Question about Sony CDP-CX53 51-Disc CD Changer
Sony CDP-CX53 rotates the carousel and inserts the CD into the playing position, but it won't play the CD
My Sony CDP-CX53 rotates the carousel and inserts the CD into the playing position, but it won't play the CD. I removed the cover to view it better and can see that the player doesn't "grab" the cd to play it.
  • Anonymous Mar 16, 2014
    It will not stop spinning when play is pressed.
  • Anonymous Mar 31, 2014
    cannot open Cd entry door other than by hand,and with top cover removed also find the carousel is locked
  • 68 Answers
It sounds like there is a cd tray alignment problem, there is no quick fix, all i could suggest is to send it to us or take it to your nearest dealer.
Regards.
http://www.audiovisualservices.info/
Posted on Jan 02, 2009
Player won't play discs.. Removed cover, little carousel motor belt wrapped around shaft. Untangled and put back on pulleys but seems loose motor rotates but carousel barely moves
take the belt to your local ace hardware and find an o-ring that is slightly smaller than the belt. Install that and you should be back up and running for less than a dollar.
Apr 04, 2015 | Sony MegaStorage CDP-CX455 400-Disc CD...
ALL DISKS SKIP ON MY SONY CDP - CX53...SOLUTION?
If you have access to the lased head, gently wipe the lens with a stick with cotton moistened with isopropyl alcohol, or regular sanitary alcohol. Use circular movement. Then, gently shine the lens with dry cotton. DO NOT PRESS THE LENS !!!! If the issue persists, it's more complicated. You need to have access to the tiny trimmer below or near the laser head. Using a plastic screwdriver, rotate the trimmer clockwise about 2-3 degrees. Test playing. If track doesn't skip, hit the CD player's case with the finger, to check if track skips because of shock. If skips, rotate trimmer again 1-2 degr. Check again. If it doesn't work, try rotating counterclockwise. You need patience. Hope it is useful.
Mar 11, 2015 | Sony Audio Players & Recorders
A word Err appears on sony CDP-CX53
The message is its way of telling you it is shot.
Feb 13, 2014 | Sony CDP-CX53 51-Disc CD Changer
Carousel will not turn
Could be a broken/loose carousel belt. take the cover off and look near the back of the unit and make sure that both belts are on there respective pulleys.
Jan 02, 2013 | Sony MegaStorage CDP-CX355 300-Disc CD...
Have Sony cdp-c535 cd player. The door won't stay in. Keeps cycling in and out.
I had the same problem with our 5-CD Sony carousel player CDP-C535 (manufactured Nov 1993). I removed the top metal cover, and loaded five audio CDs into the carousel. After I closed the table, I pressed the carousel tight so that it stayed close, and hit the play button. The CD player tried to push the carousel out with quite a force. I needed to warp me fingers around the front panel to keep the carousel closed. After a few cycles of forcing the carousel to remain close, and caused two separate strong "clucks" from the gear area, the CD carousel became operational again. The diagnosis of gear problem seems right.
Nov 28, 2009 | Sony Audio Players & Recorders
Broken carouself? Can't properly open, close, rotate, etc.
Broken gears. The current replacement 5 disc is a CD/DVD player and sells for $129.00 at Sony or any other Sony retailer. The cost to have a service center even estimate the repair would be more than 50% of the replacement cost. Hope this helps
Nov 19, 2009 | Sony CDP-C265 CD Player
Jammed tray
Hi there, had a similar problem.
This unit is easy to open. the four screws on the sides and two i think on the back. When it is open you will have access to the discs in the machine. the last disc will probably be jammed between the facia and the caddy and will be impeding the carousel mechanism, once removed you should check the functions starting with eject, and again to cycle, load disc position 1 insert disc and check. this player i think rotated the disc on loading to a set position, would have to open one to check. hopefully the carousel is not out of sync and all is well.
May 01, 2009 | Sony CDP-C265 CD Player
Sony CDP-CX300 CD won't play
The rubber drive belt for the c/d load mech is streched or broken,
replace the belts there is another that drives something else so change them both while you have it open
Sep 17, 2008 | Sony CDP-CX300 CD Player
Sony CDP-CX53 51-Disc CD Changer Logo
593 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
