Question about GE JVM1430 Microwave Oven
Broken light bulb
While trying to take out a burnt out light bulb that illuminates the stove, the base broke off in the socket. I am unable to remove the broken part from the socket. Am I supposed to replace the socket and bulb as a combination?
  • Anonymous Mar 12, 2014
    Light bulbs broke in sockets
I WAS TRYING TO REPLACE THE LIGHT IN MY MICROWAVE AND THE LIGHT BROKE OFF IN THE SOCKET, THE WHOLE PANEL WON'T WORK GE MODEL EMO3000CSS04
Posted on Sep 08, 2009
  • GE Master
  • 9,156 Answers
First of all, always disconnect the oven from the line before you remove or install bulbs, otherwise, you can damage the control board. We repair them all the time because of this. You can find helpful exploded view diagrams and order parts by entering your full model number (without the suffix) here: http://tinyurl.com/gv383 We have critical safety & disassembly info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
Posted on Apr 23, 2007
Light bulbs in built in microwave have come apart when we tried to unscrew them for replacement. How can we get the broken end of the light bulb out of the sockets?
Most Samsung microwaves use a bulb and bracket assembly that is meant to be replaced as a unit, not disassembled (see image). If the bulb base was secured using epoxy or some other means, it may not be possible to remove without damaging the bracket.
That said, you can try traditional methods for removing broken light bulb bases. Remember to always unplug the fixture/appliance, or shut off and mark the breaker serving it, before working.
A cut potato or carrot can sometimes be pushed onto the broken glass left in the base, to provide a handle for unscrewing the base. On smaller bulbs, I have successfully used the eraser on the end of a pencil.
If the bulb was really stubborn, I would probably try filling the base with a hot glue gun, then pushing a screwdriver into the soft glue. Once the glue hardens, turning the screwdriver should unscrew the bulb base (if it is at all possible).
As you may have discovered, pliers and the like tend to just break off small pieces of the broken glass bulb.
Jul 13, 2011 | Samsung Microwave Ovens
I have the GE profile spacemaker microwave oven installed over my stove. One of the lights burned out on the left lower portion of the unit. I removed the screw, lowered the metal cover, and tried to...
You could try the potato trick. Take a small to medium potato. Cut off an end of the potato. Press the cut end into the broken lightbulb and unscrew the rest of the bulb out.
May 24, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
I cannot tell how the 2 bulbs (surface light(s)) detach. One of them broke when I was trying to remove after it had burned out, and the glass part of the other bulb turns freely and is very loose and...
Unplug the microwave oven and get a needlenose plier and a flashlight. Wear some hand protection since you are working with broken glass.
Most of the bulbs I have seen are screw thread mounts.
For the bulb with the broken glass, use the needlenose plier and try to find the screw thread for the bulb. It should be screwed in to the lamp socket of the microwave. Carefully grab a hold of the outer edge of the bulbs screw thread and turn it counterclockwise to loosen it from the base. You may only be able to turn it a quarter turn before letting go of the bulb's thread and getting a grip on a new position to continue turning. Inch your way to remove the broken bulb's thread.
If the other bulb still lights up, I'd leave it alone.
Aug 09, 2010 | Hotpoint RVM1325BW Microwave Oven
Light bracket in over the stove ge microwave XL
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Dec 06, 2008 | GE JVM1630 Microwave Oven
Broken bulb
From what others have said, it will come out, but you have to use some strong good needle nose pliers to turn the base in the socket.
Jan 12, 2008 | Whirlpool MH2155XP Microwave Oven
Broken bulb
Get yourself a cork from a bottle of wine (wait to drink the wine until after you've removed the bulb!). Now, with the power plug REMOVED from the wall socket, gently but firmly press the cork into the broken bulb. You should now be able to screw the broken bulb out of the socket. If there's not any bulb glass or shards or anything else for the cork to grip, you may need to insert a small pair of pliers into the socket, and with reverse pressure (i.e. pulling the handle apart as opposed to squeezing together) you may be able to remove the bulb. And if that doesn't work, well, keep trying. You just need to be creative. Try using needle nose pliers and grabbing the edge of the bulb socket and gently work to loosen (remember lefty loosy, righty tighty) turning counterclockwise to remove.
Dec 30, 2007 | Kenmore 62702 Microwave Oven
Bulb replacement
It aint haolgen. This is another GE piece of POO engineering.
Unplug the microwave FIRST.
Now, Make sure your stove top is cold!
There are 6 phillips head screws holding a plate that secures the stove-top light and grease trap filters on the underside of the microwave. Lay on our back on the cooking elements looking at the bottom and remove the screws. The plate should swing down on hinges in the back.
Then remove the "bulb holder" which is held inplace with another phillips head screw. You can see what it looks like: http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5100389
You should now be able to remove the "screw-in base" of the bulb with your hand or in my case, because I was so tight, I man-handled it with a pair of needle nose pliers.
Now, go find a bulb! good luck.
Nov 29, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
Sockets for bulbs are cracked and shorting out
You should be able to take the screws out of the bottom plate and remove it. Then you should be able to get to where you need.
Oct 10, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
GE JVM1430 Microwave Oven Logo
434 people viewed this question
Top GE Microwave Ovens Experts
vince
D. E. Hev
 Larry
Larry
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
