Question about Lowrance LMS-527C DF iGPS GPS Receiver
Zoom gps while on the split screen with sonar.
When I have the gps split screen with the sonar screen I want to zoom the gps without having to change the screen. I used to do it but I must haved pushed the setting to where it zooms the sonar side not the gps side.
If I want to zoom the gps I have to change the screen to full gps than zoom and come back to the sonar split each time.
How can I set the zoom for the gps side in the split screen mode with sonar?
Thanks, David.
2 Suggested Answers
gopakumarg43
  • 76016 Answers
SOURCE: i have a LMS339 can't get sonar split screen or
Hello
While you are experimenting and learning, it's possible to scramble
the settings so that the sonar picture disappears from your screen.
If that happens, remember that it's easy to switch back to full
automatic operation by simply restoring the factory auto settings.
To Restore Factory Settings
1# Press MENU => MENU => [DN] button to SYSTEM SETUP => ENT => [DN] button to RESET OPTIONS => ENT
2# The unit asks if you want to reset all the options. Press [ ] to
YES'ENT. All options are reset, and the unit reverts back to the Map
Page at the 4000 mile zoom range. (Any recorded sonar logs or GPS
data will be unchanged.)
Posted on Aug 24, 2011
I want the screen split showing chart/sonar with trails on the chart. How do I do that?
I don't know what unit you have, but here goes.. go to "pages" scroll to map, scroll to "map with sonar"..hit enter..
Jun 13, 2017 | Boating
Works on down scan but not on sonar
Hummingbird systems have the ability to turn off pages so they will not be displayed. On your main menu look for the "views" tab. Scroll down to the sonar view page and see if it shows visible or hidden by that page. If it says hidden, select visible and you should be all set.
Oct 01, 2014 | Humminbird 1158c Di Fishfinder With...
How do i find water depth
Water depth should show automatically on your sonar page.
if it does not then either you have selected "stop sonar" under your sonar options or you have opted to turn off the depth displayou so the numbers don't show up.
if you areally viewing your GPS or split screen sonar/GPS page, sometimes the depth display is not visible on these pages unless you specifically instruct the unit to display it.
Lowrance HDS 5 Gen2 Fishfinder GPS Chartplotter
Here is a link to Lowrance where you can download a pic version of the operators manual.
Go to page 11 "overlay data" this will give you a step by step of how to add data or readouts to different screens.
Aug 27, 2014 | Lowrance HDS 5 Fishfinder GPS Chart...
Can not get my HDS-5x and structure scan to interface
ooooooooook click menu button twice go to functions scroll down to structure scan see if the circle beside it is high lighted if not click on it to turn it on do this to both units
Mar 25, 2013 | Lowrance LSS1 StructureScan Sonar (Lss1...
Lowrance HDS 5 Sonar faulty
You realise we are FIXYA, we are not Lowrance?
Is this when you are moving, or when you are stationary? If it is stationary, then the transducer or the wiring to it, or the plug into the head is faulty.
If it is only when you are moving, the transducer is not sitting at the correct angle and you are getting a disrupted water flow over it.
The other possibility is that you have the sensitivity set too high, which shows more activity on the screen. Set the head back to Defaults.
Feb 11, 2018 | Lowrance Hds-5 GPS Receiver
Somehow I have split the screen into two pictures of the same sonar reading. How do I get it back to only being shown on the one screen instead of being split into two.
Hi, press pages, then use the arrow up key to select sonar only page(it will show in upper left of screen the page you have selected.) Then press enter. Hope this helps, regards Phil.
Jul 20, 2011 | Lowrance HDS 5x Fishfinders HDS 5x...
Lms 520c 5" Screen Color External Gps And 200 Khz Sonar System: I have a Lowrance LMS 520C on my boat. The GPS wi...
I have the same problem on my 520C.
I have no solution but I hope you have find some?
Best regards
Dan
May 07, 2010 | Lowrance Lms 520c 5" Screen Color External...
Sonar inop at most times . onec in a while it works fine
(1) bad transducer. (2) bad ground from unit to battery. The cable next to the battery will have no effect.
Sep 05, 2009 | Lowrance Lms 522c Sonar Gps Chartplotter...
Lowrance Lms 522c 5" Screen Color Internal Gps And 200 Khz Sonar
If it is normal in deeper water, it is most likely just returning stuff in the water (debris, algae, anything floating around...choppy water can cause this). Try installing the latest updates from http://www.lowrance.com/en/Downloads/Product-Software-Updates/
If it doesn't help, adjusting the sensitivity or setting the SURFACE CLARITY option from the SONAR FEATURES menu to LOW, MEDIUM, or HIGH...whichever gives the best results.
Jun 09, 2009 | Lowrance Lms 522c 5" Screen Color Internal...
Humminbird Matrix 12 sonar/gps problems
Make sure the 'North Up' is set to 'True' in the settings.
Best of luck
Mike
May 03, 2009 | Hummingbird Humminbird 1155C GPS Receiver
Lowrance LMS-527C DF iGPS GPS Receiver Logo
69 people viewed this question
Top Lowrance GPS Experts
JonSnell Electronic
JonSnell Electronic
Are you a Lowrance GPS Expert? Answer questions, earn points and help others
