Question about VIA P4X266 PE11-L Motherboard
When pc boot it will display " bios checksum error " please insert floppy disk drive a ready
  • 93 Answers
Check whether there is an os cd inside the drive and remove it. else reinstall the os
Posted on Dec 29, 2008
  • mohamed thahir Dec 29, 2008
    check whether there is an os cd inside the drive and remove it. else reinstall the os
DISK BOOT FAILURE, INSERT SYSTEM DISK AND PRESS ENTER... i have a mother board K7S741MG-6L, bios version 426wp225, i have this problem BIOS CHECKSUM ERROR , KEYBOARD ERROR or NO KEYBOARD PRESENT (which is...
your hard disk is disconnecetedor loose . pls check the hard disk power cable & IDE or SATA cable. Then check BIOS hard disk detected or not if hard disk is not detected your hard disk is faulty.
Dec 11, 2009 | Foxconn WinFast K7S741MG Motherboard for...
When i boot the computer what comes on the screen is (''award bootblock bios v1.0'' copyright(2) 2000, award software, inc bios rom checksum error detecting floppy drive A media insert system disk and...
it means your boot sequence is first booting your floppy drive or your hard disk is not detected.i think you should check the cmos set-up.you can set it by pressing delete while the pc is booting.disable floppy drive seek.also the boot sequence.the os installed is maybe corrupted, is also one of the problem. refer to the manual if you have.
May 16, 2009 | Computers & Internet
Clarification about my foxconn bios checksum error
try to change cmos battery...
or
flash BIOS
download bios from bellow link
and pls refer the manual.
http://www.foxconnchannel.com/support/downloads.aspx?ProductModel=661FX4MR-ES&TypeID=en-us0000004
thnaks
if ur problem solve so pls rate me..
bye
Mar 05, 2009 | Foxconn 661FX4MR-ES Motherboard
Compaq n620c evo laptop
Check your floppy drive and see if there's a disk in it and remove it. If there is no diskette in the floppy drive and you are still getting the error. You can go into the Bios and turn off the "boot from floppy drive", that way it will not look for the floppy drive when booting up. Hope this helps.
Feb 27, 2009 | Compaq Evo N620c Notebook
BIOS ROM checksum error
have you a hard disk in the pc ?
somehow your hard disk has stopped booting (virus , bad hard disk boot sectors)
you may have to reinstall the OS
hope this helps
Jan 05, 2009 | Intel D101GGC Motherboard
Checksum error
Hi Oliver, the most common error related to the message,
(Bios Rom Checksum Error). Someone has left a floppy disk in the floppy drive. Once the floppy disk has been removed press the reset button on the PC, your windows will start normally. Next place to look is in your bios.
Open your manual to page 27.
Enter your bios & go to the title Advanced BIOS Features. Check First, Second & Third boot devices they should be as follows. Floppy disk drive, CD-ROM drive & primary hard disk drive. If both of the above are ok than try clearing the cmos/bios by resetting the cmos jumper (JP1) location on page 5. Descriptions of page five on page 6. CMOS settings on page 9.
When your system restarts re-enter your cmos & reset up your bios settings. Lastly if none of the above has fixed the error message, than remove the cmos battery & check its voltage. It should maintain 3volts. If yours' is lower than 3volts replace the cmos battery. There is one other possible fix. It’s an option not given lightly. Flashing a cmos/bios is not recommended unless all other options have failed.
Bios link for the EliteGroup P4VMM2 V8.1
http://www.ecs.com.tw/ECSWebSite/Downloads/ProductsDetail_Download.aspx?detailid=436&DetailName=Bios&DetailDesc=P4VMM2%20%20(V8.1)&CategoryID=1&MenuID=82&LanID=0
Main web site;
http://www.ecs.com.tw/ECSWebSite/Products/ProductsDetail.aspx?CategoryID=1&DetailID=436&DetailName=Feature&MenuID=52&LanID=0
Good luck Oliver!
Mike
Aug 23, 2008 | EliteGroup P4VMM2 V8.1 Motherboard
Please help
Try pressing F2 / Del key during startup. That should bring the bios setup. Now Restore that defaults & install OS on your HDD. If you are not using Floppy drive, disable the onboard floppy controller from BIOS.
Jun 20, 2008 | ASUS P4SP-MX Motherboard
Bad BIOS checksum.... CMOS bad checksum errors
BOOT BLOCK COMPATIBLE VERSION VER .005
BAD BIOS CHECKSUM
CHECKING FOR CD ROM
READING FILE "P5SD2VM.ROM"
NO CD-ROM FOUND
CHECKING FOR FLOPPY DISK
NO FLOPPY DISK FOUND
Does someone already fix this problem??????
Nov 15, 2007 | ASUS M2N-MX Motherboard
VIA P4X266 PE11-L Motherboard Logo
87 people viewed this question
Top VIA Computers & Internet Experts
David
David
Tony
Abhinandan  Patil
Abhinandan Patil
Are you a VIA Computer and Internet Expert? Answer questions, earn points and help others
