Question about LG (GSA-4167B) DVD RW Dual Layer Burner
Playback stutter Fitted an LG GSA 4167B disc drive to my desktop and dvds that play ok on other players stutter all the time when played on Real Player with a grated sound that is not in sync on audio.Can you please help?
  • 1 more comment
  • tony brownless Apr 22, 2007
    Thanks but I have tried it on Power DVD version 4.0 and its just the same and I don't know how to try it in Windows media player as I am pretty new to this media
  • tony brownless Apr 25, 2007
    Many thanks for your trouble but the problem is no more.I re-installed my old CD/DVD player to prove it was the LG writers fault,they played back OK.On replacing the LG the problem vanished and all DVDs now play back as they should on Power DVD.
    Why I dont know but you probably will.
    Thank you once more,its good to know someone cares about problems
    Tonx.
    President:
  • 2,961 Answers
Realplayer is ok for small .wav files and for browsing videos on the internet, but for watching a dvd i would use either Power DVD or Windows media player as they have all the supported sound and video codecs Some media players have truoble reading different dvd depending on how they were burned or the file quality.
Posted on Apr 22, 2007
SOURCE:
My lg bd50 is able to play any normal dvds however it is unable to play any bluyray dvds!!! when a blueray is loaded into the machine you cannot even eject the disc for sometime. i downloaded updates to...
hi,
blue ray players takes one to two minute to read the content. it will not read as fater as dvd. give some time and then find out what the player says. error or no disc. also check ur BD's region and the region of the disc u inserted. BD's comes with only one region.
ok
Dec 17, 2010 | LG BD350 Blu-Ray Player
My LG DVD RW can not play DVD
Are you sure that your ROM can't play the disc or is it that you don't have a program to play the disc? To my knowledge Windows XP didn't come packaged with a DVD Decoder program; except for XP Media Center. There are some FreeWare programs out there that you can download, or you can pay for the program that decodes DVDs so that you can watch them. If your DVD isn't recognizing any type of DVD that you put into the ROM, then try playing a CD\DVD player cleaning disc in it. If that doesn't work, then you will probably have to get another DVD-ROM.
Jun 06, 2010 | LG GSA-H42N 18x DVD RW DL IDE Drive...
LG GSA 4163B DVD±RW dvd playing but no sound
Install k-lite codec pack ,you are missing codec. Some recommend vlc player.
Apr 06, 2009 | LG GSA 4163B DVD±RW Dual Layer Burner
Lg dr4912
fitted a new drive in but it wont play normal dvds.
it recognises +- discs and formats them as it should
just need to work out how to make it play normal dvds.
dont want to pay for advise thanks
Mar 06, 2009 | LG DR-4912 DVD Recorder
LG gsa-4167B DVD-ROM crashes system 90% of time when I use it
I have the same problem. Now Can not even install the OS back.
Mar 01, 2008 | LG (GSA-4167B) DVD RW Dual Layer Burner
DVD disk
check to see what format your computer burns on.[ex:dvd-r, dvd-rw,dvd-+r,dvd-+rw]different dvd players play certain dvd formats.the format for burning on your computer is probably different from the dvd players that aren't playing the disc.you also must finalize the burned disc.
good luck
wg
Feb 01, 2008 | LG (GSA-4167B) DVD RW Dual Layer Burner
DVD Writer does not respond when DVD movies are inserted..
YOU WILL PROBABLY CHANE THE REGION SETTING TO GET THIS DRIVE TO PLAY THE DVDS FROM Canada
Jan 16, 2008 | LG (GSA-4167B) DVD RW Dual Layer Burner
DVD driver and handycam dvds
None at all - the DVD player has a chipset that is incompatible with that type of disk.
Check the player manual for the disk types it can handle
Dec 17, 2007 | LG (GSA-4167B) DVD RW Dual Layer Burner
LG GSA-4167B DVD Writer... PC restarts whenever any CD is inserted
What is happening is that the dvdrom firmware or the laser is failing and cannot read the disc; and because the pc is using all the system resources trying to do so; it appears that you cannot get anything to run, making it seem as if the hard drive is faulty also, though not the case. You will need to replace the drive if this is a common occurance, as the life of a dvd drive nowadays dependant on use is aprox 2 years, because as the prices come down so does the quality of the laser required to burn and read discs.
Aug 25, 2007 | LG (GSA-4167B) DVD RW Dual Layer Burner
I am having a LG DVD writer GSA-4167B currently stops reading or writing disks after few runs
as with all writers eventually they fault at the lens and it gets out of line and cannot read discs, you can try the usual thing of checking LG for any firmware updates, but first:- Go to my computer>right click>hardware tab>device manager, then down list to cd/dvd drives and click '+' sign and highlight your writer, right click on it and select uninstall. Restart PC and it will be automatically re installed, try again and if no change you will need to replace the drive as they are cheaper nowadays.
Jun 19, 2007 | LG (GSA-4167B) DVD RW Dual Layer Burner
LG (GSA-4167B) DVD RW Dual Layer Burner Logo
94 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
k24674
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
