Question about Kirby Ultimate G Bagged Upright Vacuum
Kirby ultimate g problems
My Kirby ultimate G upright is shaking and catching when I push it forward, almost as if something is out of alignment. When I first bought it, I was told to lower the height adjustment until I could hear the vacuum make connection with the floor and then lower it one more notch past that for just the right suction. I can get the shaking to stop if I sweep with the vacuum lowered to just the point where it makes connection and not the extra notch lower, but it is definitely not picking up as well and also it will sometimes blow the particles to the side instead of sucking them up. I have taken the brush/roller out of its resting place and then put it back in, just to be sure that I hadn't replaced it incorrectly during a cleaning, but that didn't seem to help. Also, it is giving off a "musty vacuum" smell, which I thought was because the bag was ready to be emptied...but it is even doing it when I have a new bag in. I've also checked the belt to be sure it didn't need replaced or that there wasn't some hair or something causing it to give off that smell.
Re: kirby ultimate g problems
I had the same problem. I did two things to solve this. I used a quality belt for the brush bar. When replaceing the belt, on each end where the berrings slide into the plastic side guides, there are little notches on the edge of the two plastic end guides. There is one notch on one side, two notches on the next side and three notches on a third side. Make sure you have the same number of notches on both ends of the plastic guide. These notches are used to set the height of the brush bar (this is in addition to the foot pedal used after the brush bar is assembled). If you do not have the same number notch, the brush bar is out of adjustment. Hope tis helps.
Posted on Jul 17, 2007
Does it only do this in drive or neutral also? Mine does that in drive because I won't go as slow as that mode requires but I do not have that problem in neutral mode. Renee
Posted on Jun 26, 2007
I totally have the same problems. I think the smell is coming from whatever we sweep up into the bag, and that getting musty or whatever. Like skin cells and whatever else is in the carpet. But my is stinky too when the bag isn't totally new. The jumping around happens to me as well when I go too fast. If you sweep slowly ( I know, not the ideal), then the jumping or shaking will stop.
Posted on May 04, 2007
0 characters
3 Points
Why does my kirby shake ?
If your Kirby is just sitting on a hard surface and is shaking, something is either on the fan or brushroller putting it out of alignment. Here is how to change the fan / impeller if broken.
how to change Kirby fan / impeller.
If it shakes while you are pushing against the carpeting you can try adjusting the height of the brush until it is just touching the carpeting. Some thick pile carpeting the Kirby will still shake or jump on, the strong suction causes it to trip over the thick pile that is lifted up when vacuuming.
Oct 05, 2014 | Kirby Vacuums
Kirby ultimate g vacuum cleaner (not the shampooer) leaving white marks/trails all over brown carpet
This is not a normal occurence...maybe something the previous owner did or used the vacuum on?? A KIRBY will not normally leave any marks on Your carpet..
Lee in Australia
Oct 14, 2012 | Kirby Ultimate G Bagged Upright Vacuum
When I put my kirby ultimate g in neutral with power off it clicks when I move it is this a problem
needs a new neutral cam bracket, phone your local kirby agent for service. cam bracket is $15
May 21, 2012 | Kirby Ultimate G Bagged Upright Vacuum
How do i attach the hose to the vacuum so i can vacuum my vents?
Remove the vacuum head by tilting the front down slightly and pulling straight back. Attach the wand hose onto this opening by placing the small hooks of the hose on the bar beneath the opening and pushing the hose against the vacuum base. Lock the hose in place by turning the vacuum head lock from left to right so it catches the hose.
Read more: Kirby Ultimate G Instructions '
Aug 24, 2011 | Kirby G6 Bagged Upright Vacuum
Kirby will not push forward, wheels are locked
Check the back side at the bottom to see if there is a lever (switch) that has an N on one side and D on the other. You press N to roll the vacuum when it is NOT ON. N is for nuetral. You press D when the vacuum is ON and you are using it. D is for drive.
Feb 14, 2011 | Kirby Ultimate G Bagged Upright Vacuum
I want to kill my kirby
Follow these instructions step by step and it should help with the problem...
Hope this helps,
Jun 20, 2009 | Kirby G4 Bagged Upright Vacuum
G-4 Kirby self propel unit works in reverse but not foward
Here is a helpful link to use to adjust the tranny. About a 7 on the difficulty level.
Dec 10, 2008 | Kirby Ultimate G Bagged Upright Vacuum
Kirby ultimate g
Vibrating – that usually happens on some short fiber or very dense carpets. When nozzle goes against the carpet fiber Kirby starts jumping. Try vacuuming the same place while facing opposite way.
Belt – red arrows means DISENGAGE. When you install the nozzle on the Kirby unit while green arrows match you will not be able to turn it on red. You must follow sequence (starting from nozzle off the Kirby, green arrows match, Kirby front lifter all the way up by pressing one of the pedals):
1. Turn Kirby knob to match red arrows. You will feel some tension and hook inside of the nozzle is supposed to catch the belt and stretch forming a loop for the Kirby shaft.
2. Put the nozzle on the Kirby and lock it on with the latch.
3. Twist the knob back to match the green arrows. YOU ARE DONE
Go to Kirby vacuum online manual. There are some small details that you may want to pay attention to if you have removed the brush roll to install a new belt. Also there are some pictures that will help you understanding the process.
Sep 27, 2008 | Kirby Ultimate G Bagged Upright Vacuum
Sweeper vibrates when pushed forward.
do u put it on drive or neutral? does the wheels spin when on drive? is the height adjuster on the right level?
Sep 09, 2008 | Kirby Ultimate G Bagged Upright Vacuum
Kirby Ultimate G Bagged Upright Vacuum Logo
356 people viewed this question
Top Kirby Vacuums Experts
Mike Cairns
Mike Cairns
Roger Potts
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
