Question about Panasonic PT-56WX51 56" Rear Projection Television
My panasonic PT-56WX51CE rear projection will not turn on. Fuses where ok.
When I hit the power "on" using the remote control, there's a "click" sound that comes from the TV, but no sound or picture. It doesn't work when I tried the power button on the TV.
    Novelist:
  • 192 Answers
The click sound tells us that the microprocessor circuit is working and can be eliminated. The horizontal is the number one suspect. It could be shorted. If it is, then, the high voltage transformer or the focus block become a suspect as well. The voltages on the secondary of the power supply is the next place to check. If they are all there, then, you can rule out the power supply. If the voltages are missing, then, the regulator circuit is where the problem is. If only one voltage is missing, then, the the secondary has an issue and the circuit it supplies probably has a short. Good Luck
Posted on Apr 22, 2007
Is Worth Fixing Panasonic PT-50LC13-K Rear Projector TV
most likely a bad mainboard or bad caps in the power supply. Borderline on the repair-ability. I would check Shopjimmy.com to see if used parts are available. If they are it may be worth it.
Sep 14, 2015 | Panasonic PT-50LC13 50" Rear Projection...
Panasonic PT-47wx53 just shut off
Your convergence ICs have failed. Thats what causes the led to blink three times. The PT53WX53 convergence repair kit from www.tvrepairworld.com will usually repair that issue. The kit also contains the CD with detailed repair instructions.
Apr 01, 2010 | Panasonic PT-47WX53 47" Rear Projection...
Panasonic PT-50DL54; turns on and then in 5-10 seconds turns off. Replaced bulb, no help. Cleaned it out, no help. Any ideas?
It does sound like a heat related issue. What did you clean? I removed the back panel. Use compressed air to blow out all the dust from the components inside. Do not blow into the fan on the right.
I also replaced the batteries on the remote with new Alkaline batteries. Do not use rechargeable. Weak batteries can cause the remote to send POWER OFF command to the set.
Mar 05, 2010 | Panasonic PT-50DL54 50" Rear Projection...
Reseting The Projection Lamp Hours Meter
If you need the original remote, you can order the original Panasonic replacement remote control for this model (PT-50LC14) from a major Panasonic parts distributor at the link below:
Panasonic PT-50LC14 Replacement Part Remote Control
Sometimes there's a way to reset the counter by mashing certain keys on the TV itself in a sequence, but if your owner's manual doesn't specify this option, then you may have to get the original replacement remote to be able to reset it.
Apr 10, 2009 | Panasonic PT-50LC13 50" Rear Projection...
How to reset the meter of lamp
You need to have your Panasonic remote.
1. Make sure the power cord is plugged into a properly grounded outlet and turn on the set with the power button on the projection unit or the remote control.
2. While holding down the (VOL -) key on the projection unit press the PIP or SPLIT key at the same time. Hold it for longer than 5 Seconds. The PIP or SPLIT key is model specific:
PIP for Models:
PT-50LC13/PT-60LC13/PT-50LCX63/
PT-60LCX63/PT-43LCX64/
PT-50LCX64/PT-60LCX64
SPLIT for Models:
PT-43LC14/PT-50LC14/PT-60LC14
3. When the unit resets the lamp timer it will display a screen on the TV indicating it was reset to zero. You press recall on the remote to exit.
You will find a PDF of the instructions at this site:
http://fixyourdlp.com/blog/wp-content/uploads/2007/09/panasonic-tyla1000-lamp-instructions.pdf
Aug 23, 2008 | Panasonic PT-50LC13 50" Rear Projection...
My panasonic pt-51hx41e will turn on for couple secs then turn off
hello. it sound like a power supply problem.!!! to me .!!! you can check it frist.!!!"good luck"
Aug 01, 2008 | Panasonic PT-51HX41 51" Rear Projection...
Panasonic Rear Projection TV PT-47WXC43
I have a Panasonic PT-47WXC43 47 in Rear Projection. It went off, on picture, no sound.
Jul 13, 2008 | Panasonic PT-47WXC43 47" Rear Projection...
Panasonic PT-51G50CU
HEY !!
ITS A CIRCUIT BOARD PROBLEM ... IC MAY HAVE BLOWN OFF ...
Jan 01, 2008 | Panasonic PT-47WX49 47" Rear Projection...
High def tv: We replaced the lamp unit, but don't know how to reset hour meter
turn the TV power on the projection display or remote control.while pressing the volume button on the projection display hold down the PIP or split button on the remote control simultaneoulsy for more than 5 seconds.
Dec 30, 2007 | Panasonic PT-43LC14 43" Rear Projection...
Panasonic PT-56WX51 56" Rear Projection Television Logo
169 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
