Question about Singer CE-100 Futura Computerized Sewing Machine
Thread breakage light keeps coming on
I was embroidering, and I heard a sound as though something fell inside my machine, Then my machine would not continue or finish my design. I can't even do regular sewing only for a few stitches at a time. I feel like it is the sensor because I guide the thread gently to the right and it will stitch but only for a short time. HELP.
No, my problem is still not fixed, but being unemployed I can't afford to purchase a plan, I thought this information was free sorry. Thank you
Posted on Dec 28, 2008
I have an elna 3210 3230. Thread keeps breaking, stitch does not interlock. Help. Mary Poretta
Sounds like possibly more than one problem.
Why is my thread breaking
https://www.sewhere.com/why-is-my-thread-breaking-how-to-avoid-thread-breakage-at-your-sewing-machine
Sewing Machine Problem 1 Thread Breakage
If the top thread is not picking up the bobbin thread, it's possible the machine has been knocked out of time. Did the needle hit something or break recently? You can search for sewing machine timing or take it for service.
Dec 31, 2017 | Elna Sewing Machines
Bernina 170e Top thread catching around bobbin and knotting
http://se.bernina.com/download-n40-sD.html
hers the dl link ok butthey dont make it for win98 just vista and xp ok thx nick
Feb 06, 2008 | Bernina Artista 170
My sewing machine model#385-12312 serial #24027509 The thread keeps breaking. I have changed the needle few times but it doesn't work.
Could be several reasons: mis-threaded, tension too tight, thread snagging on something or wrapped around something in the thread path, incompatibility of needle/thread/fabric... Also, avoid old or bargain bin variety thread--use only fresh good quality thread.
Why Is My Thread Breaking How to Avoid Thread Breakage at Your Sewing...
All About Needles
Mar 06, 2017 | Sewing Machines
My upper thread keeps breaking
All About Needles
Mar 04, 2017 | Sewing Machines
Check Lower Thread message come up repeatedly while sewing and embroidering. Thread is not broken. Why is this happening?
This is usually because there's fluff in the optical sensor that's fixed to the bobbin door, or alot of fluff in the rotary hook. Remove the bobbin case and give the hook a good brush-out with the supplied brush and also get a cotton bud and gently clean the lens on the lower thread sensor. This is a black 'box' attached to the bobbin door ... if you look carefully, you'll see a small lens and an opening next to it; make sure the lens is clean and the whole area is free of fluff. If it's still giving a lower thread breakage indication (not an upper thread breakage - this is a different sensor), it may be a faulty sensor or the sensor may have become disconnected from the main processor board. Get it checked-out by a qualified Bernina service agent.
Nov 06, 2011 | Bernina Artista 180
Constant thread breakage. I have a singer futura CE-150 embroider machine. IT is brand new never been used just got out of the box. I can get about 100 stitches before breaks. I am using 100% ployester...
Well it sounds like you're using a decent thread, that can often be the issue. Just wondering if your top thread is too tight? Might be worth fiddling with the tension to see.
Another thought could be look at the trouble shooting guide in your manual as most have one, but my gut instinct would be the tension.
Apr 06, 2010 | Sewing Machines
Singer CE-150: Constant error messages, thread breakage, etc.
Check the sensor at the top of the machine. It is where the thread passes through the plastic "u-turn". Check to see if the wheel turns when you pull the thread through the machine. The wheel has a red marking on it. If the wheel isn't turning when you pull the thread, it may not be sensing the threading correctly.
I hope this helps. God bless you!
Mar 09, 2010 | Singer CE-100 Futura Computerized Sewing...
Babylock Ellure thread issues
I have the same machine and love it. Sometimes if the thread is old that will happen to me.  And also I spray the thread with static guard before i thread the machine in dry cold weather.  Since you said you are an embroiderer I assume you are using the same weight thread top and bottom. The other thing that causes that on my machine is if there is a nick on the spool of thread I am using and the thread catches just a little as it comes off the spool.  I use a fine nail file and smooth off the edge where the little v is to reattach the thread when you are finish using it.  I never use them. You do sew a little and cut off the tail off the top thread before you let it go through the rest of design. I hope you have found the solution but I learned these tricks while having the same problem as you.
Jan 25, 2009 | Baby Lock Ellure
Thread breakage sensor
Select in the main Futura menu Help->Machine setup Tutorial, lesson 10b, the balloon shows the proper position of the upper thread inside sensor checked area.
Sep 24, 2008 | Singer CE-100 Futura Computerized Sewing...
Problems with Singer CE-150... the LED light #19 keeps coming on, but I KNOW it isn't threaded incorrectly..
This machine uses a rotary thread break sensor. If you look at the top left of your machine when it is running the sensor (white dial) should be spinning. Threading around this part is critical. Make sure it spins when you pull thread through the needle. if it does not you have missed something in threading. If this is spinning and machine still stops it is likely the sensor is malfunctioning.
Mar 21, 2008 | Singer CE-200 Quantum Futura Computerized...
Singer CE-100 Futura Computerized Sewing Machine Logo
69 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
