Question about Kitchen Ranges
Over feeding of pellets
The problem we are having is over feeding. We have overhauled the stove, cleaned over and over. No matter what we do, when we turn the stove on it lights fine after at least two times then starts to over feed pellets.
  • llarq Mar 25, 2009
    We have a St. Croix stove. This is our second year of having it. Not many problems the first year. This year we are having problems with over feeding of the burn pot. It will burn well for half the night, then during the night overload. Or a few hours with no problem, then overload on and off. My husband cleans it every day. Has torn it apart to clean, has spoken with stove cleaners that have offered suggestions, played with the damper, etc. He thinks he has it fixed, then it will start to overload (this occurs on all settings). It is extremely frustrating.
SOURCE: St Croix pellet stove: pellets drop
ignitior is bad ....
Posted on Mar 29, 2008
SOURCE: st croix pellet stove
Had the same problem which I discovered this weekend..........
I have an eleven year old Afton Bay....the versa grate was not moving. I look into the inner workings of the stove and saw a bracket which had broken off....
The bracket was attached to the versa grate rod and made contact with the cam system in the stove...this is what moves the versa grate...........
I called my dealer, the part costs about $12.00 and looks like it can be replaced with out having a service guy come out..........
Hope this helps
Posted on Nov 09, 2008
SOURCE: Pellet stove
i have a goodman furnace 1 yaer old and the burnner mainly late at night keeps cycaling on and of no codes present
Posted on Feb 01, 2009
aborcass
  • 2651 Answers
SOURCE: st.croix pellet stove
your either burnig the wrong type of fuel, or the fuel you are burning is wet, not burning hot enough resulting in cloudy door
Posted on Feb 03, 2009
myjosh007
  • 530 Answers
SOURCE: Feed paper light stays on, and paper doesn't feed through
hi im josh in cebu phils. friend if it stays lighted on and cartrdge move side to side. ther problem is in your paper feeder it wont detec the paper because maybe it is already covered with dirt and dust. try to clean it. good lcuk
Posted on Feb 23, 2009
Hopper auger will not stop
How to Repair a Pellet Stove Auger That Won't Turn ' Home ...
homeguides.sfgate.com > Outdoors > General Repair
Cleaning the hopper, removing and replacing the auger and installing a new motor and ... Most pellet stoves do not have a removable auger cover, but you can see a ... youcan hear the motor attempting to spin the auger, turn off the auger and ...
Why wont my Auger feed pellets? ' Hearth.com Forums Home
www.hearth.com > ... > The Pellet Mill - Pellet and Multifuel Stoves
Jan 6, 2008 - Two #1 reason auger motor will not operate is: PRESSURE ..... Hopperlid trip switches now used on some stove will stop the auger and on the ... Harman Auger will not stop.
Oct 11, 2015
auger won't turn on Lopi Leyden
Oct 14, 2013
harman accentra will not turn off
Dec 31, 2011
Harmon Accentra feeding continually but no ignite
Jan 14, 2008
More results from www.hearth.com
Whitfield pellet stove repair, pellet stove repair, auger re
Jan 10, 2016 | Pool & Spa
We have a heilsa pellet stove model#QCPS-28000 ,its dropping pellets to fast ,how do I adjust the feed.
  1. SET THE AIR INLET DAMPERS
It is not possible for the manufacture to factory set your stove to work properly without some adjustments. The dampers help control the amount of airflow supplied for combustion.
A damper PUSHED IN all the way, maximizes concentrated air flow to the burn pot. This will maintain a robust fire.
The Auger timing is designed to be run, in most conditions, with the dampers closed.
In some areas/conditions, it mybe necessary to adjust the damper open slighty in order to slow down the flame and allow the pellets to keep pace with the rate of burn. This should be monitored closely to ensure you have the propoer feed rate established. If dampers are opened too much, the rate of burn will be very slow and the pellets will build up.
This setting needs to be fine tuned to according to your location and elevation. It is recommended that you start with the dampers pushed in to start.
Feb 20, 2013 | Northern Tool and Equipment Pellet Stove -...
Have a pellet stove that has been working perfect for years, then last night it shut itself off and when I opened door there was this black tar on everything inside and the windows were also black. I had...
Several of things come to mind: Have you changed the type (Brand) of pellets, recently?
Have you had your chimney (stack) cleaned in the past year? Is the fresh air intake functioning properly? Is the auger feeding to much or to little pellets?
Changing brand of pellets - Not all wood pellets are made the same. If you recently changed brands, you will need to tweak your stove to handle this new brand. This will affect how the auger feeds.
If you chimney (stack) hasn't been cleaned in the past 12 months, it may be partially clogged with creosote and not drawing properly and it is liquefying and running back down the chimney and not allowing for a clean burn. And could cause a chimney fire.
Fresh air intake: If that's not functioning properly, you're getting incomplete combustion. Which will cause the black tar looking substance you described. Couple that with changing brands of pellets and you have a problem.
The above are the first things that came to mind. I hope it steers you in the right direction to troubleshoot the problem. Please let me know.
Mar 28, 2011 | Heating & Cooling
I clean the stove as discribed in the tape i got w/ the unit. But, in about 8hrs. burn time , fire box is over full and feed tube is backed up. I have air wide open and lowest feed setting. Any ideas . If...
That is an old pellet stove. One problem may be that you have recently switched the type (Manufacturer) of pellets. Not all manufacturers make the pellets the same way. So you would have to re-tweek the auger feed an the air intake to the stove. If you no longer have your Owners Manual try searching Google for the Manufacturer and contact them for advice. But, I suspect that the model you have is no longer manufactured, as it does not meet the current EPA standards for emissions.
Jan 27, 2011 | Heating & Cooling
Our napoleon stove barely heats the room it is in and it is new first year used,,
Try this....before starting the stove, place a handful of pellets into the burn pot. Start stove with feed rate about 2-3. Let the pellets ignite fully, then turn pellet rate to about 5, less then max. Let a good flame develop for 5 minutes or so, then turn on the fan. I set the fan at about 3-4 as advised by the tech. Reduce feed rate to about 4. I keep my damper on 2 1/2 to 3 to supply air intake. Napoleon is not the greatest stove, and I'm having an issue with mine after 3 years, but hopefully this helps. It will never give the heat of a wood stove, but get a strong fire going first, then tune it down after the room gets warm.
Jan 16, 2011 | Napoleon Auburn Pellet Stove Heater
Plugged feeder on pellet stove
if u can get at it you can clean it, if you get at a little of it you may be able to hit it with a small brush or paper clip or finish nail or whatever while it is revolving. I spraye my old stoves auger with PB blaster then cleaned it and of course let it air out for 2 days as that is flamable. The cause is probably inferior non-hardwood pellets. Been there....and doing that .. good luck
Dec 07, 2009 | Stoves Heating & Cooling
Pellet stove auger motor
What's the matter with it? I can tell you how to overhaul and rebuild it.
Nov 11, 2008 | Kitchen Ranges
Kitchen Ranges Logo
204 people viewed this question
Top Kitchen Ranges Experts
Oloyede Monsuru
Marvin
Marvin
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
