Greta, If they are cheaper batteries, that is probably the problem.
CAMERAS TAKE A LOT OF JUICE, try a better grade battery like Duracell and see if you get better results, make sure batteries have fresh date code and not expired to show your appreciation press the helpful button and follow me on fixya for more tips and info.
Your camera can work with the SDXC cards perfectly. But keep in mind that the one movie can't be bigger than 2 GByte or 29 minutes. The maximum size of a file can be 2 GB in your camera and 29 minutes is probably to avoid overheating the sensor. Some modern DSLR's only can shoot for 8 minutes for that reason. But after some rest you again can start a new movie and later put them together with software on your computer.
This is what the manual form your camera says about size of a video.
Look at your memory card. SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Manual says slow shutter speed. You can adjust this by going to "S" on the dial. However it could also be that your ISO setting is too high therefore restricting shutter speed. Set ISO to 400 auto - a good all round setting.
Press the MENU/OK button. Press cursor-left then select the wrench icon. Press cursor-right, then use cursor-up/down to select the clock icon. See page 14 of this manual.
Try resetting the camera by removing thebattery for 15 mins. Then install the fully charged battery in the camera andgo to the menu and set the Date and Time.If this does not work then this camera needs to be sent away forrepairs. Just like a motor vehicle, some repairs to your camera require atechnical specialist to fix your problem.
Thanks for very quick response on this. Problem solved!
