Question about HP Officejet Pro L7580 All-In-One InkJet Printer
My HP L7580 is messaging that the back door is open. All functions are unable to perform. The door is shut, to the best of my knowledge
  • wefts Mar 26, 2009
    I have the same problem and my printer has been powered down and then on and I have reclosed the door 5 times
  • 191 Answers
Laser printer have many sensor at defferent unit like paper input cartridge fuser paper output and some cover, you may try to check a sensor at back cover somewhere around the cover edge that look like a small switch, it can be actived by the cover, the error occur if the small switch not active, press the sensor then power on see what happened, no error you may adjust the sensor position that can be active by the cover. still error need to check the sensor or repair it.
Posted on Dec 27, 2008
  • Frank Zhang
    Frank Zhang Feb 10, 2009
    any help for you please send a feedback thanks
Problem with printer or ink system
PDF]HP Officejet Pro X476 and X576 MFP Series ... - Parts Now
www.partsnow.com/.../Officejet%20Pro%20X476%20X5...
Parts Now LLCFigure 2-6 Printer status report-determining genuine HP ink usage . ..... Thesecartridges are linked by flow connections to the rest of the printbar and supply the ink..... The left door can be opened for jam clearance and has a hall effect .... The document feeder will not function when the document feeder cover is open.
db:: 4.32::Printer door will not close after printing 8p - Hivmr
www.hivmr.com/db/8p83f78d97fk8c883x9p9za3mf993scf
On the 50.8 error message, if power cycling doesn't fix the issue you may need to ...Opened printer cartridge access door and removed paper. ... HP Officejet Pro L7580, the latch to the ink cartidges broke, so the door won't close. ... Can not close the printer door on my HP B210a, after cartridge replacement need help?
Re: Do u need Help? -HP All-in-One's(Officejet,Psc's)
www.fixyourownprinter.com/posts/28357
Also, when reinstalling the HP it does print a test page, but will not print from ...Encoder Strip has been cleaned with water (had some ink residue). ..... when opening the door the cartridge does not move to the middle so i can remove it, clean it ...... Iopened the covering part of the scanner (with the glass) nad cleaned all the ...
HP Officejet 6210- repeated ' FixYourOwnPrinter
Dec 28, 2015 | HP Officejet 6600 e-All-in-One -...
Rear panel is closed scanner says i'ts open and will not print
Remove all the paper out of the machine
At the back of the printer there is an access door.
Open up the door.
Look for any paper that may be stuck inside.
If there is paper, slowly pull it out of the machine.
Close the access door
Feb 14, 2011 | HP OfficeJet Pro L7580 InkJet Printer
Scanner function will not work.error message--"no scan options". have reinstalled software plus downloaded software from hp website.
Cobbled together a MS scan option that works with the L7580. Not very seamless but I'm scanning, viewing, saving and emailing OK.
Still wish I could get the darn L7580 to work via the "scan" button!
John Boggess
Jan 05, 2010 | HP Officejet Pro L7580 All-In-One InkJet...
Unable to Scan documents
If the software is installed correctly it should scan from the scanner, otherwise i would suggest using the scan button on the software screen. Make sure all your drivers are up to date!
May 22, 2009 | HP Officejet Pro L7580 All-In-One InkJet...
Hp l7580 carriage jam - how to fix it
use the back door for printer and you can remove the envolupe
May 04, 2009 | HP Officejet Pro L7580 All-In-One InkJet...
Cannot clear paper jam on L7580.
give this a try
try this, its probably a small part of jammed paper or then theres a problem with the pickup, try cleaning it.
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Apr 01, 2009 | HP Officejet Pro L7580 All-In-One InkJet...
"Door Open" error message
check all the doors of the printer. If they are not closed, The printer will continue to throw this error.
Feb 28, 2009 | HP OfficeJet Pro L7580 Color All-in-One...
Error message: "Door Open"
HI there,
Follow the steps below:
Step one: Close the print cartridge access door
1.Verify that the print cartridge access door is completely closed. It may appear to be closed, but if it is not completely closed, the error message will display. Verify that there are no obstructions blocking the door.
2.If you are unsure how to close the print cartridge access door on your model, consult your User Guide for more information.
Figure 1: Examples of closing the print cartridge access door (your model may vary)
f3e57be.gif If you have attempted to completely close the access door and the error still appears, there may be a problem with the door sensor and the unit may require service.
Step two: Service your product
If you have completed all the steps listed above and are still experiencing a problem, service the product.
Good Luck!!!
neo
Getting error when trying to fax or scan
The L7580 is not meant to be set up as a scanning device on a network. This unit can only function properly as a USB connected device to have all the features work. Also, for the software to install with out problems, all other All in One software fro previous HP printers need to be removed. Once we did that and did clean install using USB only then did it work.
Mar 03, 2008 | HP OfficeJet Pro L7580 Color All-in-One...
HP Officejet Pro L7580 All-In-One InkJet Printer Logo
145 people viewed this question
Clive
Clive
