Question about Casio G-Shock GW500A-1V Wrist Watch
Cannot delete Thanks for the previous answer (regarding the role of left upper display), apparently it's an emulation of an analog display. I successfully synchronised both manual and automatic the watch but an annoying "E" sign persist on the display. It first showed when I tried to manually synch it in the offfice (unsuccessfully) and ever since it stays on. Was hoping that after OK synch it will dissapear along with the signal sign (as set by the factory at 3 am) but it didn't. Can you help? Thanks
  • 3 Answers
Dude, I think it is an "E" for eastern time. Check and see if it changes to a "P" when you change to pacific time in the world time mode. If it does that is what the "E" is for. Hope this helps, it took me a long time to figure it out.
Posted on Jan 19, 2009
    Problem Solver:
  • 6 Answers
My watch has a tiny letter just to the right of the signal strength indicator. In my case it is a C because I live in the central time zone. Perhaps you live in the eastern time zone? The E may not be short for ERROR but instead stands for EASTERN. Its called the E/C/M/P indicator.
I don't know if you have had a chance yet, but the manual that I talked about previously does show this feature on the first page. Its called "Operation Guide 2608 2638 2688". Your watch almost certainly has a 2688 module.
I hope that was the E that you were talking about.
As for the signal sign, you want it to be there. You need to worry when its absent. :-) I think all waveceptors are like that.
I hope that helps.
Posted on Dec 28, 2008
I have a disallignement of 10 minutes between the digital and the analogical time. The digital time is perfect how can I allign the analogical one?
You have to know that analog time "follows" digital time.Any hour/minutes correction on the display has direct effect on time/minutes hands.Some times, mostly after battery replacement,hands might have declination.That is why there is a function so called "Hands home position adjustment".Using this function you can align both hands to 12/00 position.If there is any declination (I think is your case) you can correct.Try to enable this function by pressing for 4-5 sec the upper left button(A) until "HAND SET" appears.If hands are not aligned exactly to 12/00 position, you must correct by pressing the lower right button (D) for forward movement or the upper right button (B) for backward movement.In fact, minutes hand is aligned,hour hand follows.When both hands are set to 12/00 (home position) press button A again.Time Mode returns to the display.Normally hands will now show exactly according to digital (display) time.I hope this will help.
May 23, 2015 | Casio WVA105HDA Wave Ceptor watch
How to set the time and analog time of CASIO ILLUMINATOR0 SGW 400 h
set the digital time: press and hold upper left button, then the seconds blinks use the lower left button to choose what are you going to set ( the one that blinks is the one that can be set ), use the upper right button to set. when your done. press the upper left button once.; set the analog time: from the time mode of the digital press mode until you see the "H.SET" , then the time of the digital appears, then use the upper right button to set the analog time, when your done just press the upper left button once and use the lower left button to bring back the time mode. i hope this will help you a lot.
Aug 13, 2011 | Watches
I have a casio ediface 5033 80W-M10008 how do I set the analog time
Thank you for contacting FixYa.
To set the analog time, press the lower left button 6 times. Next, press and hold the upper left button until the digital time starts to blink. This indicates that you are in analog time setting mode.
Analog time adjustment is completed using the lower right button. Every time you press the button, the analog time will advance 20 seconds. If you need to make a big change to the analog time, press and hold the lower right button to make the hands move faster. Once the analog time is set, press the upper left button to exit the analog time setting mode.
Best regards. Jewel
Sep 15, 2010 | Casio Edifice EFA109-7AV Wrist Watch
How to set the hands to match the correct digital display on my Casio wave ceptor 2734 wva-104h watch
Setting Digital Time
  1. The digital timepiece on a watch is set using the function buttons on the outer part of the watch face. To set the digital time, press and hold the upper left button until the seconds starts blinking. Press the lower right button to reset the seconds to "00."
    Push the lower left button to move to the Daylight Savings Time portion of the watch. Use the lower right button to toggle between "On" and "OFF."
    Press the lower left button twice. The hours unit will start blinking. To advance the hour, press the lower right button repeatedly until the correct hour is displayed. If you need to move the hours unit backwards, press the middle right button until the correct hour is displayed. When the hour is set, press the lower left button to switch to minutes, and use the same commands to change the minutes unit.
    After the time is set, press the upper left button to exit the digital time setting function.
  2. Setting Analog Time
  3. You may find after setting the digital timepiece that the analog display does not match. When this occurs, you need to set the analog time. To set the analog time, press the lower left button 6 times. Next, press and hold the upper left button until the digital time starts to blink. This indicates that you are in analog time setting mode.
Aug 21, 2010 | Casio Watches
How to set clock time on casio aw- 81 time
http://ftp.casio.co.jp/pub/world_manual/wat/en/qw2747.pdf
A - upper left button
B - upper right button
C - down left button
D - down right button
In the Timekeeping mode, Precc C six times to enter to Hand Mode
Hold A until the current digital time start
Hold D to advance the analog time
If you like advance the analog time a long away, press D + B the same time. Press A to exit the setting screen.
To return to the Timekeeping mode press C
Aug 18, 2010 | Casio ILLUMINATOR DUAL TIME MEN WATCH...
Put new battery in wave cepor now can't get it in proper time zone. # on back, boxed [2735] WVA-105H
It may well be that the digital time displayed on the LCD is correct, but the hands (referred to as analog time in the manual) do not match.
If this is the case, to set the so called analog time:
Press the lower left button six times to enter HS (hand setting) mode.
Then press and hold the upper left button until the display starts to flash.
You can now use the two buttons on the right to move the hands forward or backwards to exactly the same ime as the digital LCD display.
When finished adjusting the hands press the upper left button one last time to exit.
Jan 07, 2010 | Casio WVA105HDA Wave Ceptor watch
Reset watch
Hi
Thanks for using FixYa. You can set the time on your accurist watch by following this procedure--
TIME SETTING--
1. Push the bottom right hand button until the mode hand indicator points to TME.
2. Press and hold the upper left button for three seconds. The hour and minute hand will retract to the 12 O’clock position.
3. Select the time zone on the digital display by pressing the upper right button or the lower left button.
4. Pull the bottom right button out one click. The bottom part of the digital display will start flashing. Press the bottom left button to adjust for daylight saving time.
5. Press the upper right button. You will see the seconds flashing on the lower half of the digital display. Press the lower left button to reset the seconds to 00.
6. Press the upper right button. You will see the minutes flashing. Press the lower left button to set the minutes to your current time.
7. Press the upper right button. You will see the hours flashing. Press the lower left button to set the hours to your current time.
8. Press the upper right button. You will see 12H or 24H flashing. Press the lower left button to switch between 12 hour and 24 hour.
9. Push the lower right button back in.
SET THE CALENDAR--
1. Push the bottom right hand button until the mode hand indicator points to CAL.
4. Pull the bottom right button out one click. You will see the month flashing on the digital display. Press the lower left button to change the month.
5. Press the upper right button and the date will begin flashing. Press the lower left button to change the date.
6. Press the upper right button. You will see the year flashing. Press the lower left button to change the year.
7. Push the lower right button back in.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Aug 31, 2009 | Watches
What's the role of the first display (left upper corner) Casio-GW500A-1V? Simply couldn't figure out after reading the owner manual. Thanks
I really should have chosen to make the previous message a "solution" rather than a "clarification request. Regardless, a MUCH better manual than what comes with the unit can be found at
http://world.casio.com/wat/download/en/manual/
Here you can type in your 4 digit module number and get a great document that tells you how to operate your unit and some of how it works. (Adobe Acrobat - PDF file)
Unfortunately it doesn't explicitly answer your question, but its a much better manual.
I really do think each "pie slice" represents 5 minutes.
Enjoy!
Dec 25, 2008 | Casio G-Shock GW500A-1V Wrist Watch
Cant se time Citizen 8988-q02047 HSB wristwatch
In the time mode, press the upper right button for 2 seconds and the time display will flash. Then press the same button untill the entire time will flash, or both hour and minutes flash at same time. When the hour and minutes flash at same time, this adjust mode is the adjusting of the analog left display (A1). Now, press the lower button for adjusting de hour shown at the digital display that shows the same hour at analog display. This method is to adjusting the 8982 that is the "father" of 8988. Like a Citizen collector, and don´t know any website that you can view the setting instruction of 8988, only the 8982 is disposable here: http://www.citizenwatch.com/downloads/techguides/8982.pdf
Nov 20, 2008 | Citizen Watches
Casio G-Shock GW500A-1V Wrist Watch Logo
140 people viewed this question
Top Casio Watches Experts
Kazim ERGUNEY
Kazim ERGUNEY
Ansel Alberto
Ansel Alberto
Are you a Casio Watch Expert? Answer questions, earn points and help others
