Question about Canon Elura 100 Mini DV Digital Camcorder
Burning multiple mini dvd's to one dvd
Hi, I recorded a video on a Canon DC 100 camcorder using the 30 minute mini dvd's, I used 3 of them and now I want to combined them all to one dvd!! I've tried everything with no luck! PLEASE HELP! I NEED THIS FOR SCHOOL!!! Thank you
    President:
  • 2,961 Answers
If you have a pc and a video editing programme, you can make the 3 dvds into one by adding them individually as chapters directly from your camera. The programme i use is nero recode, you can download a trial version of this if you have no video editing programme. http://www.nero.com/nerodigital/enu/download.php
Posted on May 07, 2007
Can I hook up to the DW 100 Canon burner with my ZR200 to burn mini tapes on DVD?
No. The Canon USA web site says the Canon DW-100 has a USB terminal and works with "USB 2.0 Hi-Speed (with compatible Canon camcorders only)." In other words, the Canon DW-100 burner works only with Canon's USB 2.0 camcorders. I have a Canon ZR200. The ZR200 has Firewire 400 digital video output, not USB 2.0 output. The USB port on the ZR200 is ONLY for still images. Video will not and cannot be output through the USB port on the ZR200. (Page 121 in the ZR200 manual mentions using the USB port on your camcorder for transferring still JPEG images to your computer.) You need a DVD burner with "DV Input" (also called Firewire 400 or IEEE 1394) to hook up your camcorder to burn Mini-DV tapes onto DVD. The Sony VRDMC10 Stand Alone DVD Recorder/Player has DV Input. The ZR200 camcorder did not come with a Firewire cable, but you can buy one at any electronics store or at a cheaper price online. Make sure that you get the right kind of Firewire cable, 4-pin to 4-pin or 4-pin to 6-pin, whatever the DVD burner you choose requires. (Your ZR200 has a 4-pin DV port on the camera's end.) USB 2.0 Hi-Speed (with compatible Canon camcorders only)
Mar 15, 2011 | Canon ZR200 Mini DV Digital Camcorder
How to download video from Canon DC22
Please give me Degital JVC PC 810 Driver
Mar 03, 2010 | Canon Video Cameras
Editing videos taken from canon dc100 camcorder
I see here that . . .
"The DC100 takes 3-inch Mini DVD-R/RW discs, and like most of its competitors, can fit about 20 minutes of best-quality video on one. If you choose to initialize a disc for playing in a standalone player, the camcorder writes standard VOB files; if you initialize for future editability, it records in the VRO format. Windows Media Player can play the latter if you rename the file with an MPG extension, however the aspect-ratio information gets lost--that info is encoded into a separate file--so 16:9 video will get squashed into 4:3. "
Cnet Reviews.
Your videos are recorded in the common DVD format called MP2.
They have the extention .MPG so if you copy the video files to your computer, and change the end of the filename from VOB, or VRO to an MPG then your software can recognize it as the MP2 format that it is.
There is a Windows XP program, called Windows Movie Maker, it can open your video files and provide you with most of the video editing tools.
Cheers.
Jun 14, 2009 | Canon DC100 DVD Camcorder
Did not burn dvd
The DW-100 burns files in the same format as they were originally recorded by your camcorder. The Canon Vixia HG-21 records in AVCHD--a high-definition format--which is completely different from standard-definition DVD and which is not compatible with regular DVD players (even though the disc itself is a standard DVD-R). As it states in the manual for the camcorder, "High-definition (AVCHD) discs created using the optional DW-100 DVD Burner can be played back only with AVCHD-compatible DVD players."
The DW-100 is really more for archiving your files in their native format than for creating standard DVDs that can be played on regular DVD players. Regular (standard-definition) DVD players can't play AVCHD, although many Blu-Ray players can. Unless you use a Blu-Ray player that supports AVCHD playback, there are two solutions to your problem:
1. If you want to keep your recordings high-def, you can view them by playing them back with the DW-100, which must be connected to your camcorder via the USB cable, then from your camcorder to your TV via an HDMI cable.
2. If you want to have standard DVDs that you can play on any DVD player, either import the files to your computer and convert them to standard-definition using video-editing software, then burn them to DVD with your computer's DVD burner, or connect the analog output (component=better, composite=good) to a stand-alone DVD recorder (i.e. not the DW-100).
I've used the route of Vixia HF-10 camcorder > composite output > Panasonic DMR-ES25S DVD recorder (about $65 used on eBay) with pretty good results when I've wanted to give videos to relatives who don't have Blu-Ray players. You just have to make sure to set the camcorder 's analog (composite) output to 480i so that it formats the picture in the right aspect ratio, or else the 16:9 image will be squeezed to 4:3 instead of letterboxed.
Hope this helps. Good luck.
Mar 19, 2009 | Canon DW 100 DVD-RW Burner
Monitor for recording
attached the jack wire from the camcorder video output and the red and yellow wire goes to the tv video input.select the AV from your tv.good luck.
Sep 28, 2008 | Canon DC100 DVD Camcorder
Burning video from Sony Handycam DCR-DVD105?
i dont think that you can keep the menus from each mini dvd. but you can create your own dvd video with menu and at the same time you can merge all of your mini dvds. After you upload the mini dvd videos to your computer then use Nero 8 or 9 Software. On Nero look for dvd editable and browse your dvd videos then do as the instructions says to you. you should burn that with one DVD disc with menus of your own choice
cheers
CHARCOIS
Sep 01, 2008 | Sony Handycam DCR-DVD105 DVD Camcorder
Dear Magician1506
You should copy all mini dvds/ files on to computer system HD and please use any good quality dvd burning software and make new menu.
May 06, 2008 | Sony Handycam DCR-DVD105 DVD Camcorder
Canon DC 100
Is there a disc in it if not its supposed to say that.
Nov 22, 2007 | Canon DC100 DVD Camcorder
Canon Elura 100 Mini DV Digital Camcorder Logo
66 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
