Question about Panasonic DVD-RV31 DVD Player
Panasonic DVD Player RV-31
DVD player keeps showing HO2 code. ie- will not play discs.
  • tradertob Jan 27, 2009
    We have had our Panasonic DVD-RV31 player for several years now and no problems up until now. My 3 year old son frequently loans DVD's from the library and while watching one this past week, it began skipping around. I noticed a lot of scratches and tried it again, but then got the HO2 message and now no DVD's work. Is this a fixable problem without sending it in? Thanks for any info.
  • Anonymous Mar 01, 2009
    Same.
  • 458 Answers
Spring motor bad need replaced
Manufacturer Panasonic Part Number RXQ0745 Description MOTOR Sub RXQ1218KIT
Posted on Aug 19, 2009
My dvd player does recognise or play disc. After reading a few times it says HO2. Any suggestions?
Try buying a DVD cleaner disc at Radio Shack or Walmart
See if that helps.
You may have some dust on the laser lens
Oct 11, 2010 | Panasonic DVD-RP82 DVD Player
The DVD player doesn't work. The service code HO2
I keep having h20 come up on my dvd play er what does that mean it want play
Jun 04, 2010 | Panasonic sa-ht800V Home Theater Audio...
When i put in a dvd the letters HO2 come up and it doent play the dvd. what it it and how do i get rid of it.
this guy says" February 13, 2006 by Josh · 8 Comments
Filed under: Tech 2 weeks ago my Panasonic DVD-RV41 DVD player showed an error HO2 which more or less means the unit is shot. The problem centers round a spindle issue that is a known design flaw. Basically what happens is that the spindle gets warm, expands, and is then pushing on the top of the player .
Mar 28, 2010 | Panasonic DVD-RV41 DVD Player
The plaver will not play says HO2
1) Dirty or poor pick-up.
2) Sled motor sticking (bad sled motor or contaminated lubricant on the sled rails).
3) Faulty spindle motor. (especially if spindle motor is spinning with top off and no disc inserted).
DVD-RV31 also tends to suffer from dry joints to the surface mount IC's and that could cause all sorts of erratic operation.
Feb 03, 2010 | Panasonic DVD-RV31 DVD Player
Marantz dv4300 dvd player only plays cd's
have you used a cleaning disk to remove dirt from the scanner eye?
May 15, 2009 | Panasonic DVD-RV31 DVD Player
Panisonic DVD RV-31 Wont read any DVD...shows a "Ho2" code
The motor is on its way out - the H02 code indicates motor failure as in it cannot spin the disc. You can sometimes fix it but for how long is anyone's guess. Disconnect from the power, remove the three rear screws and two screws on each side (total 7) and lift off the outer cover. Now if you carefully reconnect the power BE VERY CAREFUL NOT TO TOUCH ANY PARTS INSIDE THE CASE and put a DVD disc in as per normal, you'll will see that when the tray closes, the upper platen (a honeycomb disc) that sandwiches the DVD to the lower platen does not spin - it should. Give a gentle spin clockwise and it should spin up and the DVD will play. You may need to restart if you missed your chance first time. If you switch off and on, eject and close the tray, the spin should happen as normal. If it doesn't, your motor is knackered and not an economical repair. Buy a new player. If it spins time and time again, you may well have temporarily fixed it for a while.
Jan 10, 2009 | Panasonic DVD-RV31 DVD Player
HO2 Error in VCR
I guess either the tape head is dirty and needs cleaning or you should email Panasonic with that question after reading the instruction guide's troubleshooting section.
Oct 17, 2008 | Panasonic DVD-RP56 DVD Player
Panasonic dvd RP82
well I have one of this items, and I could find an exelent tutorial, that show a graphic way to fix it.
http://www.elektr0n.com/dwm/doku.php?id=how_to_fix_the_h07_ho7_error_on_your_panasonic_dvd_player , this is so helpful.
Mar 07, 2008 | Panasonic Televison & Video
Display message HO2.
Hello, though I think it is a temporary solution you can try this:http://www0.dealtime.com/xPR-Panasonic-DVD-S35S~RD-228464823940 Best regards, Arpi
Apr 27, 2007 | Panasonic DVD-S35S DVD Player
Panasonic DVD-RV31 DVD Player Logo
525 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
