Forgot my password
Forgot lenovo password? You can use Smartkey Password Recovery to help you to reset lenovo password, and see the detail direction from http://www.recoverlostpassword.com/
SOURCE: reset factory password on t61 lenovo
password for what? bios or windows?
if it's the windows password, press the f8 key before windows starts and choose safe mode, choose administrator for the username and then go to user accounts and remove the password for your account.
if it's the bios password, you have to strip the laptop and pull the bios battery on the system...it looks like a large watch battery but becarefull not to break anything.
SOURCE: Lenovo S series ideapad will find my dlink router no network addr
Generally if you can see the D-Link then everything is trying to talk. Would have to know if the d-link is new out of the box or is part of an existing setup. If the d-link has been part of the network I would suggest that you don't have the security settings correct. If you right click on the network icon and look at the send received numbers. If received is zero then your problem is you don't have the security key (WEP or other type)) setup. If you are getting recieved numbers you may not have the DHCP setup in the d-link. DHCP assigns the numbers to the computer but the d-link has to have this turned on in some models others it is by default.
If both your laptop and dlink are not new and specifically about a year old then I would also suspect that the dlink has died or is dieing on you. If you have had periods of disconnects or slow jerky network acess then these are signs of the dlink having problems. The wireless part tends to go after a year or so while the wired portion probably still works. When they go they are annoying as they work then they won't and so on.
That is you next step to try is to plug in your laptop direct to the wired connection on the dlink to test if the problem is the wifi portion of the dlink. If it connects your problem is the wifi and you probably will have to replace the unit. Next plug it into the cable modem and see if the problem was in the dlink itself.
SOURCE: i am forgot bios password
The only simple way to Erase the forgotten Bios Password is to Reset the CMOS Battery.
SOURCE: how reset bios lenovo ideapad
Just before the machine boots, press the relevant F button to enter Bios menu and select default setting in the exit page.
SOURCE: hi i got a new
click start control panel,display,desktop you can select a different desktop from the drop down list. hope i have seen you in Tnagar browsing centre. way long time back. Long hair.
As many as two passwords may be needed for any Lenovo IdeaPad computer: the power-on password (POP) and the supervisor password (SVP). If any of these passwords has been set, a prompt for it appears on the screen whenever the computer is turned on. The computer does not start until the password is entered.
Exception: If only an SVP is installed, the password prompt does not appear when the operating system is booted.
Power-on password
A power-on password (POP) protects the system from being powered on by an unauthorized person. The password must be entered before an operating system can be booted.
Supervisor password
A supervisor password (SVP) protects the system information stored in the BIOS Setup Utility. The user must enter the SVP in order to get access to the BIOS Setup Utility and change the system configuration.
Attention: If the SVP has been forgotten and cannot be made available to the servicer, there is no service procedure to reset the password. The system board must be replaced for a scheduled fee.
Sorry hope this helps a little good luck
