Question about Electrical Supplies
I have just installed the Lutron Maestro® 600 Watt Single Pole Dimmer, White in my master bedroom. The outlet is connected to a ceiling fan. Every time I turn the fan off with the light on, the light will strobe. When I turn the fan back on, it stops. Any ideas as to stopping this problem?
  • 50 Answers
YOu need to make sure that the maestro you installed is designed for use with electric motors. CHeck out this page on the lutron site... THese are the dimmers you can use with a fan. If it is in the same box the magnetic interference can cause the types of reactions you are mentioning.
If this is not the problem you need more info-- is the light part of the fan, is there a separate wire for fan motor and light? what type of switch is controlling the light (assuming the maestro dimmer is controlling the fan motor etc...
Posted on Jan 04, 2009
Switch and dimmer work opposite each other
Refer this issue directly to Lutron. They could have an ineresting explanation!
Jan 27, 2014 | Lutron Toggler Single Pole 600 Watt Preset...
I have a Meastro dimmer MAW-600 W that is installed, but the light does not turn on and the LED keeps blinking. Any idea what the problem can be?
1) If this installation was working before, the Maestro has a small pull-out circuit breaker that lets you reset the device. This is called the FASS Front Accessible Service Switch, located at bottom of dimmer where it meets cover plate.
Open sample Lutron Maestro dimmer manual to see FASS illustration
2) If this is new installation, then double-check your wiring and check that load matches dimmer capacity: 600 watt incandescent or halogen, which excludes CFLs apparently.
Some electronic devices have shortened lifespan on circuits that are not clean. Use circuit analyzer on outlet on same breaker to see if line has interference.
3) I don't see MAW-600 W listed among Maestro dimmers, so I don't have that specific manual.
4) Amazon certainly shows the MAW-600 W, in case you need a replacement.
5) Lutron has customer service numbers:
1.888.LUTRON1 (588.7661)
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on dimmer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Feb 02, 2011 | Maestro Lutron Dimmer 600 Watts Ma-600-wh
I have two black wires in box attached to regular light switch & want to know if I can install a Skylark S-603PG single pole dimmer switch which has one black , one red&white, red and green wires
This is single-pole -or- 3-way dimmer
Manual shows on following link:
1) Manual says: The red/white wire is not used in a single-pole application. Twist a wire
nut over this wire for a single-pole application.
2) Green wire connects to bare ground wire. Or bare ground to bare ground.
3) Connect dimmer-red and dimmer-black to either insulated wire that came off of old switch
For a price, fixya expert speaks with you over phone while you work on dimmer or any do-it-yourself project.
We are always less expensive than a service call.
Jan 14, 2011 | Lutron S-603PG Skylark Single Pole/3-Way...
Ok i installed the Maestro IR on a switch that runs a celing fan with a light on it. i turned the power back on in the room and the light was flickering and the fan was unresponsive. please help!!
Lutron Maestro IR shows several model numbers:
You posted under MIR600 single pole digital fade dimmer for incandescent and halogen.
Installation manual:
If this is not your dimmer, then add a comment with exact model number so I can read that manual and look for trouble spots.
The manual does not say 'Fan'
It appears this dimmer is for incandescent and Halogen lights.
Manual gives Lutron 24hr/7day tech support number 1-800-523-9466
If you do not want to add a comment for more free assistance, and do not want to call Lutron, then take advantage of fixya phone service.
Expert will walk you through the problem for a price.
Dec 25, 2010 | Maestro Lutron MIR-600 IR Satin Color...
We have an older maestro style lutron dimmer switch with a horizontal slide button at the bottom that can turn it on and off. we are using this button to operate the light b/c the vertical...
These in-wall devices stop working and need to be replaced from time to time.
There are no repair parts.
Generally dimmers don't last as long as ordinary light switch, because they are electronic instead of mechanical.
Lutron makes the widest selection of dimmers.
Use link above to identify dimmer.
For example Skylark dimmer.
Then google search for a replacement.
For example: single pole 600 watt lutron skylark dimmer
Or: 3-way 600 watt skylark dimmer
Lutron also makes 1800 watt dimmers for larger loads.
Add a comment any time if you need more help.
You can also take advantage of fixya phone service.
Fixya expert will talk with you via phone for a price.
Dec 24, 2010 | Lutron Electrical Supplies
I have a Lutron Maestro MAW-600 switch connected to 2 pendant lights and the 2 pendant lights bulbs blew. I replaced the bulbs but the lights still do not come on. The Lutron switch flashes green rapidly...
Lutron Maestro MAW-600 manual:
Single-Pole 600 Watt Halogen/ Incandescent Dimmer (minimum 40 Watt)
Lutron technical support 1.800.523.9466
You said pendant lights blew out.
How many total watts were those lights?
Did you remove aluminum break-away fins on side of device to match wattage?
Front indicator can be pulled out to cut power to circuit.
This is called FASS switch.
Try pulling out FASS switch and then pushing it back to see if it re-sets device.
Click breaker on-off to see if it resets device.
You replaced a single-pole switch that has two wires plug ground wire.
Each wire from switch goes to either screw on MAW-600 so it's hard to go wrong there.
Bare copper goes to green ground screw.
Otherwise, it looks like tech support is next step: 1800-523-9466
Nov 24, 2010 | Maestro Lutron MAW-600H Single-pole 600...
Can a single pole dimmer replacement 3-way control dimmer?
no a single pole dimmer is for 1 location control you need a 2 location control dimmer, return the dimmer for an exchange ensuring you tell them 2 location master dimmer
Dec 24, 2009 | Maestro Lutron Electronics 3-way Duo...
Replacing ceiling fixture but wall switch not working
You an probably get all the info you need here:
Jul 06, 2009 | Lutron Maestro 600-Watt Multi-location...
Electronic Low Voltage Master Dimmer
Home Depot sells Lutron dimmers which are single pole and basic..
Apr 24, 2009 | Lutron Electronic Low-Voltage...
Electrical Supplies Logo
883 people viewed this question
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
