Question about Indesit 24 in. DE73 Evolution Free-standing Dishwasher
Indesit evolution de 73 dishwasher with an AO5 error code
This has happened after moving it so that the area could be cleaned. Could you please assist me by giving me the meaning of this error code and a fix. Thank you, Fin
  • Anonymous Nov 04, 2007
    error code a01 kept appearing tipped 70 deg then ok, a05 then appeared checked all filters arms not blocked help
  • 4 Answers
A05 is pressure switch not reset. check for blockages in the drain pump, filters and sump
Posted on Jul 28, 2007
Sulla mia lavastoviglie indesit de 74 evolution mi appare il codice di errore a12 mi sapete dire cos'?. Grazie in anticipo Fabio
Ciao Fabio.
A12 significa che c'e' un problema con il circuito di riscaldamento dell'aqua. A12 appare quando il modulo di controllo rileva che il circuito che include l'elemento e'aperto.
Elemento e circuito devono essere testati con il multimetro. Se l'elemento e' aperto deve essere sostituito. Se i cavi e l'elemento sono a posto, allora il problema e' il relay integrato nel modulo di controllo.
Il caso piu comune consiste in un elemento diffettoso.
In bocca al lupo.
G.
Dec 08, 2011 | Indesit 24 in. DE73 Evolution...
Indesit dish washer is showing error code A08 why
from what i can find out, it means (auxillary wash pump triac cloesd/open circuit)
Sep 25, 2011 | Indesit 24 in. DE73 Evolution...
Indesit Evolution W16s washing machine H20 error code
if there a advance cycle button push it an see if the timer will advance to spin if not turn the power off to washer an wait a couple mintue an the door will open
Apr 24, 2010 | Washing Machines
Led states A05 problem and machine stopped working
"Error A05 - Pressure switch has not been reset "
This is centered around the filter and drain area not working properly.
It is possible it just needs the filter cleaning and the hose flushing out, but also possible the pump needs to come out to clean it properly.
Drain it by putting the hose low down, and clean the filters of debris.
If this does not fix it, then remove the unit outside, lie on it's back and remove the pump to clean it.
Feb 09, 2010 | Indesit 24 in. DE73 Evolution...
Error code a14 on indesit evolution de73
A fault with the water heating has occurred. Book a service engineer
Sep 07, 2009 | Indesit 24 in. DE73 Evolution...
Indesit evolution de43 error a02
can my dishwasher start leaking with putting too much salt in it?
Dec 14, 2008 | Indesit Dishwashers
De 73 tripping house electrics
NEED TO REMOVE AND CHECK WIRING ESPE THE HEATING ELE AND MOTOR WIRES AND LOOK @THE HEATING ELE INSIDE THE ENCLOSURE CLOSE
Dec 12, 2008 | Indesit 24 in. DE73 Evolution...
A05 code
ao5 is showing on the display of my indiset de73 dishwasher
Aug 19, 2008 | Indesit 24 in. DE73 Evolution...
Error 05
There should be a hose on the back that is placed in a drain "usually kitchen sink". If it will not drain after this unplug the appliance and check the bottom for a food clog and clean if needed.
Mar 26, 2008 | Indesit 24 in. DE73 Evolution...
A13 error code
It seems to me that there isn't any problem with the normal washing cycle. The problem you have could be related to your dishwasher's detergant dispenser lid. I reckon that the relevant part isn't functioning normally. You can simply check out the claws placed on the detergant lid. If there is a spring inside, it might be damaged.
Apr 16, 2007 | Indesit 24 in. DE73 Evolution...
Indesit 24 in. DE73 Evolution Free-standing Dishwasher Logo
1,099 people viewed this question
Top Indesit Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Eric Taylor
Are you an Indesit Dishwasher Expert? Answer questions, earn points and help others
