Maytag washer won't spin fast enough to dry clothes
Hi, I read your post. I'm having the same problem with my Maytag washer not spinning fast enough to dry clothes. The strange thing is that maybe the 3rd or 4th time that I run it on just the "spin" cycle, it will speed up and dries them perfectly. So, it appears only on the first spin cycle I have this problem. Unfortunately it takes forever to do laundry when you have to "spin" things 3 times.
Out of your suggestions below, what do you think it might be if it work sometimes? Also, just curious on cost of this repair since this is an older washer.
1. Bad gearcase (transmission).
2. Bad basket drive, with which the transmission couples to under the agitator.
3. Bad clutch/brake assembly. Which mounts on top of the gearcase under the basket drive.
THANKS!
Washer_tech
  • 164 Answers
SOURCE: Maytag washer
if the belts haven't been replaced in a while, change them. after a eriod of ti,e belts will stretch, and become worn. this will prevent the washer from spinning out most of the water
Posted on Oct 12, 2007
SOURCE: maytag atlantis washer
I am also expiriencing the same situation.
I took a look at the machine and it appears to be in good working order.
But the belt does appear to be in need of replacing. I have ordered one and should find out everything will be back to normal once it is installed.
The worn belt would explain a lot.
- Light load are fine due to the lack of power needed to spin the contents.
- Heavy loads need the maximum amount of power it can get to spin.
But does not because the belt is slipping further into pulley grooves and is probably partially slipping, due to the wear.
Posted on Jan 02, 2008
SearsTechToo
  • 261 Answers
SOURCE: washer won't spin dry clothes
What model is in reference here? Please post back with model number.
Posted on Oct 16, 2008
onthejob5130
  • 640 Answers
SOURCE: Hi, Own a Maytag Atlantis
did you take off agitator,,look and see if you did eat the bottom of the agitator up,,splines,,
Posted on Jan 10, 2009
  • 68 Answers
SOURCE: Cloths Soaked after Spin Cycle
If the motor has a transmission, it could be stuck in 1st gear. I think the agitator running is normal.
Posted on Jan 17, 2009
What will cause the washing machine to not spin fast enough to spin the clothes dry or not spin the fabric softener out of the agitator cup?
If your towels are coming out the dryest it is probably a problem with it being off balance. Did you make sure that the clothes are even placed in the washer. If you have a bunch of heavy stuff on one side and light stuff on the other side it could cause the same problem.
Dec 05, 2012 | Maytag Legacy Series Top Load Washer
My Hoover 700 LA Top loading washer does not spin dry clothes after the was cycle ? The drum does not spin fast enough for the clothes to dry out as before.
Just got Hoover 700 la manual top loader 2. hand...it is taking maximum amount of water on low arrange, and takes an hour on delicates. it also spin dries very strongly, just ruined my clothes..what you would suggest folks..
cheers aysh
Jul 06, 2012 | Washing Machines
We just moved and the house came with a Maytag Neptune TL which won't spin if there are clothes in the cylinder. It will spin empty. Please help! Thanks.
Washer bangs around in spin cycle and throws a DC or UC unballance code with cloths in the wash basket is that correct?
If so it's a Clutch issue.
If you want read more about what I feel is your issue read this post Maytag Neptune load unbalance
Sep 08, 2011 | Maytag Neptune FAV6800AW Top Load Washer
MAYTAG WASHER WILL NOT SPIN
Drive belt may be loose or the fluid drive clutch plates worn.
That is if your Matag has a fluid drive system.
If not, Drive belt
Good luck
Feb 23, 2010 | Washing Machines
Clothes are dripping wet after spin dry cycle
You may have a bad belt not spinning the drum fast enough or not enough tension on the belt due to worn motor springs.
Jan 02, 2010 | Maytag PAV2300 Top Load Washer
My washer doesn't wring the clothes fully.
It's not spinning fast enough because of a loose or worn belt on the motor. Post back with your model number and I may can find a diagram of your washer to help you.
Sep 04, 2009 | Maytag Performa PAV2200
Spins fine, but clothes still soaking wet
Clogged water pump. Not draing fast enough. If this is helpful, please post as such.
Feb 21, 2009 | Maytag Performa PAV2200
Maytag Neptune MAH6700AWW spins but not fast enough
Too much laundry in your machine. Try a smaller load and see if you have the same problem
Jan 19, 2009 | Maytag Neptune MAH5500B Front Load Washer
Jan 17, 2009 | LG WM1814CW Front Load Washer
Washing Machines Logo
1,045 people viewed this question
Top Washing Machines Experts
