How o I remove the pilot injector from a Cannon coalridge bf
Cannon k38 gas heater: mistakenly turned pilot light on gas heater off. I can't find instruction manuals or any help online. Can you re-ignite the pilot light manually or do I call a service agent?
Anon, To relight pilot check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to Light Your Pilot Light Gas Fireplace
Fireplace Pilot Light Tutorial
How To Light The Pilot Light On Gas Heater
Jul 02, 2016 | Water Heaters
Pilot light blowes like flame thrower when lit on bosch 125 blp
Remove the pilot injector from old unit and fit into new unit
Apr 03, 2014 | Bosch Water Heaters
Pilot Orifice
Okay you don't ream pilot injectors hence the 3 inch pilot which is now no good to you nothing to be done with that .
Take you manual to heating / plumbing shop tell them you need a new injector for you pilot block they might be able to sell you just the injector or a new pilot block Most pilot injectors are the same size . Or get you gas fitter back to replace it as the injector was only blocked and needed a clean . in 40 years of gas fitting I have never reamed a injector .
Jun 04, 2017 | Bosch 1600P-NG AquaStar 4.3 GPM Indoor...
Monitor will not awake from sleep mode. Pilot light is amber when asleep. If the monitor is turned off pilot light goes from amber to off or black or nothing. Turning the monitor back on the pilot light...
That means your monitor is not receiving a signal from your video card.
A couple things to check:
*Make sure your cable is ok - unplug and replug the cable to see if it is a loose connection. Or try a different cable.
*Make sure your computer is not in sleep mode - Move your mouse or otherwise ensure your computer is awake and sending a video signal
*If you have another computer, try the monitor on the other system and see if it works.
Sep 03, 2017 | LG L196WTQ-BF 19" Monitor
The pilot on my Procom QL300TYLA will not light. It appears that no propane is getting to the pilot. I tried lighting the pilot and burner with a BBQ lighter but nothing. No propane getting to the unit....
sounds like you have a blocked pilot injector. normally part of the pilot head. if you can remove it , blow it out with compressed air but it must be removed from the pilot head. commonly known as a Pilot restrictor,Pilot spud or Pilot injector
Dec 15, 2010 | Procom QL300TYLA Heater
Yellow pilot flame
pilot is yellow cause its air mixture hole is blocked or you have something in pilot stem like a spider web i have had this problem on flame effect gas heaters during thier off months spiders get into pilot stem and create webs which can cause this the other reason is that the air mixture hole is blocked with carbon or something clean out to get blue flame, and an example of yellow flames in gas heaters is flame effect fires where i know a certain company cover air mixture hole on burner to get the flame more yellow and realistic looking but on a service i remove the foil they stick over hole making flames blue again, as it can cause the heater to carbon up to the extent of black glass with yellow flames
Nov 25, 2010 | Empire BF-10 Mid-Size Heater
Pilot light wont stay on. How do you adjust pilot flame? Pilot flame doesn't reach temperature sensor.
then the pilot is blocked needs cleaning out or try blowing it out with air , or undone pilot and remove pilot injector and clean it .
Nov 01, 2010 | Rinnai Unvented Gas Zone Heater. 99% fuel...
How do i light the pilot light on my Cannon Fitzroy gas log fire
Users manual link attched. This is for the built in put operating instructions should be the same for free standing.
Cheers, hope it helps.
http://www.sampfordixl.com.au/cannon/upload/CannonFitzroyProfilePowerflue.pdf
Jul 26, 2010 | Heating & Cooling
On my gas fireplace, the pilot light used to burn blue. Now it's burning more of an orange color. How do I fix it?
needs blowing out remove pilot tube from pilot remove injector and clean it out then replace it all test joint with soapy water to check for leaks
Jan 21, 2010 | Vanguard International Blue Flame - Medium...
Heating & Cooling Logo
112 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Mack Baxter
Marvin
Marvin
