24032\24036 Top Load Washer
Belt on my kenmore 70 series washing machine - Kenmore 24032\24036 Top Load Washer
  • onthethejob1
    onthethejob1 May 11, 2010
    please a model number..how old is unit..
I fixed this by purchasing a new washer.
Posted on Dec 28, 2008
watugot
  • 290 Answers
SOURCE: belt on my kenmore 70 series washing machine
Your washer should be a direct drive unit, it has no belt. If you hear the motor running but nothing is happening you probably have a broken motor coupler. The coupler is about $10.
Pop off the trim pieces on each end of the console.
Remove the two screws that hold the console to the cabinet and flip the console back.
Remove the two clips that hold the cabinet to the rear panel of the washer and unplug the lid switch harness. The cabinet will tilt forward and slide off.
Remove the clips holding the water pump and move it to the side.
Unplug the wires from the motor and remove the clips holding it.
You will see the motor coupler.
Make sure you can turn the gearcase shaft with a pair of pliers so it is not locked up.
Post back and let me know what you find or if you need any help.
Posted on Dec 12, 2007
SOURCE: kenmore series 70
6 yrs old kenmore series 70 top load washer in great condition..except none of the spin cycles are working. Everything else work...
I seem to also have some lint residue on clothes.
Will appreciate your help.
Posted on Feb 04, 2008
AlmostBob
  • 550 Answers
SOURCE: kenmore heavy duty washing machine 70 series
The most likely cause for water fill temperature problems is the solenoid has burned out, usually cold first, it gets used more. Not a repairable item , easy to replace
Posted on May 25, 2008
mikedurland
  • 481 Answers
SOURCE: What is the capacity in cuft of a Kenmore 70 Series washer?
it is a large capacity 2.3 cf with a small case.
Posted on Jun 27, 2008
jsrock516
  • 5911 Answers
SOURCE: Broken Machine-Kenmore 70 series Washing Machine
This is commonly caused by a lid switch malfunction. If your model number is correct, the lid switch for your washer is located under the right hand side of the washer casing along the wash tub rim. The switch is activated by a small plastic piece on the washer lid (called a "lid strike") through a small hole. The switch contacts close when you shut the lid. In many cases, the lid switch either comes loose, or the lid strike breaks off. In both cases, the washer will exhibit the symptoms you describe. Open and close the washer lid and listen for a distinctive "clicking" sound as the switch contacts close. If you cannot hear the switch, make sure the lid strike is intact and the mounting screws for the lid switch (located around the wash tub opening on the casing) are tight. Sometimes, all it takes is to tighten the lid switch screws to realign it with the lid strike. If the switch is defective, or the strike is missing, parts can be ordered on line at searspartsdirect.com. Just type in your COMPLETE model number, which can be found on a nameplate under the washer lid. The lid switch and lid strike will be listed under the "Top and Cabinet" heading. Other sites that offer competitive pricing are repairclinic.com and appliancepartspros.com. If you require instructions on how to replace the switch, you may use the following link:
http://www.fixya.com/support/r385198-replacing_lid_switch
If you have questions, or if the diagnosis is incorrect, please let me know. I hope you find this information helpful.
Posted on Jan 14, 2009
How do i determine if my switch is working on my kenmore 70 series washing machine
i think there is some problem in wiring of spin and drain. thats y it works only for washing. current stops after washing. or otherwise click below link and check the manual may be its timer problem
http://www.askmehelpdesk.com/appliances/kenmore-washing-machine-70-series-repair-manual-479481.html
http://www.askmehelpdesk.com/appliances/kenmore-series-70-washer-manual-445690.html
Jan 04, 2012 | Kenmore Washing Machines
Kenmore 70 series washing machine filled up with water today but wont spin it just humms. smelled a little burning smell
check the belt/coupling for failure.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Mar 04, 2010 | Kenmore 24032\24036 Top Load Washer
70 series how to replace belt
the kenmore 70 series do not come with belts they have a coupler behind the motor. Fairly easy to replace you can actually find videos on youtube.com to walk you through how to change it.
Oct 02, 2009 | Kenmore Washing Machines
Kenmore series 70 washer will only fill with water.
I recently had this problem. It was found that the main drive belt broke and the washer would fill but not spin, agitate or drain. I replaced the belt and everything worked again. A defective or disconnected cover switch would also cause the same problem.
Jun 30, 2009 | Kenmore Washing Machines
Help with Kenmore washer 70 Series
I called a repair man. The machine, it turns out is gear driven, and all the gears were shot.
May 27, 2009 | Kenmore Washing Machines
Belt replacement on kenmore 70 series heavy duty plus
No belt on this, its a direct drive with a motor coupler..There is a tutorial for this at www.shop.washermd.com Dave
Jan 12, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore 70 series
You will need to replace the motor coupler. Go to Appliance Guru for details of replacing this part
Jan 05, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore 70 series washer will not spin, clothes are too wet
Not a belt, this is only a sound deadening devise on the brake housing. Not really needed. Replace the coupler
Jan 03, 2009 | Kenmore 24032\24036 Top Load Washer
Need the belt routing for my washing machine
unless you washer was bought prior to 1988 there is no belt ..washer is direct drive with coupling between motor and gearcase
Jul 30, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
67 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
