Question about Kenmore 25512/ 25513 Progressive Canister Vacuum
Kenmore Vacuum 116.36623501 does not stay on bare floor setting
When the vacuum is shifted from the carpet mode into the bare floor mode, it shifts back into the carpet mode when you try to use it on a bare floor. The vacuum will not stay in the bare floor mode.
  • Anonymous Mar 25, 2014
    will not stay on only the bare floor works i tried resetting also
    President:
  • 1,214 Answers
It sounds like there is something wrong with the latching assembly. GO to the Sears Parts website and enter your Model number. Look at the parts assembly for the Nozzle, and the problem will be in one of items 12 through 17.
Posted on Jan 15, 2009
Just got my dc33... one issue... the dial switch to control btn bare floor / carpet mode doesn't seem holding in it's position when I set to the bare floor mode... it keeps coming back to carpet...
I'm sorry to hear you're having difficulties with your DC33. If you're concerned that the brush control doesn't seem to be staying in position, it's probably best if you get in touch with us directly. One of our experts will be happy to run through some troubleshooting over the phone with you to check everything is correct with your machine, and recommend the best course of action. You can call us free on 08002980298 (UK), or 1866MYDYSON (US). We'll look forward to hearing from you.
Kind regards,
Jack
Dyson Online Customer Support
Aug 24, 2011 | Dyson DC33 Bagged Upright Vacuum
When the vacum is set on the bare floor mode, the on/off light blinks and the roller brushes stop working
This is normal. The roller brushes aren't needes on bare floors. They are used to brush lint, hair, etc. from the carpet that the suction itself wouldn't get.
Jan 28, 2011 | Dyson DC28 Animal Bagless Upright Vacuum
I followed your directions to replace the belt on the Eureka Smart Vac 4870 upright bagged vac -- worked perfectly. Except when I turned it over and started using it -- the vacuum was in...
Obviously something is wrong. Take it to a vacumn repair shop and get it done right. The few dollors is not worth the frustration.
Mar 02, 2017 | Vacuums
Brushes don't spin
Hello :
try this please : switch the carpet/bare floor dial back & forth 5 times, ending on carpet. Tilt the handle back as if to vacuum upright & lay the vacuum on its side so it is resting on the side opposite the carpet/bare floor dial. Turn the vacuum on.
or try this also if the above suggestion didn't work :
Maybe the belt is broke. You will have to replace the belt before the roller can spin. You must have run over something in the carpeting like string or whatever to have it break. Happens all the time. Get several replacement belts to keep as spares while you're at it as nothing is worse then having to vacuum and no spare belts.
please rate !
May 07, 2010 | Hoover F5866-900 SteamVac Deluxe Wet/Dry...
Brush will not spin
Hello :
Try this: switch the carpet/bare floor dial back & forth 5 times, ending on carpet. Tilt the handle back as if to vacuum upright & lay the vacuum on its side so it is resting on the side opposite the carpet/bare floor dial. Turn the vacuum on.
PLEASE RATE !
Apr 19, 2010 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Stripped gear noise occurs in carpet mode, not bare floor mode
Maybe the level to carpet is too low or there is more then one belt and one is broke?
Mar 26, 2017 | Dyson DC07 Bagless Upright Cyclonic Vacuum
How do I stop that annoying ratchet noise?
its your clutch tht has failed you will need to change it if you need to see how its done then log on to youtube and search for fit dyson clutch its all on there hope tht helps
Oct 14, 2009 | Dyson DC14 Animal Bagless Upright Cyclonic...
The adjustment knob for bare floor will not stay in position
broken catch. recommend dyson service as it is not user replaceable.
Jul 24, 2009 | Dyson DC14 All floors Bagless Upright...
Works on carpet not on bare floors
It's not supposed to rotate on bare floors
Nov 14, 2008 | Dyson DC14 All floors Bagless Upright...
The brush rollers are on off, how do i turn them on? model #u6616-900
There is a slider on the front of the hood labeled "brushroll on/off. Carpet/ Bare Floor."
Slide this switch over to the carpet position. Note that if the handle is upright, it will not shift into "carpet" mode until you drop the handle back. This is a safety feature.
If the brushes are not turning at all, it is either your rubber belt, or possibly a problem with the belt tensioner.
-R
Aug 04, 2008 | Hoover Vacuums
Kenmore 25512/ 25513 Progressive Canister Vacuum Logo
319 people viewed this question
Top Kenmore Vacuums Experts
Chris Nomland
Chris Nomland
Marvin
Marvin
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
