Where can I get a sub-woofer?
From a wrecking yard is about the only place unless the Ford dealer can supply it, call them first..
Crutchfield.com has them
SOURCE: Need to have diagram for fuses in 1989 Lincoln
Go to the link below and you will see the diagram for the fuse panel in your car. You can click on the picture to enlarge it as well.
http://www.repairpath.com/rp.asp
SOURCE: lincoln town car body-4d
it would be a single cd unit in the dash or a cd changer in the trunk
SOURCE: 1997 SIGNATURE LINCOLN TOWN CAR, THE RESET SWITCH FOR FUILPUMP
The inertia switch should be located in the trunk, on the right-hand side, behind the feltlike trim material.
SOURCE: My trunk latch on my 1997 Lincoln Town Car,
replace the electrionic latch for the pulldown motor, thats the problem its common, i would just replace the whole assembly, but if you know how to take it apart then just do the switch part, if you power up the motor when you take apart you can test the motor part of it, good luck hope this helps.
