Question about Panasonic CT-32G11 32" TV
TV TURNS ON WITH NO PICTURE BUT YOU CAN HERE
IT STARTED WITH HORIZONTAL LINES ACROSS TOP OF SCREEN THEN WENT AWAY AFTER AWHILE .
  • 43 Answers
You need some caps changed in that set in vertical circuit
i usually change about 5 caps to cure the problem
caps go bad over time
Posted on Aug 29, 2009
Have horizontal lines across the screen and some
Yeah we have the same exact problem here. Defective TV....ours would correct itself after 30 mins, but now it's blurry all the time. I'm never dropping 2K on a SONY tv again.
Aug 01, 2010 | Sony Bravia KDL-46VL130 TV
Horizontal Lines scrolling on screen
I had a similar issue with my Mitsubishi HD 1080. My power supply went out, I had it replaced and it works like new. However, just today I had AT&T U-Verse installed. When the cable guy was showing me the new HD channels all seemed good. This evening (about 5 hours after being installed) I started seeing these horizontal lines across my screen. The picture was still HD quality, but those annoying lines just wouldn't go away. Anyway, after reading a few blogs on-line suggesting interference or bad grounding, it hit me!!! The AT&T guy who installed my U-Verse (cable, internet and phone) had set the modem on top of my TV!!! It was just starring at me this whole time. So I removed the modem off the top of my TV and put it on a side table just to see what would happen and sure enough the lines were gone!!! You may not have the exact same problem, but it may be some type of interference (cell phone, modem, etc, either on top or around your TV that is causing the issue... Hope this helps. Thanks.
Oct 31, 2008 | Televison & Video
Horizontal white lines across top of TV screen
Hi I had the same problem. Broken white lines across the top of the screen. This is called overscan. You need to go into the Setup menu, other settings. 16:9 overscan needs to be on. Hope this helps.It solved our problem.
Sep 15, 2008 | Panasonic CT-2006S 20" TV
Picture reduced to 1/4 on a black screen
Picture is reduced to a straight horizontal line across the center of the screen.
Aug 17, 2008 | Televison & Video
Flashing Horizontal, Circuluar, Colored Lines
sounds like bad capacitors on the FMT board need replacing that is a common fault with the first generation DLPs There are 3 bad capacitors.
May 31, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Picture reduced to a horizontal line across center
sounds like the vertical, more info ctechnicians.com
Dec 21, 2007 | Hitachi 35UX80B 35" TV
Lines in picture
I had this problem around the time my TV was 3 years old. I ended up having to get it repaired at a TV repair place, it cost me $375.
Sep 24, 2007 | Toshiba 57H83 57" Rear Projection HDTV
RCA F36674ET - Only beeps when turned on
Clearly shows problem in deflection area both horizontal and vertical section. Horizontal lines is due to vertical section problem and making bbzzzz is due to horizontal output transistor short and sometimes LOT SHORT.
Aug 23, 2007 | RCA F36668 36" TV
Televison & Video Logo
110 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
