Question about Toys
Mr christmas double decker carousel rotation stopped.
Model # 19993 - sold by Lowe's.
Music and lights are ok.
Rotation has stopped. Instruction manual troubleshooting says turn off power and reappy power to correct. Doesn't resolve problem.
No parts manual or how to disassemble carousel. Mfrs website is not available today 12-27-08. (www.mrchristmas.com)
Is there a detailed parts manual available anywhere that also describes disassembly and reassembly?
  • 5 more comments
  • housingauth Dec 30, 2008
    I have the exact same thing going on with my carousel. Got it for Christmas and it has never worked right. If you get any answers I would love to hear about it.
  • Baldovin Jan 13, 2009
    I bought mine this year at Christmas for my son and it too has problems....It will rotate but then gets to a certain point and gets hung up and won't turn unless you force it to keep going. There is obviously a problem with this model.
  • Anonymous Apr 25, 2009
    same thing, won't rotate, unsolder? sounds like a lot of work
  • Audrey Patrick Jan 10, 2013
    I have the same issue, my carousel quit working, I need someone to repair it like a jeweller, but they won'y touch it. The kids love it. I'm looking for a repairman in Regina. Any ideas?
  • Elizabeth Dorazio Feb 12, 2013
    Take the top canopy off, plug into power turn on, see if one of the gears is getting stuck on one of the electrical wire that runs under the gears. My carousel would not turn but I could hear the motor running, it was just one of the gears getting stuck on the wire. Hope this helps.
  • pookiebearja
    pookiebearja Dec 02, 2013
    Mine never did work either. Isn't there a fix for this???
  • elsa davila
    elsa davila Dec 18, 2013
    my double deckr carousel is not spinning light's gos on but don't move whats wrong please help
These things are really hit or miss. The company (Mr. Christmas) is virtually useless in the realm of tech support. Caveat Emptor and all that. Personally I have no use for this sort of thing but I must admit they ARE cute (when they work)!
I met a gentleman at the Citigroup Station Model Train exhibit (where I work as a train operator during the holidays) who had a problem similar to yours (in his case it's the music which doesn't work). I offered to attempt to fix this fellow's Mr. Christmas carousel (which he bought used, strike one!). Being a model railroader, I have vast experience repairing model trains but thought this might be a challenge. I did some online research and came to the same conclusion you did (ie Mr Christmas doesn't give a *%&^ once you've bought something, and there's NO viable tech support or schematics to be found). I was nearly about to throw in the towel and return it when I figured out how to open it. I will at least get you to the innards.
My guess is that these carousels are more or less mechanically similar (this fellow has the Disney Carousel, model 94448). The carousel consists of an outer "roof" which snaps around an inner roof (where the horsie poles insert; there are four little tabs which keep it attached to the outer roof). To get the outer roof off, however, you need to carefully remove the "crown" (which is glued on with some sort of silicone based adhesive) It is glued on with some sort of silicone based glue. BE CAREFUL removing it! Once the crown is off, you'll see a screw. Unscrewing it allows you to remove the outer roof.
If you feel mechanically adept enough, continue but TAKE NOTES as there are a LOT of screws and parts from here to the bottom base (where the motor and electronics are located). Once the roof is off, you will see the light wipers and contact pad. You will need to unsolder the two wires from the sprung wipers (be careful not to lose the springs!). You can now unscrew the hexagonal nut which holds the light wiper bracket/wipers in place. CAREFULLY remove this piece! You will now need to unscrew the contact board. pull it over the central shaft. You can now remove the inner roof. Once the inner roof is removed, you can lift up the main assembly (ie the horses, &c); CAREFULLY place this aside!
You are now at the base. There are several screws holding the motor and central shaft to the plastic base. This will come free but will remain wired to the switches. FYI the whole mess is a rubber band drive (sort of like an old cassette player or VCR). If there is no rubber band connecting the motor to the shaft, that is your problem! If the motor plain doesn't work, check the wiring fro the motor to the switch!
To reassemble, just reverse the directions. HINT: the roof will only go on top of the mechanism one way, so if it doesn't quite fit just rotate the roof until it does! Good luck!
Posted on Jan 01, 2009
  • 5 more comments
  • rdssan Oct 25, 2010
    Great instructions, I finally found that the small gear on the drive shaft with the belt was slipping---so I roughed it up and coated it with jb weld, have to let it set up, and then hope it holds, then reassemble, if the shaft had splines in it and gear was pressed on there would have been no problem, but then people go out and buy a new one.---glad for this letter of instructions, otherwise, would have ended in trash can too! rdssan@comcast.net
  • mrfreeeeze Nov 18, 2010
    Model: Christmas Carousel
    - Remove top crown cap
    - Remove screw
    - Then you are left with 4 screws, remove those.
    My Carousel had a broken lead, fixed it in to seconds.
    This blog was amazing. And yes Mr. Christmas are useless!!!!!! Don't waste your time calling them if your product is out of warrantee period.
  • lazerdude Dec 07, 2010
    LtJim!!
    Thank you for figuring this out. My carousel stopped working also. Because of your helpful ingenuity and instruction in taking it apart I was able to replace the drive belt ( 1-5/8 "O" ring from a hardware store) and it works fine now.
    Thank you for the help.
  • inllorente
    inllorente Dec 15, 2012
    You all rock. This was spot on. The carousel is back up and spinning. Thank you all and merry christmas!!!
  • valerie nelson
    valerie nelson Nov 20, 2013
    I am in the same situation. I just pulled it apart and found a broken rubber band. can you explain to me how to put a new one back on? I will order one now!
  • Debra Learmonth
    Debra Learmonth Nov 30, 2013
    Not sure this is the best place to ask but it's the closest I've been able to find anything close. I have a ~ 2000 Mr Christmas Nutcracker Suite. The music still works and the carousel turns correctly but the figures done move any longer. They seemed sticky for a year or two but once I got them going they seemed to work until the next time. WEll now they don't move at all. I was able to get it apart but can't take the top completely off due to a wire with no slack. I was thinking I could oil something until I saw how it was put together. Now I think it's the motor. Is it simply a wire to the motor or could the motor be dead and if so can it be replaced? Thanks!
  • Paul Di Nardo
    Paul Di Nardo Jan 26, 2014
    Late to the game here but I have the came Nutcracker Suit, same problem. I have determined it is the drive belt (rubber band) that went bad. Years in a hot attic have caused it to dry rot. Access by turning the unit over and unscrewed the bottom. Please me know if you can find one of these rubber bands. I have been looking for a couple of years with no luck.
These are some of the best solutions I have ever read. There is absolutely nothing on line and no one who can help with these problems. My problem is a little different in that I have a San Francisco Music Carousel and the music plays and the carousel rotates, BUT the horses no longer will go up and down. I took the top off and discovered there are little gears that slip over metal rods that, when turned, make the horses go up and down. Well, these gears have completely smashed up on 4 of the 6 horses and because of that, none of them will move up and down. I am trying to explain my problem to several on-line repair places but nobody seems to understand what I am looking for. Is there anyone out there that could direct me (even to a hardware store option) to be able to replace these gears so that can get traction and move the horses? I would appreciate any input.
Posted on Feb 20, 2012
I took my carousel apart using LTJims instructions and fixed the lights but no music. Tried replacing a transistor and a capacitor that were both burnt out, but still no music. Any thoughts on how to solve the music problem
Posted on Feb 04, 2010
  • mackattack12 Feb 04, 2010
    LtJim,
    Did you manage to fix the music. Did you get any schematics?
    New Friend:
Can not get the carousel to run
Posted on Dec 22, 2016
  • Gail Mills Dec 22, 2016
Is there someone we can send our carousel to get fixed. I am not good at this stuff. No patience
Posted on Dec 19, 2014
I have the single model. The top of the "tent" (essentially a plug) comes off on mine. This reveals the one screw on top then takes the top cover off. My problem was lights not working. Two wires are on the center (on some sort of pivot). Both had broken off. I am a beginner at solder, but did good enough to reconnect them and have them running.
Posted on Dec 27, 2013
I have a Mr. Christmas 1995 Santa's Musical Worskshop and it no longer runs the tape ribbon through the unit or plays music although it played a spate here and there and then stopped. It also attempts to move the moving parts when plugged in. Any idea how to take it apart and repair it? I think the musical tape needs threaded through the machine. Thanks!
Posted on Dec 06, 2011
When you try to unscrew the roof, if it doesn't feel like the screw is raising up - stop turning as the shaft it is screwed to is also turning and this will twist the roof lights power wire inside the central shaft and rip the connection off the land on the circuit board below. This will also stop the motor supply. If you gently insert a wedge between to outer rim of the roof (push in that side's retaining tab), you can insert a pair of long nose pliers in and grip the central shaft, then you unscrew the top screw and remove the roof. My problem was the first plastic cog wheel on the drive shaft driven by the rubber ring had broken in half (I suspect pushing the carousel base to try to get it moving puts a strain all the way back to this initial wheel which is held to the drive shaft by a serration on the metal drive shaft. Tried to epoxy the wheel back on but caused a slippage and uneven jerky motion. I would attempt this a gain if I had a replacement drive wheel, so anyone who doesn't want their defective or working Mr. Christmas (Marquee Carousel model preferable) contact me and I'll pay the shipping for you to send it to me. Mentorall@aol.com
Posted on Aug 08, 2010
Mr christmas carousel lights above each horse won't turn on
i would check any bulbs it might have some times it only takes one to blow to stop the others working.not saying this is what is going on with yours .
Nov 30, 2016 | Washing Machines
Model TB425CS WHAT IS SPARK PLUG GAP
Al, .025" is the plug gap for your trimmer,page 20 in your manual. There may be a recall on your model to do with safety.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://lawnandgarden.manualsonline.com/manuals/mfg/troybilt/tb475ss.html
Troy Bilt Model TB425CS Parts
Troy Bilt String Trimmer Sold at Lowe Recalled for Laceration Hazard
May 15, 2016 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Hi can u help me my 2840 laserjet paint error 54.2 ..rotating to mageta
Display Description The device has experienced an internal hardware error.
Carousel rotation error Remedy Turn off the power by using the power switch, wait at least 30 seconds, and then turn on the power and wait for the device to initialize.
Replace the carousel drive motor. If the error persists, replace the DC controller. If the error still persists, inspect or replace the engaging detection flag.
Apr 03, 2015 | HP LaserJet 2840 Printer
Timer does not turn on its own turn it manually is fine can l change the timer
There is no replacement timer module sold for the power pack.
Plug power pack into cheap wall timer.
Link below has troubleshoot steps and warranty information
http://waterheatertimer.org/Malibu-power-pack-stopped-working.html#troubleshoot
Gene
Water Heater Timers Save Money
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Feb 19, 2015 | Malibu Intermatic Inc. ML300RTW 300-Watt...
My Samsung refrigerator won't stop beeping and light inside is out
OK we know it's a Samsung Refrigerator probably 1 of about 50 models that Samsung sells. The model number is on a plate inside the refrigerator. If you don't have a user manual use the model number at searspartsdirect.com to view or
download the user manual. If sears has ever sold this model it will be there! Use the troubleshooting section to find out why it's beeping. It may be as simple as needing to clean the door seals so they don't leak air. Remove the light bulb cover if there is one and replace the light bulb with one of the same kind.
Oct 26, 2014 | Refrigerators
I need the wiring diagram for Pioneer Music System MS-Z64
You would need to contact Pioneer directly, in Long Beach, CA, to obtain a service manual. I would suggest you hurry, as Pioneer has recently sold off the home audio side of the company.
Feb 06, 2014 | Pioneer Audio Players & Recorders
My kodak carousel 750 wont stop advancing
The Carousel projector you describe is approximately 50 years old. Parts are going to be very difficult to locate.
The continuous cycle condition you describe is due to either the cycle contacts just being worn out, or there is a slight chance that those same contacts could be out of adjustment.
If it is the contacts being worn out, it means that the "J"-shaped contact that stops the rotation of the clutch contact that protrudes from the hub of the camstack has nothing to stop it - - the clutch contact has "burned off" from excessive use.
If it is out of adjustment, the "J"-shaped contact should capture the spring protruding from the camstack. In this situation, a VERY careful hand can bend the "J"-shaped wire so it stops the cam contact after it makes one rotation.
I have searched my illustration archive, but can not find an illustration that represents these contacts.
I hope this helps you with your repair!! Jim
Jan 29, 2014 | Kodak Office Equipment & Supplies
Toys Logo
10,595 people viewed this question
Top Toys Experts
Marvin
Marvin
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Toy Expert? Answer questions, earn points and help others
