Question about Vizio P2 42 in. HD-Ready Plasma Television
Can't turn off closed caption & not its not on the TV menu
Purchased new 42" vizio plasma TV and when I turned it on for the 1st time it displayed closed caption text on the screen. According to the manual I can turn it off on the setup menu, but contrary to the instruction manual there is no option for this on the setup menu or any other TV menus.
I went to menu, special features. then select analog CC and selected OFF.
Posted on Jan 04, 2009
Can I turn the caption mode off with the remote?
CC (Closed Caption)
To select the options in the CC sub-menu, press the MENU button or the #
button. A new menu will be displayed showing the following CC settings:
CC
The CC feature is available when watching regular analog (NTSC) TV.
Select from CC1, CC2, CC3 or CC4. Closed Caption for regular TV is
usually CC1 or CC2.
Digital CC Style
The Digital CC Style feature is available when watching digital TV.
Select either As Broadcaster or Custom. If Custom is selected then
you can customize the way Closed Caption is displayed.
Feb 14, 2015 | Vizio VF550M 55 in. LCD HDTV
My closed captions all channel is displayed on my vizio tv. I can't get it to go off. I use verizon fios my box doesn't have a menu button on it. Any other suggestions?
Closed captioning is selected during initial set up of your Vizio TV. If you return to that procedure, you can turn off closed captioning.
Dec 07, 2014 | Vizio Televison & Video
How do you get closed caption on
manual below.
http://www.retrevo.com/search/v2/jsp/mytrevo/myTrevo.jsp?page=man Turning On Captions Pressing the CC button displays caption options: ? CC on: Displays captions. ? CC off: Turns off captions. ? CC mute: Displays captions when the Mute button is pressed. To assign your preferences for captions, see “Using the Closed Caption Menu” on page 33.
Mar 17, 2010 | HP PL4260N 42 in. Plasma HDTV
The closed capioning will not come off the screen. I went in the tv menu to shut it off but the tv menu says it is off but the words are still coming up on the screen
If you are getting your broadcast signal by way of a digital satellite or a digital cable box, you will need to access the menu(s) within them to turn off the (CC) closed captioning. I have had times when I had to contact the satellite or cable co. to have them help me get into their "special" menu to shut this off. Good luck !
Jan 04, 2010 | Vizio P2 42 in. HD-Ready Plasma Television
I black rectangle appears on the screen and finally dissappears after a few minutes. WHat is this?
This sounds like the closed caption is turned on and in the text mode instead of the regular closed caption mode. With the remote or in the main menu there is a way to change or turn off the closed caption. Regular caption is usually marked CC1.
Oct 21, 2009 | Vizio P2 42 in. HD-Ready Plasma Television
Close caption problem
Use ur remote turn off CC functions on the remote.
Or go to the menu go to the caption turn everything off like Text or CC1 CC2.
Sep 23, 2009 | Vizio VW42LF 42 in. LCD HDTV
Cannot get rid of captions on TV screen
Have you gone into the menu and located Closed Caption or just caption and turned it off? It might be under the Audio menu or Features.
Feb 01, 2009 | LG 42PX5D 42 in. Plasma HDTV
Closed caption wont turn off
I have a Vizio VX37L that i purchased on 12/26/08 and I had the same problem by 1/4/09. My five year old son loves to futz around with buttons and switches and he somehow enabled closed captions from the front of my Motorola digital cable box (I had it hooked up to the Vizio via HDMI 1.)
What you need to do is turn off your cable box and leave the Vizio on. Hit the "Menu" button on the front of the cable box and that should bring up a setup screen on your TV. Using the down cursor button on the front of the cable box, go down to the "Close Caption" section on the setup screen. It probably says "Enabled." Click on the right cursor button to disable CC and you should be good to go.
May 07, 2008 | Vizio L32 32 in. LCD HDTV
Close caption works when I select the input for tv, select hdmi input and the close caption option disappears from the menu. I have a shaw cable pvr hd box and need the close caption to work on all...
You need to turn on closed captions through the menu of your PVR. To have it on all the time, turn the box off, press menu on the front of the box, and scroll down to captions.
This should fix the problem
Jan 12, 2008 | Dell W4201C 42 in. Plasma HDTV
Closed captions will not disappear
Some TV will not display close caption in HD mode. This is why its Grey out in HD mode. If you switch to regular input, i can bet you your close caption will not be Grey out. The problem you are having is your cable box has close caption enable. You must go into the cable box menu and turn caption off. In some box you may have to call your cable provide for assistant.
Best regards
Circuitcity
Nov 27, 2007 | LG 42PX5D 42 in. Plasma HDTV
Vizio P2 42 in. HD-Ready Plasma Television Logo
722 people viewed this question
Top Vizio Televison & Video Experts
pzarnold
Level 1 Expert
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
