Question about Lenovo 3000 Y410 Laptop
Hi srinu9, I'm facing the exact problem of lenovo
Hi srinue, I'm facing the exact problem of my lenovo,
can't boot anything unless I remove the hard disk,
have you solve this problem ?
is buying new hard drive fix this ?
thank you
    Genius:
  • Lenovo Master
  • 1,102 Answers
Do a disk defrag and a scan disk
and a virus scan if that does'nt help then
do a format
Posted on Jan 17, 2009
Flash bios lenovo 3099-1uu
It sounds like your hard drive may have failed. I would suggest the following to confirm.
  • At the splash screen, press F1 for BIOS Setup Utility.
  • Ensure that you see HDD and that it has a device id next to it
If you can see it, then you may have an operating system boot issue. If you cant see it then it might be an idea to remove the HDD and re-seat it. There may also be a setting in the bios for booting from an older operating systems such as XP. I think it might be a setting similar to "Boot mode set to UEFI" etc.
Another good tool to check hardware and get a device booting that may be missing the boot files etc, is to use an application called HIRENS. It can be put onto a USB stick. You can also do a hard drive test with it
The link is https://www.hiren.info/pages/bootcd-on-usb-disk
To be honest I don't believe a bios update will do anything for you. But you could try loading the default settings etc.
I hope this helps
Nov 24, 2017 | Lenovo Computers & Internet
MY LENOVO G570 KEEP SHUTTING DOWN EVERY TIME I RESTART AFTER INSTALLING OR DOWNLOADING A SOFTWARE OR DRIVER . WHEN I TROUBLESHOOT IT AFTER GETTING IT TO START , WINDOW WAS FORCE TO SHUT DOWN BECAUSE OF...
If you can boot up in SAFE MODE then you maybe able to download the drivers from the Lenovo WEB site.
The same model Lenovo can have different types of network, video and audio drivers and unless you know exactly which one is installed in your Lenovo, you need to download all the drivers and install each driver until you find the right driver.
When you download the drivers, write down the device driver and it's file name so you have a record of which driver you are installing and which directory the unzipped files are located on your hard drive.
Go to the IBM/Lenovo WEB site - support/download page and download the latest Windows device drivers for your model computer, Use this link: -
http://www-307.ibm.com/pc/support/site.wss/product.do?template=%2Fproductselection%2Flandingpages%2FbrowseByProductLandingPage.vm&sitestyle=lenovo&brandind=10&validate=true
Feb 02, 2013 | Lenovo G570
MY LENOVO G570 IS MISSING 3 IMPORTANT DRIVERS CAUSING IT TO SHUT DOWN EVERY TIME I RESTART AFTER INSTALLING OR DOWNLOADING .CAN U HELP ?
Feb 02, 2013 | Computers & Internet
My laptop is missing some inportant drivers causing it to shut down
The same model Lenovo can have different types of network, video and audio drivers and unless you know exactly which one is installed in your Lenovo, you need to download all the drivers and install each driver until you find the right driver. When you download the drivers, write down the device driver and it's file name so you have a record of which driver you are installing and which directory the unzipped files are located on your hard drive. Go to the IBM/Lenovo WEB site - support/download page and download the latest Windows device drivers for your model computer, Use this link: - http://www-307.ibm.com/pc/support/site.wss/product.do?template=%2Fproductselection%2Flandingpages%2FbrowseByProductLandingPage.vm&sitestyle=lenovo&brandind=10&validate=true
Feb 02, 2013 | Lenovo Computers & Internet
Laptop is not switching on
The Lenovo maybe damaged beyond repair.
You should not have turned on your Lenovo and imediately removed the battery then drained the water and place the Lenove in a warm dry place for several days to make sure it was completely dry, then take it to a computer repair shop and get them to check out the Lenovo.
I suggest you take it to a computer repair shop, they may charge you for a quote unless you go ahead with the repair.
You could remove the battery and dry out the Lenovo for several days and then replace the battery and then boot it up. If it does work then I suggest you get a new laptop.
You can remove the hard drive and insert it into an USB hard drive adapter case and use it as an external USB hard drive.
Apr 12, 2012 | Lenovo 3000 Y410 Laptop
Im having an error when trying to turn on my lenovo. The error codes are PXE-E61 and PXE-M0F. Then it says missing operating system. It wont do anything after that. Can you please assist me with this....
pxe-e61 (media test failure, check cable) and pxe-m0f (exiting pxe rom), your laptop is not detecting your hard drive so it cannot boot. Try this, remove anything that it is attached to your laptop (external drive, external camera or the likes) and try rebooting. If that does not work you have to open your hard disk drive bay located at the back of your laptop and carefully remove it then place it back again make sure that the screws are complete and are not loose.
Reply if pulling out your hard drive did'nt work.
Aug 05, 2011 | Lenovo IdeaPad Y550 Notebook
'blank sceen appear on my lenovo ideapad S10 but lenovo and the windows manage to appear after tunning it on and blank afterward
Hi licah,
It seems that your computer is not booting into windows properly at all.
You mentioned you see Lenovo and windows appear then the screen goes Blank afterwards, you can try to Boot directly into the Hard Drive manually just to get everything working or I mean Booting up again but this is a small shot from what you are experiencing but is also worth the try.
turn your S10 machine OFF then turn it back ON and keep on tapping f12 on the keyboard you should see Boot menu on the list Select HDD then press enter this should boot into the Hard Drive, if it does not then you may need to send the system back to Lenovo for a possible reinstallation of windows or on most time we also have the Hard Drive replaced in many cases.
I hope that this Helps.
Have a nice day,
mvincentc
May 27, 2011 | Lenovo IdeaPad S10 - 42312BU Notebook
How to enter the bios to change boot sequence on a lenovo 3000 n500 laptop
Turn on your computer. Press F2, while the initial screen is displayed.
The BIOS Setup Utility screen opens.
Boot priority order look for your had disk here.
order should be
1. cd rom
then 2. hard disk
then 3. usb or network boot device. anything bellow doesn't really matter much.
Oct 01, 2009 | Lenovo 3000 N500 Notebook
Password in ibm r61 bios
For IBM/Lenovo Password
there is solution for all IBM/Lenovo laptop
check this site... http://ja.axxs.net. u need to buy this device Key maker pro...
OR
there is one more way to break password for many laptop ..u need to make com port or printer port and there is software for it ...
check this site http://www.lancos.com/prog.html
Thanks
Mar 06, 2009 | IBM ThinkPad R61 PC Notebook
Laptop is not booting
go back into the bios and reset the bios to defaults, hit F10 to save changes and reboot
let me know what happends
regards
Nov 24, 2008 | Lenovo 3000 Y410 Notebook
Lenovo 3000 Y410 Laptop Logo
69 people viewed this question
Top Lenovo Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
