Question about Dell Latitude D600 Notebook
Dell Latitude Notebook D600
Shutdown completely while I was using it. Power cord was plugged in and light on power box was lit. When I press the power on/off button I get no response, not a light or a power hum. What do you think the problem might be and how do I fix it or get it fixed?
  • 191 Answers
You may try
1) check the battery charging light is on or off, if off
2) take out the battery and power on
- if ok then put back the battery then power off and power on.
- if not ok go next
3) sometimes D600 cause adapter problem with the sentre pin so you need change another adapter to test as well
Marry Cristmas
Posted on Dec 27, 2008
    Scholar:
  • 108 Answers
The laptop probably overheated.
I would get a cooler for the laptop they sell them at wal-mart or stores such as that one.
It's a small thin table like that the laptop sits on and it has 2 fans pointing up at the bottom of the laptop.
Unplug the power supply then hit the on button and try it if it don't work unplug the battery then try that.
Happy Holidays
Speakers won't power on when plugged in
firstly check your power cable by moving the wire in various directions while it is plugged in ac outlet and powered on, if it lit up the standby power LED then the prob lies on the power cable. If not, try opening the speaker system box itself (be sure to unplugged the power cable before opening the box), then visually check inside for the little cylindrical glass type tube(if the circuitry still uses this kind of fuse) if it is burnt-out.
Hope this help pal...
Feb 23, 2013 | Labtec Pulse 285 Computer Speakers
Hp officejet 6500 all lights are flashing and mechine says turn off and on . Please can someone Help??
: Check the power cord
1.
Turn on the product.
2.
Remove the power cord from the back of the product.
3.
Check the power cord for any physical damage. If the power cord is damaged, replace the power cord.
If these steps resolved the issue , you do not need to continue troubleshooting.
If the issue persists , continue to the next solution.
Turn the product off and then on again
1.
Press the Power button ( ) to turn the product off.
2.
Wait 60 seconds, and then press the Power button ( ) to turn the product back on.
3.
If the product does not turn off when the Power button ( ) is pressed, wait three minutes, and then proceed to the next solution.
Plug the product into a wall outlet
Follow these steps to make sure the product is plugged in correctly.
1.
Unplug the power cord from the back of the product.
2.
Unplug the power cord from any surge protectors or power strips.
3.
Select a wall outlet to plug the product into. Test the wall outlet by plugging another electric appliance, such as a lamp, into the wall outlet and turning it on. Unplug the test appliance.
4.
Plug the power cord into the back of the product.
5.
Plug the power cord into the wall outlet.
6.
Press the Power button ( ) to turn the product on.
Solution six: Reset the product
Follow these steps to reset the printer.
1.
2.
Unplug the power cord from the wall outlet.
3.
Wait 10 seconds, and then plug the power cord back into the wall outlet.
4.
NOTE: Many power cords have an LED light on the power module or on the end of the cord that plugs into the product. Make sure the LED light is lit and steady.
5.
6. Perform a partial reset of the product
  1. Disconnect the power cord from the product.
  2. Wait for 20 seconds.
  3. Press and hold # and 3 while reconnecting the power cord.
  4. When the product turns on, release both buttons.
  5. Try printing again.
IF still won't resolve it by following steps mentioned above then your printer needs replacement. Malfunctioning hardware.
Mar 28, 2011 | HP Officejet 6500 Wireless All-in-One...
Okay so first off I have ALOT of important docs and what not on my laptop so it is a must that I require these items ! okay So I just got back from Denver and had used my laptop only once and it worked...
Sounds like a graphic card problem. You should be able to remove your hard drive and connect it to a desktop computer and access the drive and get your important files.
Aug 06, 2010 | Toshiba Satellite A215-S5837 Notebook
I have a new printer and it has no power
Plug the printer straight to the wall power outlet, bypass any surge device or power strips. If still no power. Unplug the power adapter from the printer. The power adapter is the black box behind the printer where the power cord is attached. With the power cord still attached to the power adapter and the other end plugged in to the wall power outlet, the LED, found around the silver contacts on the adapter, should lit green. If it's not lit, make sure the power cord is properly secured in it. Otherwise, you're looking at a defective power adapter. If that's the case, I suggest you contact Lexmark Technical Support and request for a new power adapter for your printer. They can send you one for free. If it's lit, plug it back in the printer in the right position. If it won't automatically power on, press the Power button. If that doesn't help, the problem might be on the printer itself. Again, if that's the case, I suggest you contact Lexmark Technical Support. Hope this helps.
Jun 23, 2010 | Lexmark X3650 Printer
Improper Shutdown Message
1. Disconnect the power cord from back of printer ( while printer is powered on )
2. wait for 10 seconds
3. hold and press the Power button and connect the Power Cord.
4. Release the Power button after 3 seconds
5. Follow the Instructions on the printer screen.
Later try to shutdown it, it should not give the message again
Jun 16, 2010 | HP Photosmart C6180 All-In-One InkJet...
Latitude D600 PC Notebook: dell d600 three light on and of problam...
This is do to the jack were the power button board plugs into the motherboard, i see this alot on d600 and d610, the lights come on for about 3 sec then computer turns off..
this can be fixed by resoldering the plug to the motherboard but most will say you need a new mother board the leads are small and tight together..
Used motherboard on ebay $60-150
May 17, 2010 | Dell Latitude D600 Notebook
I put a new black printer cartridge in and now it doesn't power up at all. I replaced the printer cartridge with the old printer cartridge and it still isn't powering up. I replaced the power cord,...
With the green light lit on the power box or power supply of the printer, that indicates that there is power flowing. But just to make sure it's getting enough to power the printer on, bypass any power strips or extensions, if you're using one, and plug the power cord straight to a known working power outlet. Make sure the power box or the power supply is inserted all the way in the slot and in the correct position behind the printer. Press the power button if needed. Hope this helps. If it's still not powering on, I suggest you contact Lexmark Technical Support for further assistance.
May 04, 2010 | Lexmark X4690 Wireless InkJet Printer
My Gateway 700X PC (Windows XP) will not Shutdown/Will not Start.
Best to format and reinstall a fresh copy of your operation system.
Regards
Feb 24, 2010 | Gateway 700 X PC Desktop
States scanner failer; turn off ;then on; have
Solution one: Check the scanner light Make a color copy of any document by pressing the Start Copy Color button on the product control panel. While the product is making the copy, lift the scanner lid slightly to see if the scanner light is visible. CAUTION: Do not look directly at the light. It is not necessary to completely open the lid to see the light.
  • If the scanner mechanism moves across the scan bed, but the light is not lit, proceed to Solution six: Service the product .
  • If the light is lit, proceed to the next solution.
Solution two: Check operating conditions Extreme temperatures can affect the operation of the product. Make sure the operating conditions match those recommended in the User Guide provided with the product. Solution three: Check the power connections
  1. Make sure that the part number on the power supply matches the part number listed in the User Guide .
  2. Disconnect the power cord from any power strips or surge suppressors, and then plug it directly into a wall outlet.
  3. Try making a color copy by pressing the Start Copy Color button on the product control panel.
    • If the copy job is successful, you do not need to continue troubleshooting.
      NOTE: Power strips and surge suppressors can sometimes prevent enough voltage from reaching the product.
  4. If the error message displays again, temporarily move the product to a different room, or plug the power cord into a different wall outlet.
  5. Try making a color copy by pressing the Start Copy Color button on the product control panel.
    • If the error message displays again, proceed to the next solution.
Solution four: Perform a power cycle
  1. Turn the product off.
  2. Unplug the power cord from the product.
  3. Wait 30 seconds, and then connect the power cord to the product.
  4. Turn the product on.
  5. Make a color copy by pressing the Start Copy Color button on the control panel.
Solution five: Reset the productFollow these steps to reset the product. Step one: Perform a partial reset
  2. Press and hold # and 3 while reconnecting the power cord to the product, and then release both buttons.
    • If the partial reset resolves the issue, you do not need to continue troubleshooting.
    • If the error message displays again, proceed to the next step to try a semi-full reset.
Step two: Perform a semi-full reset CAUTION: Performing a semi-full reset deletes any saved phone numbers on the product.
  2. Press and hold # and 6 while reconnecting the power cord to the product, and then release both buttons.
    • If the semi-full reset resolves the issue, you do not need to continue troubleshooting.
Solution six: Service the product If you have completed all the steps listed above and are still experiencing a problem, service the product.
Jan 26, 2010 | HP OfficeJet 7410 All-In-One InkJet...
Dell Latitude D600 Notebook Logo
67 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
