Netbook won't connect to my home network
Trying to connect new netbook to my home network system. Have main computer and laptop which work fine with my Tiscali broadband, but when trying to set up my new netbook, it says it is currently connected but is 'aquiring network address' in the 'Wireless Connections' box. Have phoned Tiscali who took me through 40 minutes of problem solving - to no effect, and also contacted Medion about the E1210 netbook, who also couldn't solve the problem. Medion have told me to try and remove the Bullguard protection, but it won't remove via the Add/Remove programmes in the Control Panel.
  • bridgie babe Dec 27, 2008
    have jusy bought a sw-e700 notebook but cannot connect through wireless but have another laptop which connects no problem i have tried to connect at my sons house and was successful .when trying to connect it says invalid address although it saya connected it will not display web page please help
I re-typed in the WPA number in the new netbook, which has now got it working. I found the WPA number by typing in a number Tiscali gave me to search for my router information (Netgear) in the search bar on my main computer and getting my WPA key from there.
Posted on Dec 28, 2008
No internet connection over wireless netwok
first of all make sure your wifi is turned on. In the lower right tool bar next to the time & date, click on the wifi, click open network & sharing. Click manage wireless networks. Hilight each and remove until it is completely empty. Restart your computer & you should be fine. If not there is a physical problem with your wifi.
luck,
cwynnj@yahoo.com the computer guy
Dec 19, 2011 | Acer Aspire One Netbook 8.9" Notebook
I have a 'new' aspire one netbook and i cant make work. it says in need to be connected to a network. ihave an acerlaptop that works just fine on network 7AP13. i am connected verizon fios and am not
That means there is a corrupt or a missing wireless driver on your new acer laptop. First of all if you are using Windows XP follow the following
1. Go to start
2. Right-click on "My computer"
3. Go to "Properties
4. Go to Hardware tab
5. Go to Device manager
In the device manager check for any yellow question mark or an exclamation mark. Especially on the network adapters. That means if you had the network drivers working before, then they are corrupt or they are not there at all.
Here is the solution..
visit acer.com and go to their downloads and support tab, you will be abel to see the model of your computer and you can download the wireless drivers that are compatible with your laptop.
Nov 15, 2011 | Acer Aspire One PC Notebook
Bought daughter a 7" Sylvania netbook for X-mas,
See: http://digitalgadgets.com/netbooks/support-7in-netbook.htm for a detail of how to connect. If that does not work then see my how to at: http://www.fixya.com/support/r7350901-fix_synet07526_wifi_flashing
You may also see:
Wait for the little computer icon in the lower right corner to show two radiating side waves with a red X under the icon. The red X indicates that the WiFi has not connected. double click on the Computer icon and a window opens up with RT28701 as the header, with all zeros in the fields.Click on the tab Wireless Information. and a new window opens up. Look for the name of your home wireless network, and double click on that name. another window will open up called Network Properties and you will see some entries, with the name of your network as the SSID. go down to the key box that says The key is provided automatically, and uncheck that box. At the long box that says Network Key type in your code for the network key. This code was assigned when your network was set up to prevent someone else from accessing your network. When you finish, check the box The key is provided automatically and from then on your machine will connect automatically because it will remember your key.
Dec 18, 2010 | Sylvania G-Netbook
Laptop wont connect to wireless network but desktop is fine.
Perhaps, it just needed a new IP address. Simply rebooting the computer and resetting the IP Address of the computer took care of the issue.
or
That sounds like symptoms of Manufacturer & Windows drivers conflicting. Try uninstall the Manufacturer Drivers and let the windows ones do the work, and see how that goes down.
Apr 20, 2010 | HP Mini 1000 Netbook
Internet signal is fine, works on main computer but not on laptop
download the driver here
http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?os=19&softwareitem=dj-28354-1&lc=en&dlc=en&cc=us&lang=en&product=57565
Apr 03, 2010 | Linksys Wireless-G WRT54G Router
Cannot get Toshiba Netbook connected to wireless network
ok. try this:
open a computer on your network that connects to the network. start -> run -> type cmd and click enter.
then type ipconfig /all
then open your laptop.. go to local area connection and click properties.
click internet protocol on the list and then properites.
click on "use the following ip"
and on the three text boxes below type the same settings as the ones that appear on the pc that you did ipconfig /all. the only differnt will be the ip address. if the pc is 192.168.0.105 you should put 192.168.0.106 or something else.
do the same with dns server.
click ok to close all the opened windows and check the new ip of the laptop
Jan 25, 2010 | Toshiba Mini NB205-N313/P Netbook
I can't connect to the internet on my ACER Aspire One aod150-1920 netbook running XP. I am connected to my home network (wifi, excellent strength) but IE, Skype, Mcafee won't connect. Laptop and desktop...
Most Acers use an IPN2220 Wireless card. If yours does and your router is using WPA or WPA2 (TKIP or AES) security then you'll need to update the driver by searching for it manually using the Custom button (Hardware) in Windows update (instead of Express). This driver is not part of XP service pack 2 or 3. In my experience if you don't update to the newest common form of home wireless security (WPA2 AES) then the older formats seem to become unreliable
Nov 02, 2009 | Acer Aspire One AOD150-1920 Netbook
Brand new Dell netbook won't connect to internet (at home). Connects fine at work. Wireless strength is good at home but no internet connection. Husband's notebook connects just fine so it appears to be an...
No, it's probably because you have setup a wireless home network with security in place.
Go through the settings on your husband's notebook settings for your home network and set your Dell up the same way. You will need to know the SSID for the wireless network, security type and key to set it up.
Oct 28, 2009 | Dell Computers & Internet
Advent 4213 netbook not connecting to wireless network
Have you entered the security details regarding your network connection into your new netbook.
Sounds like the problem.
Detect the network and enter the security key (WEP;WAP etc) and should work
Jul 11, 2009 | Computers & Internet
Computers & Internet Logo
822 people viewed this question
David Payne
David Payne
