Question about Wharfedale DVD-M3 DVD Player
Not all speakers work
I have just purchased a wharfendale DVD 75 USB home theater system and 3 of the speakers do not work (SR, SL and the Centre speakers) they came with the system. I the Audio Setup these speakers seem to be "grayed out" ie I cannot set them up. What is the problem?
Hi I have the same problem, did you find a soloution?
Posted on May 03, 2010
UBX Home Theater System
It sounds like a problem with your centre channel or speaker. The sound of Voices and on-screen, actions in the middle of the screen are played through the centre speaker. General sounds such as music in the background, off-screen events, etc. will be played through other speakers on a home theatre system. Check your connectors coming from your DVD player to your sound system. Are you using a single-cabled digital connector or one for every channel? Check your sound settings as well, i.e., Surround, AC3, Music, etc.
Jan 30, 2014 | Audio Players & Recorders
Tip
How to install a 5.1 home theater system
1. Read the installation guidline/connection diagram given with the product.
2. u will get 5 speakers and a subwoofer. speakers are front left & right, rear left & right and center speaker.
3. install the front spearkers both side of the TV at ur ear level.
4. install the centre speaker at the centre above or below the TV at ur ear level.
5. install both the rear speaker at the back side wall corners (min 1.5 feet from ur sitting position) at a hight of 5 feet. face the speakers towards ur sitting position.
6. keep the sub woofer at the right side corner of the room.
7. note that the room should be a closed one with less air ventilession & use a carpet on the floor to get clear sound.
8. use co-excial or optical fibre cable to connect ur home theater system to ur TV, DVD player or audio device.
Now u can enjoy ur home theater.
on Aug 15, 2010 | Audio Players & Recorders
Hi I have bought a new sony DAV-DZ310 model home theatre.I have connected all the speakers and a woofer.All are working fine except the center speaker.It is not at all working.I have made the connections...
This may not be Dependant on the Music or DVD, but with the setting on the Home Theater system. Try out all the modes - such as 2 Speaker, Multi etc. within the Home Theatre system. In one of the mode only the center speaker works.
Hope this helps. Good Luck.
~SmokinJoe~
May 24, 2011 | Audio Players & Recorders
When playing a DVD music and backround audio is ok but actors have no sound (talking) any idea ??
Check the connections to the centre speaker which is where the actors voices come from.
Jan 29, 2011 | Bose 3 2 1 Series I DVD Home Entertainment...
The rear and centre speakers are not working but the front and subwoofer speakers are working. What do I need to do to get the three working. In the booklet it says the rear speakers might not work becasue...
From them manual Troubleshooting section:
"When listening to a CD or radio, sound is output to the front
speakers (L/R) only. Select "PRO LOGIC II" by pressing
PL II (Dolby Pro Logic II) on the remote control to use all
six speakers.
• Make sure that the DVD disc is 5.1-CH compatible.
• If you set C, SL, and SR to NONE in the speaker mode in the
audio setup of the setup screen, no sound is heard from the
center speaker and the rear left and right speakers. Set C,
SL, and SR to SMALL."
This means you might want to check your speaker settings again and make sure the Cenyer and Surrounds are defined.
Feb 27, 2010 | Audio Players & Recorders
Speaker set up what speakers are the l.s. and the r.s.
LS or SL is rear left and RS or SR is rear right
Feb 21, 2010 | Zenith ZHX-313 System
How to hook up protron pds-2315
First of all, the PDS-2315 is not a DVR (this question is incorrectly categorized), it is a home theater system. Also, this system is not a receiver -- it is a DVD player (DVD/CD/HDCD/CD-R/CD-RW/Kodak PCD Playback) with a "full function" Karaoke feature with two microphone inputs. If you haven't figured out how to set it up in the past 11 months, this is how you do it.
1. Connect the supplied RCA cables (labled FR, FL, SR, SL, Cen, and SW) to the corresponding RCA connections in the back of the DVD player and the back of the Sub-Woofer.
2. Connect the DVD Player to your television.
A. Video:
There are several options here depending on your available Television inputs: Coax Cable, Component (yellow jack), S-Video and Composite (composite providing the best video resolution and coax the poorest). HDMI is not available. Use s-video or composite if you can. You will note that the composite RCA jacks are colored Orange, Blue, and Green. In a pinch, any RCA Cables will work - just don't cross the color codes between the DVD Player and the television. If you need to use coax you will need a coax to RCA adapter. If your television only has a component jack (yellow), it's a simple connection between the two.
B. Audio:
On the back of the DVD player you'll find two RCA jacks labled "Main R" and "Main L". These will be connected to your Audio Out connections on the back of your television. If you don't have Audio Out RCA jacks on the back of your television, but have an earphone jack, you can purchase an RCA adaptor to make that connection. With rear audio out jacks, you should have an option in your television's audio setup menu to select those outputs. (DO NOT CONFUSE "AUDIO OUT" WITH "AUDIO INPUT" because the will look identical.) If you don't have either of these connections, you will not be able to use the system to listen to television signals.
3. Connect the speakers. Each of the speakers is labled with their position (FR, FL, CEN, SR, SL). The speaker wires are color coded to the spring connectors in the rear of the sub-woofer/amplifier. Press the spring lever and place the wire into the opening. For proper biasing, place the color coded wire into the colored spring connector and the other wire into the black connector for the specified speaker. Connecting the speakers should be very easy. If the ends of the speaker wires become damaged, simply strip the wires back half an inch and connect as above. Place the speakers as specified by their position lables (FL, CEN, FR in front of the television and SL and SR to the right and left of the seating.)
4. Plug it in and power on. You'll need to plug in both the DVD player and the sub-woofer. Press the power button, hit the open/close button on either the DVD player or the remote control and put a disc in the machine. If you don't have a picture or a "Protron" title screen, hit the "P-SCAN" button on the remote (top left corner below the "STANDBY" button).
5. Hit the "SETUP" key and enter your system's information and you're done. Your system will work just like any other DVD player with theatre quality sound. --With the added feature of functioning as a Karaoke machine! Just add proper Karaoke CDs, a couple microphones, a bunch of friends and copius amounts of alcohol . . .
Feb 21, 2009 | Protron PD-DVR100 DVD Recorder
SB speakers error
I had the same problem but fixed it (no thanks to what I believe is an oversight by Pioneer!). The amp is a 7.1 system. What we are assuming is the rear surround (SB) is the default using a 5.1 setup. The amp uses the SR & SL as the default. So the solution is plug your rear speakers into the SR & SL & you should have your surround! (only took me 6 hours to figure this out, hope it saves you time!)
May 01, 2008 | Audio Players & Recorders
JSI js5001 Home Theater
My dvd player won't go on. Worked one day the next day wouldn't work any help?
Jan 05, 2008 | Progressive Computer JSI 6 spkr. Home...
Wharfedale DVD-M3 DVD Player Logo
57 people viewed this question
Top Wharfedale Televison & Video Experts
Marvin
Marvin
Colin Stickland
Colin Stickland
Are you a Wharfedale Televison and Video Expert? Answer questions, earn points and help others
