Limited connnectivity on a data cable
My son has had an X-box 360 for xmas. I have run a new cable from a Linksys WRT54GS router to his room (distance approx 15mtrs). To test the function of the new cable I connected my laptop to it. It took a long time to 'see' the connection and when it did I gave a 'limited connectivity' message. Incoming source is via Vigin Broadband, through a set top box to the Linksys router.
We have another PC that i wired in which works without any problem, as dows my laptop on the wireless network.
Any suggestions?
Thank you.
    Problem Solver:
  • 13 Answers
There are several possible causes for this error. As mentioned before there is a chance that the cable is not a 568A or 568B standard. I suggest trying a 568B standard cable for an xbox. and be sure that the router is handing out IP addresses correctly. the wireless connection may act differently than a wire connection, but you home router is likely handing out IP addresses from the same 192. address pool. the distance should not be a problem if the cable is a valid cat5 standard cable. to make it easy use a different wire and see if that resolves it. If not rest the router. If that does not work the router setting need to be adjusted. also consider assigning an ip address to the xbox. I do not know if you can manually set the ip address on an xbox.
-good luck-
Will
www.compressionconnector.com
Posted on Feb 19, 2009
    Problem Solver:
  • 10 Answers
Sounds like you have a cross over cable which your pc will detect and the laptop is not, nor will the xbox. you should be able to see the colors in the ends through the plastic, they should be B scheme on both ends, or in laymans terms it should be brown/brownwhite-green-bluewhite/blue-greenwhite-orange/orange white on both ends. if its a cross over the orange and green will be swapped on one end. Id use another cable and hardwire the laptop to that same port and make sure its not a router problem though too.
Posted on Feb 07, 2009
    Problem Solver:
  • 13 Answers
If you made the cable, I would start with the wire setting in the plugs. When I make cables, this is the biggest mistake that I make (I spend an extra $10 some times in remakes). Then make sure that the correct cabling schema is used for the XBox, I am not sure if it uses the standard T-568-B or T-568-A. This could cause some problems.
Additionally, I would check to see if the IP addressing is set up correctly, but it sounds like the cable is the problem, maybe the cable itself, not the connections.
Posted on Jan 04, 2009
I have linksys 2.4 ghz + one 12' line. My new computer is in another room, 32 feet from cable modem how do I connect to internet?
I'm assuming that one computer isn't wife enabled. Depending on where the non wifi computer is located in relation to the router, you will need another either patch cable or a wifi adapter.
Feb 01, 2014 | Linksys Wireless-g 2.4ghz 802.11g W/speed...
My router has been running very slowly, what can i do 2 speed it up? linksys speedboost wrt54gs
Could be your router is slowly going bad. Sounds like time to buy a new one. WRT54GS is pretty old at this point in time.
Oct 30, 2012 | Linksys Wireless-G WRT54G Router
My son gave me an older computer and wireless Linksys-G model WRT54GS router. I bought my wife a ipod for christmas and in the setup of the ipod it is asking for a password for the router. My son does not...
Reset the router to default....the default username and password is usually on the bottom of the router..then open a web page on your pc and connect the router with a network cable..type 192.168.0.1 or 192.168.1.1
Use the generic name and password to logon....once logged in, configure username and password and wifi...once setup..save and exit..disconnect and connect router to internet modem...log onto pc and look for your wifi neteork name..cheers
Jan 24, 2018 | Linksys Wireless-G WRT54GS Router...
I have been running a Linksys BEFSR41 version 2 wired router for over 5 years without any problems. My wife is a teacher and her school p[urchased new laptops recently so I decided to go wireless. Got on...
I think the most likely problem is that both routers are using different IP address ranges and won't allow data to pass between them.
I suggest you use only the Linksys wireless router.
Nov 17, 2010 | Linksys Wireless-G WRT54GS Router...
1 linksys wrt54gs router 2 xbox 360's and a not open nat setting
connect the 360 to a port in the router and have the internet going straight into ur router ull stay connected at all times as soon as u turn on the xbox itll log on automaticly
Feb 21, 2009 | Linksys Wireless-G WRT54GS Router...
No disk for WRT54GS
You Can Download Your Software From Here
Just Find Out What Version It Is By Looking At The Information On The Router.
Thanks For Choosing Fixya.com
Sincerely,
Michael Scott
Jan 30, 2009 | Linksys Wireless-G WRT54GS Router...
Cannot get wireless router to work with Xbox 360
Does the westell router only have 1 ethernet port, if so a ethernet hub would be better, they can be baught for about £10.
You will need to input your account settings for your broadband conection into your new router for it to work, with this router all you actually need to do is connect it to the 360 with an ethernet cable, if you want to use it wirelessly you need to buy a wireless adapter for the 360 for about £30 - £60 depending where you buy it.
Jan 02, 2009 | Microsoft Xbox 360 Console
Wireless router not communicating with computer
Dont run the CD. Connect the Wildblue to your router via the INTERNET PORT then your computer to ports 1 2 3 or 4. Turn off the router wait 10 seconds then turn it back on and restart your computer. you should be online. you dont need to install the router using the CD.
Dec 26, 2008 | Linksys Wireless-G WRT54G Router
Xbox 360 live on wireless router
In theory you should be able to "share" your internet connection. I use a Linksys WRT54GS wireless router and I have a Linksys Game adapter on my son's 360. He has not complained about lag or slow server times unless other intensive bandwidth is being used.
Nov 09, 2008 | Microsoft Xbox 360 Console
Computers & Internet Logo
101 people viewed this question
David Payne
David Payne
