Question about Nikon COOLPIX L18 Digital Camera
Possible card read error?
My dad is having problems with his Nikon coolpix L-18. When the camera is turned on it reads "would you like to format this card?" Also when the card is loaded into a source such as computer or another camera it reads:"error" on camera & does not read at all on the computer. I am unfamiliar with what to do for him? Please assist us. thanks
  • 26 Answers
Try take out your memory card see weither it will show you the same error.If not try to change to other brand memory card.
Posted on Dec 27, 2008
Nikon Coolpix S3300 can not read memory card but card works fine in other devices.
Bob. Your camera can work with all modern SD cards. But it is picky sometimes. It like to work with a format the camera makes. So before you use a memory card, do format it in the camera like it is printed in the manual on the bottom of page 18
Oct 29, 2013 | Nikon Coolpix S3300
Hello there, I have a Nikon Coolpix L4, and I'm trying to use a 4GB memory card in it that was most recently used in a Canon digital camera. I'm getting the error that "this card cannot be...
Sorry to tell you, but your older camera will not work with 4GB or higher SDHC cards. Your camera was designed before SDHC format came out. You'll need to use 2GB or less standard SD cards. These are relatively inexpensive these days, and are easily found on Amazon, just in case your local store no longer carries them. For others reading, there are several other possible causes for memory card problems, with troubleshooting steps that may be viewed here.
Jul 09, 2011 | Nikon COOLPIX L4 Digital Camera
Hello, I have a Nikon Coolpix S6000. It has worked well until this evening when I attempted to erase multiple selected images from the camera. It then froze for a minute and when I got it running again it...
Hi
1) Mostly its card problem
2) You must be format your card in your computer
3) Now put your card in camera and format card twies , if error comes again then do this proces again
4) If this not solve your error then tell me
May 29, 2011 | Nikon COOLPIX S6000 Digital Camera
Doesnt read the memory card
Welcome to Fixya, possible reason why the memory card doesn't read by your camera are memory card is not yet formatted,memory card is in write protection mode,memory card requires cleaning,memory card was damaged, memory card is not compatible.
I have here the manual of your camera where you can check all error message and warning signs, together with their solutions. Just click here and please refer to page 156.
I hope this link will give a big help to you.
Please let me know if you have any questions.
Thank you for using Fixya,
seancarlisle
Apr 20, 2011 | Nikon Coolpix S51c Digital Camera
I got message "system error
Having a "System Error" message display on the camera's LCD display generally indicates a problem where the camera will need to come to Nikon for repair. A System Error is a general error which can be caused by many things: lens problem, CF Card problem, general camera failure, etc. Before sending the camera in, check these:
  1. Use the memory card that originally came with the camera (or a Nikon approved card) [/*]
  2. Remove and replace the battery [/*]
Mar 05, 2011 | Nikon Coolpix 8800 Digital Camera
Nikkon coolpix L1 After downloading memory card .. then putting back into camera. Reading says "cannot read memory card." Checked card out at store verified that it is good. Why does it not work in my...
A couple things you might try.. remove the card carefully and check the position of the "lock" tab. Make sure it is fully in the unlocked position - not locked or a point between the two positions. Reinsert and try again.
It sounds lie you're using a card reader to download the pictures - try formatting the card while in the card reader via computer. The card should be completely empty when the format is complete. You can even try copying files to and from the card to make sure its ok and format again. When complete, try again in camera.
If the problem persists, check to make sure the card is on Nikon approved memory card list for use with the Coolpix L1 (provided below):
The following is a list of approved memory cards for the Coolpix L1 digital still camera. These cards have been tested and approved for use with the Coolpix L1.
The L1 uses SD (Secure Digital) memory. Sandisk:
  • 64MB, 128 MB, 256MB, 512MB, 1 GB, 256MB*, 512MB*, 1GB*
Toshiba:
  • 64MB, 128MB, 256MB, 512MB, 1 GB, 128 MB*, 256MB*, 512MB
Panasonic:
  • 64MB, 128MB, 256MB, 1 GB, 256MB*, 512MB*, 1GB*
* - Cards rated for 10MB/s (high speed) Other cards have not been tested. For more details on the memory cards listed above, please contact the manufacturer.
The list came direct from Nikon Support. Other cards may work, but only those on the list are approved. Successful use of other cards can not be guaranteed.
I hope this helps!
Sep 30, 2010 | Nikon D60 Digital Camera with 18-55mm lens
Memory card cannot read!!!
sometimes lapstops and PCS as well as Cameras can go out of line. That is the formatting in a particular PC may not be able to be read in another.
In you case this may not be so, as the card now cannot be seen. It would have been interesting to see if it could have read it before it was formatted by your laptop. Try another card in the camera first. If no other card can be read then the problem is on the read head of the camera.
This may be just dirt or damage, and it will have to be repaired. But try another card first as the card is cheaper than a repair.
Thanlks for using FIXYA
Sep 21, 2009 | Nikon Coolpix 5900 Digital Camera
Nikon 4300 CF Card Erro
The Nikon Coolpix 4300 only supports the FAT16 filesystem, so it can only support a 2GB partition. To support 4GB you need a FAT32 filesystem.
Put the card in a CF writer and attached to a PC or Mac. Partition 2x2GB partitions, then format them as FAT16. Now put it into the Coolpix 4300 and it should work.
Jul 29, 2009 | Nikon Coolpix 4300 Digital Camera
Reading mem card
Try to Format the memory card Either in Camera or COnnect it to the computer and format it..Thank you..
Jul 26, 2008 | Nikon Coolpix L11 Digital Camera
Nikon COOLPIX L18 Digital Camera Logo
126 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
