Question about Belkin (F5D7230-4) Router (587009)
Cannot get blekin wireless g router to work
We have done all connections as per set sheet but cannot get it
to connect to computer
I had the same problem when I installed mine. Make try changing cables around and re insert disc do not cocect anything until pronpted on screen. Make sure you set WPA so that network is secure. Mione working fine now.
Posted on Dec 30, 2008
  • kevindee Dec 30, 2008
    Sorry for the spelling mistakes. That should read do not connect and prompted....
I want to set up security for a network already established ...
Is there any computer connected to the router ?
If not then you will need to connect the computer to the router.
Do not change any wireless settings on the router with the wireless computer.
you will need to connect the computer to the router with the Ethernet cable.
check the IP address of the computer.
open the router set up page of the router.
Here you can change the wireless settings of the router.
Now once you change the network anme and security on the router, you will need to connect to the wireless network on your wireless computers.
Click Here for step by step instructions
Aug 29, 2010 | Cisco WLS G BROADBAND RTR-54MB PER SEC W/...
I just want to use the router as a wireless switch
1. power router off
2.connect all computers you want to connect.
3. start computers one at a time completely
4. check router for status light per computer to see if device is seen by router.
5. open web page to see if each computer is online.
7. do ipconfig / release/renew if not connected.
then .....
1.Log into router
2. Verify wireless router name( on the computer) >>> ( on/off)
3.Note router name you are connecting to.
4.. Check the laptop/desktop do ipconfig /all to see current IP addresses.
5. Set the laptop/desktop PC's up in the router by WEP KEY or MAC address.
6.Note router name you are connecting to.
7. Move the laptop about 20ft away and try to log on to the internet.
This is for all routers to set up wirelessly. You can connect up to 250 wireless devices on one router. This will decrease bandwidth of course but this is the range.
Jun 29, 2010 | Cnet CWR-854 Router
Cant connect wirelessly to my router. have done all the steps like WEP setup, password and router name. just says failed when i try to connect wirelessly. and when i try to connect the router to my comp...
You will need to check the settings of the router. You said that if you connect the cable to the router and computer, it still doesn't work.
First make sure that the computer is able to go online when connected to the modem directly, without the router. If your computer is able to go online through the modem then your modem is working properly.
Now connect the modem and the computer to the router. check the IP address on the computer. open the set up page of the router. This is the page where you can change all the settings of the router. According to the type of Internet service change the settings of the router.
Click here for more information about the router and networking
Feb 14, 2010 | Linksys Wireless-G Broadband Router
I have vonage telephone hooked up to my pc.how do i install my wrt54g router,what wires go where?
Who is your ISP. I think your modem is connected to the Vonage and Vonage is connected to the computer. If that is the connection then you can disconnect the computer from the vonage and connect the router there. From the vonage connect to the internet port of the router. then connect your computer to the router. Check if that works. If you are connecting the router to the modem, then you will need to set up the router as per the modem set up or type of ISP. Click Here for step by step solutions
Nov 17, 2009 | Linksys Wireless-G WRT54GS Router...
When I connect my wireless router to my computer the speedtouch cannot be detected by my computer therefore I have no internet on my computer but I have wireless on both laptops which are directed through...
you probably have the router set to static ip so first you have to assign your pc with an ip range of the router , then log in the router set to dynamic ip and make sure you connect cables as per router manual. if it does not work then disable firewall , enable upnp devices . After configuration of wireless router you can enable firewall again. If you are using vpn with speedtouch then you should configure speedtouch to store username and password to connect to isp
Sep 11, 2009 | Computers & Internet
Brother printer and Neygear router wireless connection bad.
Had the same issue. Change the router wireless security settings from TKIP to AES algorithms. This did the trick for me.
Feb 21, 2009 | Brother MultiFunction Center MFC-440CN...
Unable to go online
I want to tell you that before making wireless connection you have to ensure that are you able to go online with the netgear router using wired connection if yes i will provide steps to configure wireless on the router.
WIRELESS SETTINGS, you can follow directly to solve teh wireless part of the router :
Once its done follow the same steps to make you wired connection working. Once its done, Lets move on to the wireless connection
a. click on the wireless settings under the heading of setup
check out another screen shot below :
a. Change Name SSID : name of your network that you want to have
b. CHANNEL : Change to 11 and if uts 11 change it to 06
c. Mode : change to G&b
d. Sceurity : Select WEP
e. Key1 ; type any 10 digit number or you can type 1020304050, as mention above as the password for your wireless network
Till now we have set up the wired connection and wireless connection on router and now lets connect your wireless computer with it
you will able to see your wireless network name on your computer, simply select it and it will prompt you for password that will be your 10 digit number you punch in Key1
connect with it and you are ready to go with your wired and wireless connection
I believe these steps help you to resolve your problem
Thanks & Regards.
Jaspreet Singh Saini
Jan 10, 2009 | NetGear WGR614 Wireless Router
How do I use a router?
1st you need to connect to the router with a PC to set up the internet connection. You will also need to configure Wireless passwords (assuming that you wish to connect wirelessly) I suggest that you use WAP as your security method. Once you have done this you will need to connect your kids pc's to the wireless network, This is done by entering the Wireless key you have just set up.
This is a very high level flyby. If you need further information let us know.
Dec 12, 2008 | Gateway Belkin 54g Wireless DSL/Cable...
CONNECTION PROBLEMS WITH BELKIN N1 ROUTER /MODEM
YOU CAN RESET THE ROUTER TO FACTORY SPECS IF YOU INSERT A PIN INTO THE TINY HOLE IN THE BACK. THEN YOU WILL NEED TO LOOK UP THE MANUAL TO TELL YOU HOW TO SET IT UP. Sorry about the caps. The button stuck.
Are you trying to go wireless? Wireless settings will need to be passworded as per the manual. Your computer will have to have wireless connection and it will need to be set up correct also. Default settings usually work. The drivers will allow you to set up the wireless card in the computer. Go to the web site and find the drivers and the manual. This can not be done by one of us here. We can help after you have done everything that I told you to do but it will work if you follow my directions.
May 30, 2008 | Belkin Computers & Internet
Belkin (F5D7230-4) Router (587009) Logo
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
