Question about Aiwa AV-D77 Receiver
My aiwa dv77 reciever will turn on but it takes a second it clicks like i want to turn on Aiwa AV-D77 will not power up. The unit tries to turn on but then shuts off. Red light is on, but no power to the receiver. Anyone have a solution?
  • 1 more comment
  • g ramey Dec 31, 2008
    Aiwa AV-D77 power failure. Click on when push power button, but immediatly turn off. I tried unpluging and waiting, then tried again and had same problem. Having same problem as the other posting about Aiwa AV-D77 power failure.
    The A V-D77 is a 5.1 audio receiver, not a CD player.
    Aiwa AV-D77 5.1 receiver power failure. Please Help!! Unit will not power up, it just clicks when the power button is pressed. Tried the enter buttom to reset, NO HELP!, tried unplugging and waiting several hours and retried. NO HELP! Does anyone have a solution to this reoccuring problen for the Aiwa AV-D77?
  • 10,594 Answers
Unplug receiver from AC outlet, unplug speaker wires and replug receiver in AC outlet and push power button. If receiver still does not power up, this means receiver got problem in output amplifier section and system control chip will not permit power supply to power up just to avoid further damage in amp section.
If you have electronics repair experience of receiver, let me know to guide you with more technical info.
Posted on Dec 31, 2008
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Initially, your description "unit tries to turn on but then shuts off. Red light is on, but no power to the receiver" is significant. It is indicative that the unit initially powers on, perform a built-in diagnostics, senses a fault, powers itself off to prevent further damage to its components/circuitry.
A few ideas you could try:
  • check the speaker/speaker wires using a continuity tester/ohmmeter. Reading should be between 4 ~ 8 ohms;
  • unplug the unit from the mains for an extended period of time. The idea is to dissipate capacitor stored electrical charge and hopefully revert the unit back to factory defaults;
  • perform the power-enter buttons to reset.
Good luck and Thank you for using FixYa.
Posted on Dec 27, 2008
  • Louie  Role
    Louie Role Jan 01, 2009
    The unit would then require opening, perform voltage measurements,determine faulty component and subsequent part(s) replacement. Further, a fair familiarity of electronic components/circuitry and safety procedures, use of a DVM and a soldering iron would be required. It would be to your added advantage access to a service manual or at the very least a schematic diagram with voltage readings.Should you be uncomfortable performing a DIY (do-it-yourself), perhaps your best bet would then be to seek the services of a qualified professional.
    Cheers.
    Genius:
  • 1,011 Answers
Sir,
Try to Reset the button If a CD does not operate properly, press the reset button
with a pointed object such as a pencil, etc. Note that all
your settings will be erased if this button is pressed.
For manual click this link
thanks
good luck
  • Aiwa Master
  • 19,396 Answers
That means that the unit is on protect mode, this happens when there is a short or a faulty component inside.
Try first leaving the unit unplugged from everything for one hour, if it stays on protection when you plug it back, thaen that means that there is an internal fault.
I have an AV-S17 and it's stuck on eco mode. I have tried doing what the form has said for me to do and it doesn't help.
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Aiwa-AV-S17-Receivers-manual/id/1076ag804/t/2/
Page 7:
To cancel the ECO mode
1 Press the ECO button to display ECO MODE while the unit is turned on.
2 Within 4 seconds, press the ENTER button.
3 Within 4 seconds, turn the MULTI JOG to select ECO OFF.
The mode will be automatically set after 4 seconds. It will also be set if the ENTER button is pressed within 4 seconds after step 3.
Mar 29, 2011 | Aiwa AV-S17 Receiver
My aiwa av-x200 click right off when I turn it on, Im thinking it is a blown fuse or something, anybody fixed any receiver with this problem?
The unit is going into protection mode. There is a fault detected in either the power supply or an overload on the output circuitry. Remove all connections to the amp (ie speakers, dvd players etc etc) Turn the unit on. If it still turns off the problem is internal and should be looked at by a qualified technician.
Feb 09, 2010 | Aiwa AV-X200
I have an Aiwa AVD57 and the unit won't turn. I tried pressing power and enter together and nothing happens
There is a fuse inside.If it blows when you replace it there it could ba a problem in the standby power circuit.
Sep 23, 2009 | Aiwa AV-D57 Receiver
Does not power up.
chuck05,
You might try to find a reset button on the back of the unit. Also, the Aiwa website may have a "support" staff that can see if they have an archived manual or tell you which buttons to push. Also, check to see if the unit has a fuse in back. Finally, check a website called audio.manualsonline.com . It's a free deal where people exchange manuals and information.
chrisxx
Jun 03, 2009 | Aiwa Audio Players & Recorders
Aiwa AV-D77 receiver power issues
Please confirm 9 volts on Power Board as shown in below picture...
Regarding click-click-click sound of relay its caused by Serial Clock and Serial Data signal failure in digital ICs. Please confirm above signals by using Oscilloscope.
Nov 22, 2008 | Audio Players & Recorders
Issue with the power. Reset doesn't work.
If you know basic electronics and can recognize parts inside receiver, then I'm here to help you but please don't call it as junk. Its beautiful piece of Aiwa.
Nov 08, 2008 | Aiwa AV-D77 Receiver
Aiwa AV-dv75 powers on and off
Its the power relay switch which is no longer made.
I have been looking to see if there is a class action suit on this receiver
Aug 31, 2007 | Aiwa AV-DV75
Power on but no display
Hello Coach T, Reset Instructions: 1. If pressing the power button does not turn the unit off, unplug the unit, then plug it back in. 2. Press the power button while pressing the ENTER button. This will bring the unit back to factory defaults. Please let us know if you need any additional help. Best regards, nightdiver
Aug 21, 2006 | Aiwa AV-D57 Receiver
Aiwa AV-D77 Receiver Logo
251 people viewed this question
Top Aiwa Audio Players & Recorders Experts
 Grubhead
Grubhead
Morne Olivier
Are you an Aiwa Audio Player and Recorder Expert? Answer questions, earn points and help others
